If your touch pad isn't working that means that your device is having some physical problem. take your mobile to a mobile shop where they can further fix the issue.
You can get an unlock code for your Samsung Galaxy Pro B7510 mobile phone from Prounlocking.com .Here you have to specify your country name,the
current network provider and IMEI number of your mobile phone.Then you
can get an unlock code from them at reasonable cost and unlock it.
press and hold power/lock key & T/3 key of the qwerty keyboard at the same time until you see the android system recovery menu shows. then use the volume key to scroll to wipe data/factory reset, press the home key to proceed with the confirmation, press the volume key again to scroll down to yes, press the home key again to confirm, then use again volume key to scroll again to reboot the system, and home key to confirm..
if you have to tap the tourch to get it to work then something in the tourch is loose or worn,have you tried to replace all the consumables in torch,check that all leads are tight.as far as parts go to your local welding store(praxair,midwest air gas, s j smith)not a hardware store,
