Question about Alesis 16 Bit Stereo Drum Machine System
Backup user patterns for Alesis SR16 drum machine to pc
Is special software required in order to back up Alesis SR16 Drum machine programs on to a pc
    Problem Solver:
  • 7 Answers
Some harddisk recording/PC based recording programs recognize "Midi Bulk Dump"
I use Alesis Data Disc for all midi backup from synths and drum machine. This is a one unit rack module you can get for som few dollars.. ;)
Alternative check out download.com with "midi" as search word.
Posted on Aug 24, 2009
    New Friend:
All you need is a cable with a mono miniature jack plug at each end. One end goes into the SR16 and the other into a cassette, minidisc recorder, whatever you will record the back/up stream to. A bit like old PCs ... Ataris. Commodores etc., you effectively make an audio recording of stream of data ... it sounds a bit like hearing a fax transmission or modem connection over a phone line.
So first, you make a recording of your existing SR16's patterns, drum kits etc.. Before you change the patterns, check your back up is OK by playing it back into the SR16. In my experience, the SR16 likes a pretty "hot" signal so don't worry if it's a bit "loud". Make a note of the settings that work.
Once you know the back up of your SR16's data is OK and you can return your SR16 to its original state, start messing around or buy patterns online from sites like this www.1borneveryminute.com/AlesisSR16CustomPatternSet1.htm where you'll also find samples of what's possible with the SR16, some free patterns and technical details. There's also loads of other references to the SR16 on the web. I use the above option simply because pretty much everyone has something that records audio which, along with the cable, is all you need.
Posted on Jan 13, 2016
How do I reinstall preset patterns
According to the Alesis SR16 Frequently Asked Question section: Power On while holding down Erase and Play. http://alesis.com/sr16
Feb 15, 2015 | Alesis Sr 16 Stereo Drum Machine
Can alesis sr16 be reprogrammed with computer
You can read everything on the alesis-site, but don't expect to much
from it's sound quality and options.... Nice in the 90's, but nowadays you buy apps which way heavier beats and options. Gr richard
Sep 25, 2014 | Alesis SR16 Stereo Drum Machine
Connected alesis sr16 with alesis 110v power supply.to 240v mains...........briefly powered up and then nothing. Have I "fried" the adapter or the sr16?
Look carefully at the adaptor and see if it takes any voltage besides 110 (it will say in very tiny print, you will need a magnifying glass). if it does NOT say 220V or 240V then you friend the adaptor. Get another adaptor - most are "dual" voltage meaning they run in the U.S. or overseas.
Also check for "polarity" (which part of your plug is + or - ).
Jan 24, 2013 | Alesis Sr 16 Stereo Drum Machine
I have an Alesis SR16 drum machine. It fires up ok and you can select a drum pattern, but the output is barely audible. Only by bringing the volume on the machine and the amp right up can you hear anything...
What power adapter do you have on this? This one REQUIRES and AC input, NOT a DC adapter !!! Many people try DC adapters on these because they lose the original and ALL fail. You need a 9VAC at 830ma or more adapter. If you have lost yours, search for "SR16 power adapter" to find replacement.
Apr 27, 2011 | Alesis Sr 16 Stereo Drum Machine
Drum sound distorted
Try a factory reset:
alesissr16logo53x41.jpgrmidialesissr16logo53x41.gif Performing a 'Reset' on your Sr16 will will 'clear' it's memory and re-initialize all of it's parameters to the original factory settings. This implies that:
  • All of your User Patterns will be erased.
  • All Songs will be erased.
  • All drum assignments you have made will be erased.
  • None of the above actions should be an issue to you as:
  • It is assumed that at some point you have Download And Save A Copy Of The Sr16's Current State.
  • It is assumed that at some point you have Export any 'User' Patterns you may have programed into your Sr16 and imported them into your _rMidi installation.
  • It is assumed that at some point you have Export any 'User' Kits you may have programed into your Sr16 and imported them into your _rMidi installation.
  • Perform The Reset
    To perform a 'Reset' on your Sr16:
  • Turn the pwer off and wait a few seconds.
  • Press and hold the PLAY and ERASE buttons while turning in the power.
  • Continue holding down these buttons for at least three seconds after turning on the power.
  • If this doesn't fix it, check power adapter. If that is OK then service is required
    Jun 06, 2010 | Alesis Sr 16 Stereo Drum Machine
    I can't find a rotary pot for alesis sr16
    Try WD Greenhill.com. They were really helpful when I've needed hard to find parts for synthesizers. Let me know if this helps.
    Jan 18, 2010 | Alesis Sr 16 Stereo Drum Machine
    How can I put a walz beat in the Alesis
    Page 59 Odd time signatures of the owners manual explains how to do this. Type Alesis SR16 manual into Google and you can download a copy from media.zzsounds.com Please rate this if it helps. You can also download documentation here:http://www.alesis.com/sr16 under DOCS and Downloads
    Oct 29, 2009 | Alesis Sr 16 Stereo Drum Machine
    I need to find the instuction manual for an Alesis SR-16 drum machine. I was told that it is available for free on line. Where?
    Go to alesis.com/sr16 the reference manuel, program chart etc. are all there. I just went there to double checkit and it is there.
    Aug 31, 2009 | Alesis Sr 16 Stereo Drum Machine
    Alesis 16 Bit Stereo Drum Machine System Logo
    1,478 people viewed this question
    Top Alesis Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Ben Armstrong
    Gil Shultz
    Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
