Question about Clarion DXZ375MP CD Player
Having Trouble Assessing Bass and Treble Controls
Ive gone through the menus a million times.. both on normal speaker settings 2way and 3way...
I can access sub control, parametric equilizer settings, time alignment whatever.. but everytime i scroll through the menus bass and treble control seems to be missing... what am I doing wrong?
  • 61 Answers
Bass and treble can be adjusted via the sound menu only when the z-enhancer is set to off.
To change them while the Z-enhancer is on (B-Boost, Excite, Impact) choose the enhancer mode, then press the play/ent button. You can then use the up/down arrows to adjust bass and treble to -3 to +3
Posted on Mar 29, 2009
How do i find out what sound card my p.c is using? i'm on windows vista, and need to change the bass and treble level ?
Most laptop sound card do not have a setting for bass and treble.
You can use external powered speakers that have bass and treble settings and connect these speakers to the headphone socket on your laptop.
Jun 26, 2012 | Computers & Internet
What are the frequencies that the bass and treble controls on a Yamaha AX-396 amplifier control? I recorded alot of music direct from the amp to my pc with the bass and treble controls at max and need to...
The bass and treble controls (as well as volume) have no effect on the recorded output if you're using the traditional jacks a tape deck would use. Only PRE-OUTS get massaged by sound controls.
Even if you DID affect the recorded signals, WHY are you using such exaggerated settings? Or was it by mistake?
In theory, passing the modified output back through the same controls (set to Minimum this time) would undo most of the unwanted effect. Assuming their precise and mirror image for gain and loss.
Aug 23, 2011 | Yamaha AX-396 Amplifier
Is there a way to mod the hd100fx head for more bass?
You are ultimately limited by the available power of the internal amp. You can set controls for bass boost and turn off the treble but there is only so much power available.
HINT: If you are using speakers smaller than 15 inch, that will limit the bass as well. Use larger efficient speakers.
Aug 04, 2010 | Marshall MG100HDFX 100-Watt Amplifier Head
My problem just came up recently. The speakers keep losing the bass and having nothing but treble coming out of the speakers. I checked all of the connections and they're all fine. This happens for about...
I just got that same problem too. Except its completely gone with the bass not coming back. I think it has to due with wiring because the speakers have not gone dead and there plugged directly into the outlet.
Dec 10, 2009 | Insignia 2.1 Speaker System (3-Piece)
How do I use the remote to cont bass & treble for rxv-657 reeiver
No, Tone controls are on the front of the unit only. If your passing video thru the unit you can go into the setup menu from the harmony and adjust all the sound parameters that way "on screen" The only "EQ" capabilities are for the Center channel only. You can adjust "speaker size". "Large" setting will give you a little lower response. "Small" will crossover the speaker at "100hz" That's about as far as tone adjustment goes on this unit. Hope this helps
Jun 30, 2009 | Yamaha RX-V657 Receiver
What duz level adjustment do
The level control controls the input level coming from your head unit (receiver) to the amp.
Your Sony users manual is a little vague on how to best adjust the level and other controls.
Here is one method that some installers use and works well with most amps.
Most 10" subs sound best between about 80-100hz and below, so start out by setting the LPF at about 80hz. The HPF will not be used. Next turn the bass boost and gain all the way down. Turn on the radio and set all tone controls, bass, midrange, treble to flat, usually "0" on most head units. Turn the volume up to approximately 3/4 volume level or just until you begin to hear distortion. Now, back the volume down until the distortion is gone. Next turn up the gain control on the amp until you hear the subs start to distort then back the gain down until the distortion disappears. Next turn the bass boost up again until the subs begin to distort, then either back the bass boost down or back the gain down until the distortion is gone. You may need to play around with the bass boost and gain controls to get exactly the sound you prefer.
Hope this helps.
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Having Trouble Accessing Bass and Treble Controls
Only parametric EQ OR Bass/Treble can be active at a time. There is a option to set which one you want, refer to manual. Follow this- Adjusting Sound Setting Mode (long press "sound-mode" button) -> EQ SELECT-> select either P. EQ or B/T
Feb 18, 2009 | Clarion DXZ785USB Car CD/ MP3 Player
Can't fine tune audio
u cannot adjust these treble and bass settings in all sound cards embedded normally when u select sound blaster audigy or SB live at the time of buying a laptop then only u can adjust these trebel bass settings , by the way which brand of sound card u have in ur laptop pls le tme know so i can checck
Jan 24, 2009 | Dell Inspiron 5160 Notebook
Cinemate bose how do I adjust base and trebble
If the system doesn't have controls labeled "bass" and "treble" - or if there are no clever presets like "Hall", "Theater", etc., then you'll have to adjust these parameters before the signal reaches the speakers. One way is to purchase a graphic equalizer to hook between the speakers and the signal source. A graphic equalizer a basically a tone control, with the spectrum divided into 10 or more "slices" instead of 2 (bass and treble). Consider the sliders on the left as "bass", and the ones on the right as "treble". If you're using these speakers for a computer, some sound card software has these controls buried beneath a few menus - but sometimes not. The easiest solution is to buy an equalizer and hook it between the signal source and speakers. Bose is typically "audiophile" equipment, and many audiophiles don't want tone controls (thus the extra electronic processing required) to contaminate the signal. Obviously, most systems do need to offer some control to the user, as you've discovered!
Dec 24, 2008 | Bose Cinemate Digital Home Theater System...
Mordaunt Short MS5-30
Hi r_drain
great choice of speaker, always liked MS gear. They are designed to be biamped, or rather have a separate amplifier for bass and treble frequencies. You can just jumper between the terminals. They originally cam with a plate that connect the 2 black and red terminals together making effectively one black and one red. The speaker still has a crossover in line internally.
regards
robotek
Jul 05, 2008 | Mordaunt Short 302 Main / Stereo Speaker
Clarion DXZ375MP CD Player Logo
309 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
