SOURCE: A light comes on in my car that says oil pressure
If the light is only turning on during acceleration or deceleration and then goes off, this is normal. If the light is constant, and you are sure you have oil that is up to the "full" or "max" level on the dipstick while hot, then it might point to a faulty oil pump or worn gaskets that will no longer prevent the oil from staying in place in the engine. Is this light accompanied by a check engine light. If so what is the code. You may also have a faulty oil sensor. Hope this helps
SOURCE: Low Oil pressure light in idle at stop
Depending on the amount of miles, maintenance records, or how hard the car has been driven either by a previous owner, or by yourself. The engine's main crankshaft bearings or the connecting-rod bearings could be excessively worn.
Also, it could very well be a wiring problem to the sensor and/or computer causing the problem.
SOURCE: Low Oil Pressure on 1992 Chevy 1500 Pickup Truck
1992 silverado pickup has a problem with the oil pressure Gage on the dash board fluctuate when i put break on or accelerate the gas
SOURCE: Fluctuating oil pressure gauge.
Two quarts is about half the capacity. The pump was probably starved of lubrication and is failing.
If that's not expensive enough, you may now have a problem with a damaged engine. You may want to just put that money into a new vehicle.
I don't think the car would have enough power in its present condition to get high enough to reach a cliff, and driving it into a lake would not be environmentally sound. Besides, the fine would not be worth it.
The cheapest and easiest maintainance that anyone can do on a car to avoid expensive repairs is still checking the oil ever 1000 miles (filling if necessary!) and changing it every 3000.
SOURCE: OIL PRESSUE LOW
At some point, your engine is registering low oil pressure and warning you the oil pressure is insufficient to lubricate the engine properly.
How does the engine know this? What causes it? Excellent questions. The engine 'knows' this because there is one or more sensors that read the oil pressure all the time. The sensors report to the computer which reports to you. They could be faulty. On the other hand, there could be times when oil pressure IS low. Your oil pump may be mal-functioning. Normally, I would expect the oil pump to either do its job properly or NOT do it properly but not act intermittently. It may warrant being checked by a professional. Another reason for this condition could be the oil itself, though you report you just had it changed. Presumably, whom ever did the change put in the proper oil grade, service and weight, recommended by GM.
Another thought, is this warning seen by you immediately after you start the car? If yes, it is normal for oil to take a second or two to build the proper pressure, particularly in cold weather. Where I am at, it is cold. Oil doesn't like to move when it is cold (like me) so it takes a bit of time to get up pressure (like me).
If this continues, you may want to have this problem looked at by a professional, as I said.
Thanks for your interest in FixYa.com
