I recently purchased a Sony DAV-DX255 home theater system and wanted to be able to replace their subwoofer with 4 aura 25-watt, 4-ohm transducers. According to the specs, the subwoofer output was rated at ~285 watts @ 3-4 ohms, which I thought would be plenty to drive the transducers. Either I am misunderstanding the specs, or they are highly overrated as the output from the receiver is barely enough to drive one transducer! So I am looking for an alternative way to hook up the transducers. I figured I would get an amp specifically to drive the transducers, but there are NO audio out's on the Sony system! The only audio output is via the speaker outs. (Well, there is a headphone jack, but using this disables the speakers, so it does not count.)
Specs are here, if needed:
Is there a way to take the audio signal from the speaker output and boost it so that it can drive the transducers? Does anyone know what product will do this?
Show your appreciation by commenting on Boost signal strength to transducers?:
Solution #2
posted on Aug 01, 2007
Gary10 - usenet poster
Rank: Apprentice Rating: 0%, 0 votes
After purchasing the unit, I did some research on that "10% THD" and found that such high distortion firgures are used in able to inflat the advertised wattage output. I have certainly learned a lot from this venture!
Which is probably this low-end Sony.
I did read many reviews where people said that the volume level was not great, but I wasn't going for something the neighbors could hear, so thought I would be fine with that. The sound quality is so-so. What I forgot to factor in was that if people were complaining about low sound output, then this probably mean something that could not drive the transducers!
I looked at them at Parts Express, but at this point am opting for:
I ordered the hi/lo adaptor and an amp and we shall see how it goes!
Thanks for your feedback.
Dave
Was this solution helpful? Show your Appreciation by rating it:
Solution #3
Jimmy NY - usenet poster
Dave <dave@_NO_SPAM_risingfire.net
Hi Dave: To say that these specs are an overrating is an understatement. This spec alone is a clue: 285W (1KHz 10%THD), This is to say that the amplifier unit for the sub can produce 1 kilohertz (annoying midrange tone) of sound at 10 percent distortion and hit 285 watts.What Sony does not tell you is what is the "usable" power of this amplifier. It takes a lot of power to produce 80 hertz of sound at a decent level. Most cheap subwoofers use 100 watt MOSFET amplifiers and good units use 250 watts plus. This means that the amplifier will produce 80 hertz of sound (at a decent level) with limited distortion. The sub amp I use is rated at 300 watts from 22 hertz to 22 kilo hertz at 1% distortion. This means solid clean power at any low frequency. I tried to find what many call "usable" power ratings for your unit and could not. I did find many folks who did not like the power of the unit. What you will need is a "Plate" amplifier to drive your transducers. If you are running stereo subs then you will need two of these units. Alternately you could use a stereo amp and a Hi/Lo impedance adaptor. This unit will hook up to the sub output and give you a RCA style output jack and level. These are often used in car systems to create a line level output for an additional amplifier. I have a unit from Pyramid called a NS 60 that does the trick. You can then safely power your speakers with the output of the external amps. You are not alone with this problem Dave as many people are wowed by the 1000 watt spec which is a farce to say the least. 1000 watts of sound power in a decent speaker at 1 kilohertz would kill an invading army unfortunately it means nothing when it comes to true power and home theater.
Mrsee.
