Question about SanDisk Sansa e250 MP3 Player
My sansa clip froze after I removed it from my computer It reads disconnected on the screen. Any suggestions? EDH
Since I was unable to it off the battery became low and it fixed it self
Posted on Feb 19, 2009
SANSA CLIP MP3 FROZE WHILE CHARGING
try removing the battery and putting it back in and see what happends. i not sure this will work
Jun 03, 2012 | SanDisk Sansa Clip MP3 Player
Player is froze
Push the power button up and hold it for 20 seconds.
Release it, then turn it on again. Go to the Sansa website (http://www.sansa.com) and download the "SansaFirmware Updater." Select "Run" when the updater installs.(Installation will take less than two minutes.) Wait for the Sansa Firmware Updater to run through its system test. It willask you to connect the Sansa Clip to the computer to update your Sansa'ssoftware. Connect the Sansa Clip. Remove it from the computer when instructed. If thisprocess does not unfreeze your Sansa Clip, contact Sansa support at the SansaFirmware Updater website.
Complete Reset
Turn player on. Press the "Menu" (home) button.
Pressthe bottom of the scroll wheel until you reach the "Settings" screen.Push the center button to choose "Settings." Scrolldown to "Reset All" and select. You'll be asked to confirm the reset.Select "Yes." This option will simply allow you to reset the languageand location settings on your Sansa Clip. Thiswill not erase data from the clip.
To doa complete factory restore, whichwill erase all files from the clip, follow these steps: Inthe "Settings" menu, scroll down until you reach "Format"and then select. You will be asked to confirm that you wish to format. Select"Yes." Wait for the screen to say "Formatting Complete."You have now cleared all the files from your Sansa Clip and reset it to factorysettings.
Oct 24, 2010 | SanDisk Sansa Clip MP3 Player
My Sansa Clip screen is not showing up (it is
it is probably defective. take it back to the store and replace it
Mar 21, 2010 | SanDisk Sansa Clip MP3 Player
My sansa sanclip just froze.iit was charging and
Hi.
You have two Solutions.
Solution 1:
Resetting the player:
1. Slide and hold the Power switch up for approximately 20 seconds.
2. Release the Power switch.
3. To turn the player on, slide the Power switch up then release instantly.
Solution 2:
Updating the Sansa Clip Firmawre:
  1. If it's not installed yet, download and install the Sansa Firmware Updater.
  2. Connect your Sansa Clip to the computer.
3.1. Assuming there's a new firmware available, the following message will appear on your lower right task bar. Click on the balloon message:
3.2. 3b. OPTIONAL: You can also manually run the SansaUpdater from your programs files. Most likely it will be under All Programs > SanDisk > Sansa Updater > Sansa Updater.
4. Select the Firmware check box.
5. Click Download Now. Firmware downloads and updating starts.
6. Click Finish after the firmware has been downloaded.
7. Disconnect your Sansa Clip from the computer.
8. A "Firmware upgrade in progress" message will appear on the Sansa Clip's display screen. The device will turn itself off after the firmware is updated.
Additional Help:
Sansa Clip Manual Guide.
If you need any Further Help Just don't Hesitate Asking me.
Thank You For Using Fixya.
Good Luck.
Nov 03, 2009 | SanDisk Sansa Clip MP3 Player
I was charging my sansa mp3 player and now it does not work!!!!!!
the problem is when the computer freezes it sometimes can wipe the hard drive and can damage the mp3 player for good thus freezing it from turning it on and clearing the memory and thats it
Dec 27, 2008 | SanDisk Sansa Clip MP3 Player
Sansa 1g clip wont turn on.
did you try holding the power button on for ten seconds (the reset) after trying to charge it again? does it even power up when you plug it into the usb. if it powers on when connected to the usb and then shuts off immediately when you take it off the usb (rather than "refreshing database") then your battery is either 1)disconnected inside 2)dead or there may be issues with power management. Same thing happened to me (disconnected) but I soldered the loose connection and it only worked for two days, even checking the connections again. Now I don't know what's going on. It's more likely the battery has reached the end of its life.
Nov 16, 2008 | SanDisk Sansa Clip MP3 Player
Won't do anything!!!!
My screen "froze" up and stayed continuously "blue". I pushed the power button up for 10 seconds and it reset it self.
Sep 26, 2008 | SanDisk Sansa Clip MP3 Player
Fozzen conected screen
turn off your mp3 then switch it to the hold option hook it back up to computer then hold on to the center button til it unfreezes.
Apr 02, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
