1996 Audi A4 Logo
Posted on Feb 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Audi starting A4 Audi. Hit a curb, had a flat. Went to work. Hours later: Drove on flat 200 feet. Inflated with "fix of flat". Start car with lights on low beam. Drove 100 feet. Lights does not go to high beams as needed !! Stopped, turned car off. Turned lights off then attemps to start car. Hours later... After 3 separate 20 minute charges later and a push to autozone. No start, Help needed.
Anonymous
Level 2:
  • Expert 100 Answers
  • Posted on Feb 18, 2009
Anonymous
Expert
Level 2:
Answers
100
Questions
Helped
71419
Points
226
You may of dislodge a main fuse, check them for security and integrity
Audi A6 Brake Light & Beeping
think its a computer system issue-its all connectd these days-even with the steering--disconnect batt then put it back after a minute-may clear up--------if not pull plug at computer clean it and replug a few times-----these reboots at times work------but u mite need to run a thuro diagnostic to see different voltages-go to a good mechanic not a dealer--a hand held scanner will not do this
Stuck in gear audi A4 1.9TD 1996
Check the trans gear oil!!!
Also the cables from the shifter to the trans actuate levers on the trans that sometimes stick. Check the levers.
1helpful
2helpful
2answers
Audi a4 whirring acceleration noise
Hi i have 02 audi a4 slimline. on motorway going 70 mph and to past a car dropped it down to fourth gear probly hit 90mph. Drove for a further hour and a half, and hear a bang under car. car started to loose power. was drivable but hissing noise come out of it when accelerating. Feels like turbo not kicking in. Would this be that the turbo has blown of maybe burst pipe or something. If anyone can share a light on this i would be very greatful. Cheers
2answers
Have an audi a4 1.8T Cabrio. Battery went dead,
You will need to put the car on a scanner to reset.
2answers
Did'nt start
weak battery due to shot altenator
200 AUDI A4 WILL NOT START AFTER BATTERY CHANGE
make sure you have the correct battery for you car.
1helpful
2answers
05 audi backup sensor
Have AUDI reinitialize back up sensors via factory scan tool.
1helpful
Audi tt 180 quattro car wont start. EPC and E-M system lights on
I would suggest you check oil levels etc. Generally these cars suffer from the air mass meter / air sensor problems aswell as coil problems too. Did you ever get a solution to the problem?
Top Audi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you an Audi Expert? Answer questions, earn points and help others
