Bowed vertical edges on screen
I picked up a LG CT-29K30E TV it was working fine, then I put it in the car and drove for an hour and a half with it on the backseat.
Got home turned it on and the right and left edges of the screen are curved inward about an inch or so.
I didn't bump the TV whilst moving it and I have gone through the user manual to be sure it is not set to wide screen and to make sure all the settings are correct.
My dad gave me the TV and he has never had a problem with it.
I hope you can help,
Thank you in advance
Chad
  • 4,234 Answers
This is a problem with the pincushoin circuit, most likely a bqd capacitor. I don't have service information for your specific model, but a service shp shouldbe able to resolve this cheaply. It is possible that there are poor solder connections inside the set that the move may have aggrivated as well. If the set is no longer under warranty and you can solder, try resoldering any connections on the board that appear grainy or have rings. Please note that there are potentially dangerous high voltages present inside hte set even when unplugged.
Please keep us posted on your progres.
Dan
Posted on Feb 18, 2009
Horizontal lines across TV screen Pansonic CT 35g25
Check its vertical output section circuit for any component damage or loose soldering terminals. Check the solder terminals of the vertical output IC. Resolder all the suspected solder terminals by applying al little more fresh solder, without making any solder bridge short in between adjacent solder terminals.
If this do not help you, replace the vertical output IC. Lose of Vertical Scan is the problem of your TV.
Aug 04, 2012 | Panasonic CT-35G25 TV
Display problem after bulb change
the vertical display IC must have gone..
you need to replace it
Jun 01, 2008 | Optoma HD70 DLP Projector
LG plasma 50 inch tv with a fine vertical black line in the center of the screen that runs from the top of the screen to the bottom
Try changing the input device to something you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | LG 50PG20 50 in. Plasma HDTV
Hi, My Samsung UE46C8000 is suddenly showing left half of the screen fine, right half is simply colourful blurry vertical lines. After about 3 seconds the TV then restarts itself, but the problem...
if you have this tv connected to the internet try and see if it needs updating. it also could be the pip settinmg picking up an air signal instead of a cable channel.
Jun 25, 2011 | Televison & Video
Our tv, a Panasonic # CT-36D11E/CT-36D11 only shows a horizontal thin line across the screen. The sound is fine - any ideas? Is it time to replace or could it be repaired cheaply?
Resolder the vertical IC and replace those capacitors near and next to your vertical IC. If the horizontal line still appears, you may have to replace the IC. Thanks for asking and be caredful!
Jun 18, 2010 | Panasonic CT-36D11 36" TV
NO PICTURE
Turned the Tv seton had only half a screen tried to used the remote to reset the set to is regular settings it reset but the picture was offset to the right of the right of the screen I the brought up the menu in hopes of using the vertical or horizontal to bring it back full screen and the remote stop functioning for the tv and i put new batteries in it thinking matbe the remote was down but to no avail it still didnot work I had to unplug thr tv for about an hour and plug it back up for the remte to work and still had only a half of sreen and now i have sound and no picture just a green screen
Nov 15, 2008 | Televison & Video
Philips plasma tv vertical black stripe
Hi
If there is no picture behind the stripe and the edges are well-defined, then one of the display driver ICs has failed. Philips displays can be made by several manufacturers - usually Samsung. The ICs are bonded to the flexible ribbon in most cases, and replacement is an expensive specialist job - and in many cases is simply not possible.
A shadow on the picture is much better - usually due to interference.
Glyn
Jul 22, 2008 | Televison & Video
Half Screen has colored lines, Half screen is working ok
there is a defected capacitor in the vertical circuit trouble shoot and replace. or if the vertical circuit is separate then replace the whole board.good luck
Jul 11, 2008 | LG 42PX5D 42 in. Plasma HDTV
LG TV CT-29K30E
Possible reason is TV CH button might have stuck. Try to exercise the CH buttons on TV side and release them.
Hope it will help
Dec 29, 2007 | Televison & Video
Weird problem not convergence
Mine is doing the exact same thing! have you found a fix yet?
Apr 23, 2007 | JVC AV-48WP74 48" Rear Projection...
Televison & Video Logo
114 people viewed this question
Top Televison & Video Experts
Electro Med Services...
