Question about Home
Small hairline sized crack on top edge of a white Franke sink - is there anything I can use to cover this? Resin? Plastic?
  • 547 Answers
Silicone or replace it
Posted on Feb 19, 2009
I have a Franke double bowl deep drop-in sink that I have already replaced once. The problem is that the bowls do not stay in the frame. One rise us up out of the frame with a sharp edge. What is going...
Assuming your table is level and even, is the bowl itself even also. Check it for even thickness throughout the whole edge that sits on the table top. If that is even also, then you may have to cut part of the table that the bowl sits in so that it will allow the entire sink to sit flat.
Feb 22, 2013 | Franke Drop-On Single Bowl Kitchen Sink ...
We bought a Franke top mount sink and go system from Lowes. It is being installed in a standard formica countertop. The clips that came with the unit will not stay on for anything when you attempt to...
Is the Foot print of the replacement maybe sink smaller than the foot print of the orginal sink that was replaced? It sounds like it is. Make the hole smaller by cutting a plywood strip to be placed on two sides of the sink hole. Long side at back of sink and short side. (plywood needs to be marine type because of the high mosture of the sink area and painted)
I went to their web site; they have posted a buyer beware notice of bad contractors. They may be able to help.
info@frankekitchensinks.com
Nov 27, 2010 | Franke Home
Difference between black basket strainer 900 and regular strainer.also i want white. are there different sizes or universal.
Unless you have a special purpose sink all basket strainers are standard size. You should be able to use strainer from any manufacturer that has the color that you want. If you are doing this yourself make sure you use rubber gasket and fiber friction ring. These go on the underside of sink in between sink bottom and retaing nut. I would recommend you use a small amount of pure silicone caulking in between flange of strainer and sink surface. Be ready to wipe off excess caulking as soon as you get retaing nut snug as it starts to cure in about ten mins. I use paper towels and wipe till its clean. Hope this helps. Thanks
Nov 16, 2010 | Franke 900 Black Basket Strainer 900
We cannot get the mounting clips to stay on
I have spent several hours trying to solve the same problem with a Franke Granite double basin sink. The clips for this Franke sink appear to be a piece of engineering garbage, and the instructions are utterly useless - A huge piece of paper with a template, and tiny pictures that look like they were drawn by a kindergartner with a crayon. The instructions for using the clips --oh there are none - other than a blurry picture in which the clips could fit inside this period (.). Lots of other people appear to have the same issue. I like the Franke sink, but without proper mounting hardware, this franke sink is no better than the poorly made clips, and the Franke Sink horrible instructions that it came with.
May 02, 2010 | Franke Work Top Double Bowl Kitchen Sink...
I Have a FRANKE Fireclay white Farm sink only 90
E-mail the manufacturer from this page.
http://www.frankekitchensinks.com/link_to_us.htm
Sep 04, 2009 | Franke Plumbing
Fixing a franke sink
Turn sink upside down on paper/cardboard & trace around outside. . Measure from outer edge of unit to just beyond inner edge [where the clips fit] transfer this to cutout and mark/cut on this inner line. This is not your template to cut out the worktop.
Push the clips over the inner ridge on the underside until they click into place.on small cutouts make sure the worktop grips face outwards.
place into worktop cutout - most likely there will be some more worktop to trim to fit. When fitting easily, fit the seal on the underside where the sink fits into the worktop & screw up the clips until they bite into the underside of the worktop.
Not got the seal? use silicone [clear]
Aug 31, 2009 | Home
Bowl dropped in Swanstone sink caused a Y shaped crack, through.
that is a lot of work...why not just replace the sink?
Mar 26, 2009 | Swan Home
I have a brown colored stain in the bottom of my white franke white fireclay sink (maybe coffee stain, not sure) I can't get it clean with regular hand soap which is what franke told me to clean the sink...
I used Cerama Bryte for the dark colored stain, I left it on for about 5 minutes and then rubbed it clean, the stain is gone. Now I tried it on the small aluminum scratch marks, no thank you, it couldn't help that problem. Still seeking a solution. Thanks
Mar 02, 2009 | Herbeau Creations HERBEAU "Luberon" Art...
I need a new franke sink basket strainer for my franke sink model PRX11021 - stainless steel. What is the model number that will fit this sink and can I order it online or go to a local store?
You should purchase a complete basket strainer assembly. Home Depot or Lowes have some very nice ones. They are a standard size.
Tell them it's for your kitchen sink.
Jan 28, 2009 | Plumbing
Home Logo
265 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
