Question about Dell 0Y3740 Keyboard
One of my letter keys is not working!!!!
The key in between Y and I is not working, My laptop is not old any tips on how to resolve the problem is appreciated.
Regards
Ash
  • ss1987 Mar 20, 2009
    One of my keys with the 'greater than' and 'less than' symbols doesn't work, instead of those symbols appearing when I type, I get these symbols - (`) and (~) with the Shift key.
    Please help. I have a Dell Inspiron 1525 laptop - less than 3 months old.
  • 1,602 Answers
You may have to disassemible the keyboard and cleaned the leads or switchs, or contacts with some alcohal and non lent cloth.
re-assemible the keyboard and spray a can of compressed air threw the keypad to remove any type of mterail that may stop the key from making any contact with the contact switch.
you will have to do both of these steps to rule out a bad key and have to replace the whole keyboard.
there is a company that sells labtop service manuals for repairing and fixing and assemible and dis assemible os any type of labtop you could every think of and the web site is called:
www.9manuals.com
rodgandysr
Posted on Mar 07, 2009
Have a Gateway M285e laptop that the letter 'e' on the keyboard doesn't function. Will cleaning the keyboard resolve this issue? Thanks
It is possible that there is something sticky keeping the "e" key form working. Removing the key and cleaning around it carefully with alcohol or alcohol water 50/50 or 100% mix might free it up. Use Que-tips or something like that. try to clean around it first. If that does not work try gently lifting up on the key with a small screw driver or knife. You may hear a small pop. this could go either way for you good or bad, so be car full. then try cleaning around the spot ware the key was, gently replace the key.
You may also consider plugging in a cheep $10.00 key board and see if this works. I spilled a large drink in min and needed to use an auxiliary key board until I replaced the computer.
Apr 12, 2015 | Gateway Computers & Internet
Keyboard won't work
When a keyboard stops working, has odd key letters, stuck keys and non-functioning keys for no reason at all, the laptop may have an easy fix solution. However, if liquid spilled on the laptop or the laptop was dropped and as, a consequence, the keyboard doesn't work, or the keyboard device has simply failed, fixing the problem may require a more involved laptop keyboard replacement.
Click start control panel keyboard hardware make sure you have the right keyboard selected or you might have uninstall the keyboard then restart your computer then reinstall it and its drivers Click start control panel administrative tools computer management device manager scroll to keyboard you might see a yellow question /exclamation mark ? ! or a red X right click update driver if your computer came with a motherboard disk the drivers could be on it. If its still not working Tap the "Alt" and "Shift" keys simultaneously if you are pressing one keyboard key and getting a different symbol or letter. This will reset the keyboard defaults on some laptops. Press the "Ctrl" key and tap the "Shift" key simultaneously if the procedure in Step 1 did not work. Press the "Fn" and one of the "F" keys to disable the "Num Lock." Different laptops use different "F" keys to disable the "Num Lock." Toggle each "F" key and press the "Fn" key at the same time to find the right key combination. Check your laptop manual to find the right key combination. Press the "Fn" key and the blue "NumLock" key simultaneously if the keyboard is typing numbers instead of letters or wrong letter keys and the above steps did not solve the problem. b> Keyboard Maintenance b> Blow compressed air in the cracks and crevices of the laptop keyboard. Sometimes dust and debris can cause keys to lock, making such keys non-functional. Disconnect the laptop from the power outlet and remove the battery. Make the tip of a cotton swab as thin as possible by rolling it between your finger tips. Dip the thinned cotton swab in rubbing alcohol and clean the crevices of the keyboard with the cotton swab. Continue cleaning between each key of the keyboard with the alcohol-dipped cotton swab. Use a new cotton swab whenever necessary. Slightly tip up one side of the laptop so dust will move from under the keys to the crevices so you can clean. Blow compressed air into the keyboard again as you did in Step 1 of Section 2. Reconnect the computer to the power and check to see if the issue is resolved. Insert the flat edge of a flat-blade precision screwdriver under a keyboard key and gently pry it up and off. Remember where the keys go, so you can easily replace them. Remove three keys at a time and clean with a cotton swab dipped in alcohol. Replace the keys and remove the next three. Do this until the entire keyboard has been cleaned. Disconnect the laptop from the power outlet and remove the battery again. Turn the computer so the rear is facing you. Remove the screws that hold the plastic hinges in place. Insert a small flat-blade precision screwdriver in the plastic hinge seam and pry the hinges up. Turn the computer back face forward and open the screen as far back as it will go. Continue lifting the plastic hinge and power plate until it comes off. Remove the screws you see holding the keyboard with a precision Phillips screwdriver. Blow compressed air under the keyboard. Lift the cable connector levers slightly and remove the data cable. Clean the cable pins with an alcohol-dipped cotton swab. Replace everything, power on the computer and try the keyboard again to see if the issue is resolved. b> Keyboard Replacement b> Connect an external keyboard to the USB port on the laptop and verify its working condition. Disconnect the external keyboard and verify that the keys on the laptop are still inoperable. Disconnect the laptop from the power outlet and remove the battery. Remove the laptop keyboard as you did in Step 3 of Section 2 by removing the plastic hinge and power button plate, the keyboard screws and disconnecting the data cable from the motherboard connector. Replace the keyboard with a new laptop keyboard for your laptop make and model.
