Question about Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC
My system cd drive is not working while inserting the R/W disk...and also regedit is also not working i need immediate result help me please!!!!!!!!!!!!!!!!!!!!
    Guru:
  • 832 Answers
Hello there!!
I suggest that you should first try using other brands of CD/DVD -RW and if still doesn't work, check your CD/DVD drive/player from your laptop or pc. And you can buy a new set. (more practical)
Thanks! Cheers!
Pls don't forget to mark!
Posted on Feb 18, 2009
I put a game in and the syestem says insert game disk. i put the game in and it says cd is being checked and the same thing happens
Sounds like the optical drive/CD reader has failed on the system especially if it turns out the same result regardless of the disk you've inserted. It looks like you'll have to buy a replacement optical drive or buy a completely new system. If you're only trying the one disk, it may just need cleaning or replacing.
Apr 26, 2013 | Sega Dreamcast Console
The files for my CD/DVD drive seem to some how disappear and now my computer does not do anything when I insert a disk in the drive. How can I get to work again
Hi! Your system won't detect media disc that was inserted on your optical drive - that was the problem. You actually need to delete your upper and/or upper filters to resolve this. all you need to do is to click on start - then run - type REGEDIT and press enter, a window will appear. all you need to do is to follow this address to look for the upper and lower filters: HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318} inside of this folder delete upper and/or lower filters.
Restart system and that should make your system read your CD media files. Thanks for visiting FixYa.com!
Jun 04, 2010 | HP Compaq Presario F500 F700 and G6000...
How to instal file 'asms The file 'Asms' on Windows XP Professional Service Pack 2 CD is needed" when installing WinXP Pro,
When you install Microsoft Windows XP, you may receive the following error message:
[Files Needed]
The file 'Asms' on Windows XP Professional CD-ROM is needed. Type the path where the file is located, and then click OK.
This issue may occur if the Setup program cannot communicate with the CD-ROM drive.
To resolve this issue, use the appropriate method for your computer.
Hard disk formatted with FAT or FAT32 file system
If the hard disk is formatted with the FAT file system or with the FAT32 file system, follow these steps:
Use a Microsoft Windows 98 Second Edition or Microsoft Windows Millennium Edition (Me) Startup disk with CD-ROM drivers to restart the computer.
Copy the Xcopy.exe tool from the Windows 98 Second Edition CD-ROM, the Windows Millennium Edition (Me) CD-ROM, or the hard disk to the Windows Startup disk. To do this, use the appropriate method.
Insert the Windows 98 Second Edition CD-ROM in the CD-ROM or DVD-ROM drive, and then at the command prompt type the following lines, pressing ENTER after you type each line, where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive:
c:
copy cd-rom:\win98\smartdrv.exe
copy cd-rom:\tools\oldmsdos\xcopy*.*
Insert the Windows Millennium Edition (Me) CD-ROM in the CD-ROM or DVD-ROM drive, at the command prompt type the following lines where cd-rom is the drive letter of the CD-ROM or DVD-ROM drive, and then press ENTER after you type each line:
c:
copy cd-rom:\win9x\smartdrv.exe
extract cd-rom:\win9x\win_17.cab xcopy.exe /L c:\ xcopy.exe
extract cd-rom:\win9x\win_17.cab xcopy32.exe /L c:\ xcopy32.exe
extract cd-rom:\win9x\win_19.cab xcopy32.mod /L c:\ xcopy32.mod
Hard disk
At the command prompt, type the following lines where drive is the drive letter of the hard disk where Windows is installed, and then press ENTER after you type each line:
c:
copy drive:\windows\smartdrv.*
copy drive:\windows\xcopy*.*
Eject the Windows 98 or Windows Millennium Edition (Me) CD-ROM, and then insert the Windows XP Professional CD-ROM.
Copy the I386 folder and all its subfolders to the hard disk. To do this, type the following lines at the command prompt where cd-rom is the drive letter of the CD-ROM drive, and drive is the drive letter of the hard disk, and then press ENTER after you type each line:
smartdrv
xcopy cd-rom:\i386 drive:\i386 /e
Restart the computer, and then start the Setup program again.
When you receive the error message, click Browse, and then type the path of the I386 folder on the hard disk.
Note You may be prompted several times for the location of this folder. If Browse is not available, see the "Hard disk formatted with NTFS file system" section.
If the hard disk is formatted with the NTFS file system and you are upgrading an earlier version of Windows, use one of the following methods.
Method 1
Important This section, method, or task contains steps that tell you how to modify the registry. However, serious problems might occur if you modify the registry incorrectly. Therefore, make sure that you follow these steps carefully. For added protection, back up the registry before you modify it. Then, you can restore the registry if a problem occurs. For more information about how to back up and restore the registry, click the following article number to view the article in the Microsoft Knowledge Base:
322756 (http://support.microsoft.com/kb/322756/ ) How to back up and restore the registry in Windows
When you receive the error message, press SHIFT+F10 to start a command session.
