Question about Epson Aculaser C1100 Printer
Problem with quality of print out of Epson C1100 printer
Small patcches on the print out in the same place
  • famotashar Feb 18, 2009
    Thank you very much for your reply. I have mangaed to sort out the problem. When I refilled one of the the toners, apparently I touched the black belt . I managed to to clean it. and all the smudge disappeaed .
    Thank you very much for your help.
  • slaphead-uk Mar 08, 2009
    I have tried cleaning all the parts lisetd above, with no success. The marks are appearing approx 200mm from each other.
    I only have this problem when printing in colour
  • 163 Answers
Hi, I need to know where the marks are appearing on the print. Do they repeat down the page? If so measure the distance between the top of the first mark to the top of the second mark. Usually it is one of the following.
150mm: it is the PCU drum, take out the PCU and try gently cleaning the drum with a soft cloth, avoid strong/bright light as this will damage the sensitivity of the drum.
51mm: it is the 2nd BTR roller, remove the PCU. Inside the printer at the back you will see a black "foam" roller, gently clean with a soft cloth & try to avoid touching it with your fingers as any grease/oil could cause the symptoms you describe.
82mm or 94mm: these are the rollers in the fuser unit. Allow the printer to cool, open the back top cover. You will need to remove a small white plastic bracket on the L/H side (if it is held by a screw be careful not to drop it into the printer). Next unlock the two levers on the top of the fuser and pull it upwards and out of the printer. clean the orange colored rubber rollers with cloth or an alcohol wipe (screenwipe) and ensure it is dry before refitting.
Posted on Feb 18, 2009
Right hand side page print quality very poor, almost unreadable
this is cause of the lens is dirty with toner droping..
open the front cover and on the right side, there is a level for you to pull out.. at the right side of the printer, open the small cover and you will be able to find a cleaner. To clean..pull out the holder few times.. by applying slight pressure..that will clean the bottom lens..and u should be able to print out fine now..
Feb 26, 2010 | Epson Aculaser C1100 Printer
Epson Aculaser C1100 error code C0084. How is this code cleared.
Hi
The issue cause due to temporary "data error" that is easy to resolve. :-
  • A corrupted or interrupted print job, or:
  • A data or interface cable that is not connected correctly.
So, follow these steps:-
  1. Disconnect the printer from the data source
  2. Does the printer pass its ROM, RAM and Self Test checks?
  3. Test the printer standalone by printing a Status Sheet
  4. Cancel all pending print jobs on the network or computer
  5. Reseat and reconnect the data cable at both ends
  6. Test the printer
For more description view the following link:-
http://www.epson.co.uk/Store/Printers-and-All-in-Ones/Epson-Aculaser-C1100/Drivers-Support?target=article&extn=.html&articleId=1374
Feb 15, 2010 | Epson Aculaser C1100 Printer
Print quality Epson Laserprinter C1100
Sounds like you need to clean the laser lens to me. On the R/H side of the printer is a small panel, just pull this off. Now open the front cover, on the R/H side is a lever, pull this forward. Now look again inside the panel you removed earlier, there is a green "stick". Just pull this backwards and forwards a few times to wipe the lens clean. Put everything back and try a test print. Good luck.
Jul 07, 2009 | Epson Aculaser C1100 Printer
EPSON C1100 JAM ON MP E SITE
Solution to this can be found here: http://www.tradebit.com/filedetail.php/2366766-epson-aculaser-c1100-jam-mp-e-countermeasure
The printer has a modification kit for this error which is caused by a weak solenoid
Nov 09, 2008 | Epson Aculaser C1100 Printer
My epson laser printer help help
hold down the dustbin button while switching on to reset the printer after cleaning. that worked for me.
Aug 19, 2008 | Epson Aculaser C1100 Printer
Mac OS10.4.11 Epson C1100
I also use a Mac, (OSX 10.3.9) does this printer show up in the list when you activate the Printer Setup Utility (PSU) Do you get any error message from the Mac such as Printing Stopped etc. What shows when you click on the PSU after clicking on print etc.
Jul 01, 2008 | Epson Aculaser C1100 Printer
Epson C1100 - Vertical faint stripes on colour photos
see if this solution fixes the problem.
Also clean the print head using instructions in the manual
http://www.fixya.com/support/t241840-smudges_color_printing_black_ok
Mar 04, 2008 | Epson Aculaser C1100 Printer
Print quality Epson C1100
It sounds as though a cartridge is faulty. To determine which one, the easiest way is to run a page of text/block of colour through in yellow then cyan then magenta. which ever page comes out with the streaks on it will tell you which cartyridge to ditch and replace. Hope this helps Cops Pete@wedotoners.com
Oct 10, 2007 | Epson Aculaser C1100 Printer
Epson C1100 Print quality
no this is not a photoconductor problem. your fuser unit is faulty, it is not getting up to the correct temprature to "fuse" the toner to the paper hence why you are able towipe the toner from the page. Hope this helps Cops Pete@wedotoners.com
Epson Aculaser C1100 Printer Logo
551 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
