Question about Acer TravelMate 4100 Notebook
Hi i have an acer laptop 5000 series the usb ports will not work saying power surge overloaded,would buying a usb card solve the problem.Any help would be much appreciated.
  • 3 more comments
  • roetonmc Feb 18, 2009
    Thank you so much for your reply, A1
  • roetonmc Feb 19, 2009
    Hi did as said still does not work
  • roetonmc Feb 20, 2009
    Hi nothing is connected,the laptop has service pack 3 on it,do you think its the motherboard,none of the usb are broken on the serial bus connectors they are saying that they are working ok? Thank you for repling much appreciated.
  • roetonmc Feb 21, 2009
    Hi still not working,none of the usb ports are broken systome restore doesnt solve the problem,thank you so much for your time,you have been more than exellent in your responses.
    Novelist:
  • 148 Answers
are you using windows xp sp2, this issue normally occurs with it
a fast fix is:
go to start menu> run > type in devmgmt.msc > ok
1) Device Manager will open
2) Locate "Universal Serial Bus controllers" in the list and expand
3) Select the first USB Universal Host Controller.
4) Right click and select "Properties"
5) Go to the "Advanced" tab
6) Check "Don't tell me about USB errors"
7) Click "OK"
Note. If you have multiple host controllers then they should all be affected by the above action.
8) Close Device Manager
further Queries are welcome
Posted on Feb 18, 2009
  • ltoso Feb 19, 2009
    thanx for the good comment, what have you connected to your usb port which has led to production of this error, or is it producing the error without any device connected to the usb.
    awaiting reply
  • ltoso Feb 20, 2009
    hi,
    this can be because of both software and hard ware, but most likely it can be the hardware, lets try three things
    1) try booting the system into safe mode
    restart the system and when you see the acer logo start tapping the F8 key
    2) now select the option safe mode from the menu that appears on screen
    3) safe mode will have just the basic device drivers on your machine
    4) now when you logon do you see the same error message,
    if yes > this can mean that we might have a hardware problem, but software problem can also be there but probability is low
    if no > try using some device using the usb port if it works fine we are definetly having some problem with the software
    1) do you remember the day this started to happen or the day it was working fine, if so
    you can also use system restore to restore it back to that date when it was working fine, but using system restore will mean that you will loose all the software installed after the restore date and also the settings after the restore date
    use the following link( use system restore option)
    http://www.microsoft.com/windowsxp/using...
    hopefully this might solve your issue
    if this didn't resolve your issue
    try the following
    4) Right click and select "remove"
    5) confirm
    and retstart your system when it will be restarted the drivers will be reinstalled, it might ask you for Operating system or drivers CD,
    one more thing i have found one thread on the internet regarding this and issue with service pack 3 here is the link
    http://social.technet.microsoft.com/Foru...
    further queries are welcome
Work around for USB Device Software for Compaq nx6110, Windows xp SP 3. my laptop some times refuse to detect and read the USB devices like : flash disk, external hard disk, modem,... it use to write that...
first off why run XP the Virus magnet?,Microsoft and hp dropped
support on this 3 years ago,,
not only that XP does not support most USB devices.
sure some old devices, but not new ones. (unless maker says otherwise and offers software to run on XP)
you are direct connected. to USB to external HDD.
That external disk, my guess has no external supply right?
that means it will overload many Latptops
the power spec, on USB varies, by different ports used and maker of the laptop...
I solve that horror by only buying external HDD what have wall power pack connected, mine is 12vdc 2amps, and will work on any PC made , ANY !
it uses its own power, so never overloads that weak PCs USB port.
here is the USB spec from WIKI page "USB" 0.5amps is gutless.
  • 0.5 A (USB 2.0)<<<<<<<<<<<<<<<<<
  • 0.9 A (USB 3.0)
  • 5 A (BC 1.2)
  • 3 A (type-C)
  • Up to 5 A (PD)
0.5 amps that is, 500mA, about 1/2 what hdd needs. to be happy.
yours is the first one, the weakest they made.
that is not enough current to spin up any HDD, from dead start.
cures: (all)
  1. get an external SSD drive,
  2. use and external case on external drive with its own powerpack
  3. buy and an EXTERNAL USB powered hub that is USB3 rated and it might run your drive connected to it.
  4. get newer laptop, one with USB 3 and runs w7 or newer.
Jun 27, 2017 | HP Computers & Internet
My both usb ports r not wrking n hangs when eithr card reader or pen drive is inserted bt works well when tata photon usb port or mouse port or key board port is inserted ?model- EMACHINES E275
Sounds like your laptop's USB ports are not capable of providing enough power to operate your card reader or pen drive. I suggest you buy an active USB hub (one with external power source, rather than the one which draws power from the laptop's USB port), & attach your card reader and/or pen drive to that USB hub.
Nov 28, 2010 | Acer Computers & Internet
Hp nx6110 laptop error power surge on hub port
OK if you have anything plugged into the USB Ports at bootup, unless Keyboard or Mouse, remove everything, and see if it boots normally, if it does, then the "Hub" you are using may be faulty, or a device you are using is drawing a lot of current at switch on and overloading the USB bus, that can only supply 500mA. If it still does it, and you do use a USB KB & Mouse, then remove them one at a time & reboot, between, and see if it was one of them causing the problem. If you have nothing attached then your internal USB bus is flaky.
Feb 16, 2010 | HP Compaq nc6120 Notebook
My USB ports are not working. I Updated BIOS and each USB driver and HUB individually and still nothing is working in the ports.
Are the usb ports enabled in bios? and set to hi-speed?
I have had this problem where the port was damaged and overcame it by buying a usb port pcmcia card. To confirm it's physical damage you'll have to open the laptop up
Jan 11, 2010 | Acer Computers & Internet
Usb port2 in not recognizing by my obi cam or my
Try to update your usb drivers. Check if it is available on the manufacturers website.
Hope this helps!!
Please rate this!
Cheers
Sep 27, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Power Surge on Hub Port
Don't Use existing USB Portn On your Comp if u want USB port then install PCI USB Card From the PCI USB card you can use your USB Device what ever you want to use
Thanks
Ankur
May 29, 2009 | Compaq NX6110 TFT XGA Notebook
Power surge on hub port on my computer
Try unplugging everything from the hub and if that doesn't work then disable the hub.
You can either buy a new hub or buy a USB card. Both get the same results.
Oct 22, 2008 | E-Machines eMachines Desktop PC
Acer Ferrari 5000 with Ituner8 and Iphone
sounds like a problem with the iphone , did you try a different usb port?
Oct 08, 2008 | Acer Aspire 3680 Laptop
Power surge on usb port
unless your a very competant motherboard components repairer.
this is beyond repair. i,d suggest taking it to a repair centre, where they will replace the motherboard. and unfortunately a large invoice to go with it. probably more cost effective to look at a replacement laptop.
Mike @ Compurepair.
Jul 12, 2008 | Computers & Internet
Acer Travelmate 3200 usb dont work
this may help - or not..
http://support.microsoft.com/?kbid=310575
If you have damaged the USB chip on the motherboard, you may be able to disable it in the BIOS. Then when you install your PCMCIA card it may work...
USB is not as tolerant of short circuits as RS232. I know I managed to destroy one of the ports on my m/b.! Using a Hoover may not be a good idea.
Apr 10, 2008 | Acer TravelMate 2300 Notebook
Acer TravelMate 4100 Notebook Logo
105 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
