Question about Transcend (589307) Media
I dont think that the registry fix would do the trick. i also have the same problem. i have several pc's here. the pen drive is write protected in all the pc's ive tried. badly there is no switch on the sides or in any part of the pen drive. can anyone has a proper solution for this?
    Scholar:
  • 77 Answers
You might have some kind of virus on all those PCs. You can try booting in to safe mode and try to access the pen drive and writing to it (try creatign a new folder etc)
You can still try the registry trick but use this software instead:
http://www.gaijin.at/getit.php?id=usbwp
(You will need winrar to uncompress it, get it from http://www.rarlabs.com)
Unrar the usbwp.rar and double click USBWriteProtect.exe and disable the write protect, close the program. Then unplug your usb drive and again insert it. Now you should be able to write to it.
HTH,
Deboo
Posted on Feb 19, 2009
How to remove write protection
To remove write protection:
Open Start Menu >> Run, type regedit and press Enter. This will open the registry editor.
Navigate to the following path:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevicePolicies
Double click the key WriteProtect in the right pane and set the value to 0
In the Data Value Box, press OK
Exit Registry, restart your computer and then re-connect your USB pen drive to your computer.
Jan 04, 2014 | Electronics - Others
How to remove write-protection
Write Protection on any portable USB Device can be applied by the physical lock provided on the card adjuster or some times provided on the pen drives, so make sure to make your drive not write protected by moving the lock in right direction.
But even after moving the physical lock for write protection the problem can happen due to some virus action. This happens when some virus or script which applies the registry hack to make any drive write protect when connected to the computer, In that case follow the procedure below to remove write protection from your pen drive.
1. Open Start Menu >> Run, type regedit and press Enter, this will open the registry editor.
2. Navigate to the following path:
Note: If the registry key StorageDevicePolicies key does not exist, you will need to create it
Sep 21, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Pendrive Transcend 8GB JFV10 error message "Disk is Write Protected"
First
Download this batch file called add.bat from here, and double click after download the key will be automatically added to registry.
3. Double click the key WriteProtect in the right pane and set the value to 0 in the Value Data Box and press OK button
4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
However if that does not solve your problem try this
Think this write protection error is due to some virus.
Steps to remove write protection for Transcend users
1) Go to download center of the transcend,here is the link
http://www.transcendusa.com/Support/DLCenter
Type the model no. or part of model number you are looking for.
example: JFV30(all alphabets in Caps )
2) Choose other details like product type etc. and search for your product
3)Then select the product which which is most similar to yours from search results
4)Then download the mFormat utility. You will asked for serial no. if you dont have..enter this no. 1456784523
5) Connect your pen drive
6) run the mformat utility and select full format after full format your write protection will be removed. try twice or thrice if you can't correct at first time.
Thats all...
Jun 24, 2011 | Transcend (589307) Media
The pen drive indicates write protected and does not allow to write new files.
Three possible sources for this problem, and three separate solutions.
The following procedures assume your flash drive is assigned by MSDOS to drive E:
PROBLEM 1: Pen drive write-protect switch set
SOLUTION: move the tiny switch on the pen drive from the icon of a padlock locked
toward the icon of a padlock unlocked
PROBLEM 2: MSDOS attribute set incorrectly on any/all files on pen drive
HOW TO DISPLAY CURRENT SETTING: START > Run... > cmd
C:\> E:
E:\> attrib /S /D
HOW TO FIX WRITE-PROTECTION PROBLEM: START > Run... > cmd
C:\> E:
E:\> attrib -r /S /D
PROBLEM 3: REGISTRY set incorrectly (targeted by virus or other malware)
HOW TO DISPLAY CURRENT SETTING: START > Run...> cmd
regedit
display HKEY_LOCAL_MACHINE\System\ CurrentControlSet\Control \StorageDevicePolicies
The valid values for this are 0=Disabled (meaning READ/WRITE), and 1=Enabled (READ only)
regedit
set HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\StorageDevicePolicies
to a value of 0 (Disabled)
A fourth way to "Fix" the write-protection problem would be to reFORMAT the flash drive, but
this "solution" merely resets the ATTRIB characteristic of the top-level directory of the
flash drive (while erasing all files on the flash drive), which is done better with the ATTRIB command,
and completely fails to address the possible write-protect switch or Registry issues.
Feb 15, 2011 | Transcend (589307) Media
I JUST BROUGHT A NEW PEN DRIVE. FIRST TIME USING IT, AND THE PROBLEM ALREADY HAPPEN. IT IS WRITE PROTECTED. I ALREADY DONE EVERY POSSIBLE WAY TO GET RID THAT WRITE PROTECTED., BUT IT DIDN'T SUCCESS.. I...
Jan 11, 2011 | Kingston Combo 4GB DTI USB and 4GB...
Write production error
Jan 10, 2011 | Sony 4GB Memory Stick PRO Duo Memory Card
How to remove the overwrite protection in 8 GB pen drive?
Jan 10, 2011 | Transcend (589307) Media
I have problem in my transcend usb 8gb pandrive that i can't copy or delete any ting from pandrive. error is drive is write protected or can't format. please give solution
Jan 07, 2011 | Transcend Electronics - Others
My Kingston 4 GB Pen Drive became Write Protected.
1. Open Start Menu >> Run, type reg edit and press Enter, this will open the registry editor.
Note: If the registry key Storage Device Policies key does not exist, you will need to create it
3. Double click the key Write Protect in the right pane and set the value to 0 in the Value Data Box and press OK button
Please rate me if this solution works for you
Thanks......Have a great time
Jul 02, 2010 | Electronics - Others
Write protection on 8 gb pen drive
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); 4. Exit Registry, restart your computer and then again re-connect your USB pen drive on your computer. That is it, done.
In case you still find an issue, please leave a comment below.
Updated on 28th May 2009
After a lot of user comments telling that the above method does not work for them, we tell you another method which you can follow to solve the “Pen Drive is Write Protected” problem.
If the above method does not work for you, follow the below steps:
1. Copy all the important data from this drive to your computer because this method will format the drive and erase all the data on the pen drive.
2. Now download the Apacer Formatting Utility, Unzip this utility to a folder on your hard disk, preferably on a folder on desktop screen for easy access (Do Not Try To Save it on pen drive). Keep your pen drive plugged in, and double click on the Start.bat file in the folder where you unzipped the above utility. This will start formatting your pen drive, wait till the formatting completes and the LED on your pen drive stops blinking. Remove your pen drive after than and plug it in again.
The above two steps will solve the problem. If you still face the problem, follow the below steps:
1. Goto Start > Run, type cmd and press enter, this will open command prompt.
2. Type the following command on the command prompt replacing X with the drive letter of your pen drive.
CHKDSK X: /F
The above two methods will help you fix the problem.
Note: For all those who are out of luck in fixing the problem with their portable drives, I would suggest you to get your drives checked or replaced by the manufacturer to fix it for you
May 29, 2010 | Transcend (589307) Media
Transcend (589307) Media Logo
Top Transcend Electronics - Others Experts
laikexpert
laikexpert
Brian Sullivan
Brian Sullivan
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
