Question about MSI : MS-7061-020 VIAKM400/DDR333/A&V&L/MATX Motherboard (MOT55)
Problem com1 ps2 mous and keybord
I dont work my mous and keybord hou connect com2?
  • crisss252003 Feb 27, 2009
    yes and usb
  • Yannick Verhoog May 11, 2010
    What do you mean?
    You can't connect your mouse and keyboard?
  • 285 Answers
Well firstly I'd try another usb port...
Secondly there are loads of usb-ps2 connectors, theyre very cheap, just go to any computer store and buy 2, see if that helps.
I hope this solves your problem,
Yannick
Posted on Mar 03, 2009
Serial to usb cable wont work
try prolific usb to serial driver, check comport on you're pc if it's equall to the equipment you want to use! com1 on old pc's is the mouse, com2 was in the past the modem port, older equipment won't go further as com 2
May 09, 2014 | Canon PowerShot A560 Digital Camera
Problem with serial interface com1 in N15235
Look at your motherboards manual to see the pins.Configuration of COM's are Bauds 115.000 Bits 8 Parity N (none) Stop bits 1
as standard
Feb 07, 2012 | Foxconn 6627MA-RS2H Motherboard
I want a driver for com1 and com2 ports in the PCA-6003v motherBoard !! could u please help us ?
click start control panel administration tools computer management device manager scroll through all of your devices if you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver
you might have to expand your devices to see your com1 and com2 ports
if you can see your usb device but its not working sroll to Ports(Com&Ltd) right click to update driver
if you computer came with a motherboard disk the drivers could be on it
hope this helps
Aug 10, 2011 | Advantech PCA-6003V-00A1 Motherboard
Which port should I use for my printer: com 4 serial port com 6 serial port com 8 serial port usb virtual printer port
depends how your printer connect
if you realy are connecting an old serial printer com1 or com2 should be fine as long as you do not have a mouse or a modem on them ...
if USB any port is fine
if parralel printer you are only likely to have one...
Mar 18, 2011 | Computers & Internet
Problem with serial connection with AMD motherboard
Software that accesses serial ports usually allow you to specify WHICH port you want to connect via.
Your new board should have COM1 and possibly COM2... but perhaps your old setup was running from COM3?
Connect the Casio to COM1, and check the software you are using... set that to "look" at COM1 also. That should work!
Apr 20, 2009 | Casio Serial RS-232 Cable (CELL-300)
My Dell PowerEdge 2500 has 2 configurable com ports which are setup as Com1 IRQ-4, and Com2 IRQ-3. My problem is that everything seems to say that they are there and active, but my software only can talk...
That "in-op" COM port is in fact, probably defective. Had many cases where 1 works/1 doesn't. Buy a cheap, PCI COM port board, install the software, and plug away!
Cheers,
gurutim
Mar 19, 2009 | Dell PowerEdge 2500 Server
2 printer on 1 pc
You can buy a Usb to Centronics adapter that installs the printer as can be LPTx, and have the printers you want.
Mar 12, 2009 | Zebra Z4M Printer
Posiflex cash drawer
Ok
please type the following line as i am writing here to your commad prompt:
MODE COM1: 96, N, 8, 1
and then printer
I am sure it will work.
Thanks
Iqbal
Mar 12, 2008 | Computers & Internet
HELLO
is your mouse and keyboard plugged into a PS2 connector http://en.wikipedia.org/wiki/Image:Ps-2-ports.jpg
look inside of your case and see if any capacitors are buldging on your motherboard the tops of the capacitors should be level/flat if they're ok, sounds like they are going, look for brown rusty color also around tops of capacitors, might be your outputs are going. If you have your mouse and keyboard plugged into ps2 ports try a USB Mouse and keyboard, borrow one first or buy a usb laser mouse for $12 worth a try even if your ps2 ports are blown, use the usb ports for mouse/keys ;)
Jan 10, 2008 | Dell Dimension 4600 PC Desktop
MSI : MS-7061-020 VIAKM400/DDR333/A&V&L/MATX Motherboard (MOT55) Logo
373 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
