I hope you can help. I have a Zanussi DCE 5655. It heats water and runs a cycle but only if I unplug it from the wall at night?!?!?! There is usually some small leaking going on inside during operation the unit which I can see if I remove the face panel. If I try two runs then the second usually doesnt heat. I have a hunch this is smthg to do with the polystyrene water detector microswitch float but I havent managed to locate it yet. Any help appreciated. Thanks
SOURCE: Zanussi ZSF6160 Water not heating
Mantona, you're on the right track. Your heater terminals are large, insulated and poke through the tub facing downward. To test this, remove one of the wires connected to the terminal, then check OHMS. If this is what you did, you don't have to do that again. Elements rarely fail, the problem most likely resides in the hi-limit thermostat. You know where the element is, now follow one of the wires back toward the control panel. One of the element wires will pass through the thermostat (in series) before going to the control. The thermostat is mounted tightly to the bottom of the tub, touching it to monitor temperature. When you find it, remove one of the wires (there are 2) and check OHMS. You should read ~1 Ohm, if you read infinity, you found the problem. (You can verify your finding by removing both wires from it and connect them together. Then run a wash load to check the heater. Don't leave it in this condition! The thermostat is a safety device and should not be permanently bypassed! If your test of the t'stat proves that it's OK, you'll have to test it with power on and running. I can walk you through this if needed. Let us know how it turns out.
SOURCE: zanussi dishwasher
hi there sounds like a possible dry joint on the pcb repair and try first
SOURCE: How to replace heating elemant on Zanussi DE6850 Dishwasher
is your water heater set on 120 degres
SOURCE: Zanussi DCE 5655 dish washer
There's a water leak inside, causing the anti[ flood micro switch to activate. Even a couple of tea spoonfuls of water will cause this. Remove the cover and check the polystyrene float at the bottom. A very small amount of water there will cause the problem. Check for any water leaks or even a slight water surge when the machine starts.
SOURCE: my zanussi fitted dishwasher is leaking water
it has a pressure stut,that should tell it to stop filling the machine,it sounds like it has gone
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
lmnbv
