FixYa.com
Tags:
Panasonic Home Theater System System
Panasonic Home Theater System sound keeps shutting...
By Kim1 - usenet poster
I have a Panasonic SA-HT790V combination DVD/VCR/tuner/surround sound
with SB-WA312 "active subwoofer" unit. Recently the sound has begun to
shut off during relatively louder passages. It is necessary to either
plug in and remove headphones, or power-cycle the subwoofer unit, to
bring it back.
I suspect that the 5 channel amps are actually a part of this
"subwoofer" unit, as well. At first I wondered if overheating could be
the culprit, but now I suspect the low-frequency vibration from the
subwoofer is tripping something in the unit.
Is anyone aware of an issue such as this with Panasonic gear? Any
suggestions on where to poke and prod?
Thanks!
-Charles Green
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 01, 2007
Not Rated (0)
Beresford
Beresford - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
There may be a fault in the protection circuits, or in part of the output
stage. Sometimes the mounting screws that hold the output devices to their
heatsinks loosen a bit, thus causing the devices to overheat during high
output demand. Tightening the mounting screws may help, if this is the
particular situation. If not, the unit will have to be troubleshooted to
determine the exact cause.
Jerry G.
I also have the same problem and do not know how to fix this. This did
not happen for about 2 years but now this is a regular phenomena. I
have the HT900 model.
It is a crap and I can not watch any movie. Can someone help?
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Bomber
Bomber - usenet poster
Rating: 0%, 0 votes
Solution #3
Not Rated (0)
jessie25
jessie25 - usenet poster
Rating: 0%, 0 votes
If I were you I'd check to see that the load on the output of your unit
is what it should be. It sounds like you may have put some speakers in
parallel or in some other way put too much load on your amp. Try
running your amp with just one left and one right speaker and see if
you still have the same problem. If the problem goes away then you
have a speaker load problem. It could be that your unit is doing
exactly what it should be doing in order to protect itself from too
much load. Good luck.
Solution #4
Not Rated (0)
Brad
Brad - usenet poster
Rating: 0%, 0 votes
charles:
As you are probably becoming aware, the "build" quality of these cheap
all-in-one combo units is genuine crap no matter what brand it is.
Look for cracked solder joints and faulty interconnects between circuit
boards and then consider getting real individual components. At
least with individual components your whole system won't be down as you
repair, replace or upgrade an individual item.
As is usually the case, you get about what you pay for.
electricitym
Can you Help with these Home Theater Systems problems?
Recording and saving
When I record a cd on audio... Answer This...
reciever reads
My home theater system wont... Answer This...
sa-pt750
Hello, I am trying to use the... Answer This...
It is a used set and i cannot...
The set ia a [ANASONIC SA-HT... Answer This...
SC-PT960 Wireless Speakers...
I have a green light and the... Answer This...
Repair Service
Find Home Theater Sys. Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