Type regedit.exe, and then press ENTER.
Click HKEY_LOCAL_MACHINE.
On the File menu, click Load Hive, and then load %Windir%\System32\Config\System.sav.
When you are prompted to specify a name, type Test.
Locate and then click the following key:
HKEY_LOCAL_MACHINE\Test\ControlSet1\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
Delete the UPPERFILTERS and LOWERFILTERS registry keys.
Repeat steps 6 and 7 for the other ControlSet# keys under the Test hive.
Click File, and then click Exit to quit Registry Editor.
If the path in the error message is the correct drive letter for the CD-ROM drive, click OK to continue the Setup program.
If you receive the error message again, the Setup program cannot correctly read from the CD-ROM drive, or the path information is incorrect. In this case, restart your computer and let the Setup program resume.
Method 2
If you cannot start Regedit.exe at the command prompt, and there is another available partition where you can install Windows on the hard disk, follow these steps:
Install Windows in the other partition.
Start the new installation of Windows, and then start Regedit.exe.
Follow the steps in method 1, but load the System.sav hive from the original Windows folder.
Method 3
If you are not using a retail Windows XP CD-ROM with a hologram (for example, if you are using a burned CD-ROM), try to run the Setup program from a retail CD-ROM with a hologram. To verify this, start the computer by using Recovery Console, and then check the C:\$win_nt$.~ls folder. Look for the Asms folder. If the folder is missing or the files that it contains are zero bytes, the CD-ROM was not burned correctly.
For additional information about how to use Recovery Console, click the following article number to view the article in the Microsoft Knowledge Base:
307654 (http://support.microsoft.com/kb/307654/ ) HOW TO: Install and use the Recovery Console in Windows XP
Apr 27, 2010 | Microsoft Windows XP Professional With...
Neither of my CD rom drives are working in my E310 Dell dimension desktop, they stopeed working quite sometime ago. I never used them much other than installing some programs on the machine when I first...
Start by going to (I'm assuming Windows XP) My Computer->Manage and then selecting Device Manager Under DVD/CD Rom devices, see if you have any yellow exclamation marks. We need to make sure all of your devices are "seen" by the system and that the drivers for them are installed.
Note: DELL usually has their own drivers, so you would need to go to the DELL support site and get them. I would recommend doing this to start and get everything up to date.
Mar 28, 2010 | Dell Dimension E310 PC Desktop
Drive reports no disk even though a disk is inserted?
Does it do this with all disks - or just one?
If it is all disks, your drive is probably died or dying, if it is jjust one disk, then it could be the disk is faulty.
If it is a blank disk, it could be the wrong format - R instead of a +R, or vice a versa,
If it is only one disk and it is a data disk try using this to recover the data.
If this helped you then please help me by voting kindly, thank you.
Oct 16, 2009 | Computers & Internet
Windows XP , system goes to sleep immediately after booting.
CHANGE THE CD OS IF YOU HAVE ANY AVAILABLE SOME FILE NEEDED IF YOU KNOW HOW LOCATE THAT FILE DOES'NT MATTER BUT THE PROBLEM IS YOU DONT KNOW HOW LOCATE..
PROBLEM FROM THE CD INSTALLER
Jun 25, 2009 | Microsoft Windows XP Professional
Disk boot failure insert system disk
Is it recognises Hard disk or not?
reply
i will try to solve u r problem
Jun 25, 2009 | ASUS K8V-MX Motherboard
Toshiba sd-r2002 - won't recognize blank CD when trying to write files to a CD
right click on the drive.... go to properties... under tab recording, remove tick "enable CD recording on this drive" and press apply... after that tick "enable CD recording on this drive" and press OK.
It should work.
Jun 01, 2009 | Toshiba SD R2002 CD-RW/DVD-ROM Burner
Dvd RW driver (E:)
Thereis a standard cd/dvd registry fix you can try , go to start menu and type regedit to enter the system registry. go to registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} an delete the upper and lower filters enties on the right side of the screen. close registry edit and reboot you system and you should have your drive back . given its not the drive itself( hopfuly it power up, and spins a cd)
Jan 19, 2009 | HP Compaq nx6310 Notebook
Can't find DVD drive under My Computer and regedit fix doesn't work for it
you may have to check the registry manually and if this will not work, you may have to reinstall windows.
1. click start > run > regedit > ok.
2. In Registry Editor, expand the following registry path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class
3. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}.
4. Delete Upper and Lower Filters. (If only one is availabel, that's fine).
5. Restart system and check your drive again.
NOTE: Make sure to do this correctly or else, system will not load to windows.
If manually deleting upper and lower filters will not work then you may have to backup your files and reinstall windows.
Aug 26, 2008 | Toshiba Satellite A70 Notebook
Microsoft Windows XP Professional With Servise Pack 2 (e8503040) for PC Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