Jan 15, 2013 | Lenovo b560 Notebook
My keyboard wont type
Restore a Laptop Keyboard b> When a keyboard stops working, has odd key letters, stuck keys and non-functioning keys for no reason at all, the laptop may have an easy fix solution. However, if liquid spilled on the laptop or the laptop was dropped and as, a consequence, the keyboard doesn't work, or the keyboard device has simply failed, fixing the problem may require a more involved laptop keyboard replacement.
b>
Jan 11, 2013 | Samsung N145 Plus 10.1 inch Netbook -...
The letter 'r' and 't' has come off our laptop how do I put them back on?
The keys on the modern day laptop as placed on hinges, and that's how they keep coming up when we press them down.
The problem is, if the keys come out of the keyboard, then we need to check whether that hinge is broken or not. If it's broken, then you need to contact your local Computer Engineer who can fix this for you, as helping you in this medium won't resolve the issue.
If it's not broken, then I would suggest you to carefully see how the mechanism of the keyboard is on your laptop, and place the hinge back on the keyboard.
One more small tip, if neither of them works, then use some permanent glue and try to stick the keys on the keyboard. Though I would recommend this only as a last resort.
Let me know how it goes.
-Pragith
Mar 11, 2011 | Acer Computers & Internet
Mac laptop keys are not showing letters but symbols and delete key not working. How do I unlock this problem?
There could be a couple of possibilities :-
1. Faulty keypad
2. IC on the main board
Faulty keyboard is more often a problem. Even though there is no dust and dirt, faulty keyboard may result in all the above said symptoms.If you press a letter key, a symbol might be there. If you press delete key, it might not work. The best option what i follow in my shop is replacement of keyboard. There are certain days when i only replace few keys, but more often if this is a problem with more than 5 keys or with all the keys on the notebook, better to go for a new keyboard.For your laptop, always prefer hard keys as those are more durable than the soft keys.
IC on the notebook is again one of the reasons. This is usually a problem with old laptops, such as 5 to 7 years old. New laptops generally do not have this problem. If laptop IC is at fault, soldering is required to get it fixed.It needs a tech to confirm the faulty IC on the mainboard and then followed by replacement.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 03, 2010 | Computers & Internet
When i type a-key on the keyboard then a1 appears on the screen in Dell inspiron 1525 laptop,please assist me to get resolve this problem
Most likely you have your numlock key turned on by mistake. Look on your computer and see if there is a light with a padlock and a number in the padlock. It is probably lit up. Now look for a key on your keyboard called "numlock" and press the key once. See if the light goes off. When you have the numlock key on some of the letter keys will work as numbers like a calculator. When you turn it off the keys are back to letters.
Dec 22, 2009 | Dell F3534 Touchpad
Letters are num locked. pushing num lock key does not resolve
Number lock, a situation where numbers instead of letters are typed is as a result of the digital lock being active. to deactivate pressing the Fn+Numlk or Fn + Shift +Numlk key combinatioins
Jun 18, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
The letter d sticks on my gateway laptop. I use air can..clean it with alcohol swabs. Its relatively new kp..about 8 monyhs old
You should be able to pop off the key and then see if the problem in in the key mechanics or with the pad itself. Either way, using alcohol swabs could fix the problem.
Jun 12, 2009 | Gateway 2520915 Keyboard
Letter
The letter "H" on your keyboard got stuck and it's like pressed down all the time. You can pop out the key then clean it. If the issue is resolved, you should not hear the beeping sound anymore when you boot up the unit. Or better yet, if your under warranty, contact Toshiba, 1-800-457-7777 and they'll be blad to repair your keyboard.
Hope this helps.
Sep 16, 2008 | Toshiba Satellite A135-S4527 Notebook
Dell 0Y3740 Keyboard Logo
989 people viewed this question
Alun Cox
