Toshiba 57H93 57" Rear Projection HDTV Logo
A
Anonymous Posted on Feb 25, 2013
How to remove power supply from Toshiba 57H93 TV
2 Related Answers
Chi Chu
  • 8457 Answers
  • Posted on Oct 20, 2009
SOURCE: my toshiba 57h93 worked fine this morning power went out
Ur DM power board is dead,must be replaced.Try this
website for the board.Tv repair World.com.
Anonymous
  • Posted on Oct 07, 2010
SOURCE: How to replace power supply?
Toshiba model 57H93 worked perfectly last night. Turned off and went to bed. Turned on this morning, and nothing, it won't turn on. Checked all cords and cables, pushed reset button, and still won't turn on. What could cause this to happen?
57h93 flashing screen
If the set when first turned on has noise lines or distortion (left to right usually) but after several minutes they diminish and go away you have a bad HYPER board.
If this is the case let me know and I will advise you on options.
My Toshiba 57H93 has too much red in it. I cannot get the colors to look right anymore. Convergance seems ok. Any thoughts on how to fix this?
I had the same problem and called sears they only chare $99 to come out free estimate. it was a circuit board had to be resoldered and it works great
3helpful
1helpful
No power
has a short in the power supply I suggest it is a technical revs
3helpful
My toshiba 57h93 worked fine this morning power went out
How to change a fuse on toshiba 5793 when a power surge occurs
hello yes there are fuses. the main one is located in the power supply it glass type it might be black where it has shorted if you replace it and it blows again then you have a dead short in the power supply good luck. ps on the main there are wickman fuses these are solder in to the board
shaun
2answers
After power surge my tv (toshiba 52') will not power on
after a power surge if you dont have in on a surge protector it probably fried the main board in the tv so it wont work anymore..woudl probably be cheaper to buy a new tv than to try to repair the one you have now
1helpful
Toshiba 57H93
I have the same exact problem that started today. Any ideas.
57H93 Toshiba
Protect screen Part # 23311038.......117.30
Fresnel screen ( inside ) # 23311014 ...65.47
Lenticular screen ( middle) # 23311128....81.96
You should only need the protector screen......T.
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
