Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
Hi..my computer works on vista but the futura program doesn't respond with it
    Problem Solver:
  • 5 Answers
Try contacting singer at 800-4singer or email them at talktous@singerco.com
Posted on Feb 26, 2009
    Problem Solver:
  • 11 Answers
Depends on how old the "futura program" is...as Vista is a new system it's not compatible with many programs. For example if you save a document with MS Word 2007 and then go home and try to open it with MS Word 2003...it won't work...or you'll end up with a document full of source data. That help or make sense at all?!?
Posted on Feb 18, 2009
Hello im trying to install my singer futura in my laptop is a windows vista and when it reachs the 100% it just stops and i try to open the futura program and it saids that the machine is off or the usb is...
Make sure you're plugging the USB cable from the machine intoa USB port in the BACK of your computer, not one of the front ports or a porton a USB hub. The cable and machine need more power than most of those portsprovide, a technical detail that Singer doesn't realize. Good luck!
Apr 01, 2011 | Singer CE-200 Quantum Futura Computerized...
Computer does not install software
You probably have upgraded to Windows 7 or Vista. Please read the tip at http://www.fixya.com/support/r8955271-use_machine_windows_7_or_vista. The first part of the tip should get you up and running and is a bit time consuming, but simple. If it doesn't work, the second works every time. You just need to follow the steps carefully, step by step. My own machine runs under the second set of steps perfectly, while I have 2 friends who run their 2 different Futura models under the first series of steps.
Good luck and happy embroidering!
Mar 30, 2011 | Singer CE-200 Quantum Futura Computerized...
Just bought this machine and installed the software. When I try to use I get a message: Can not run CF_Splash.dll
It sounds like you are trying to use the software on Windows 7 or Vista. There's a patch at www.Futura-support.com you'll need. On the lefthand side of the screen, click on downloads, then choose CE100/150/250/350, etc, etc. Follow the directions CAREFULLY. Be sure to install ALL Futura software you've already installed and reboot your PC BEFORE starting the new instructions.
If for some reason this still doesn't solve your problem, I've posted a solution that's a bit more involved on the CE100 Problems & Solutions home page for running your machine on Windows Vista/7. Basically, it allows you to run any XP program on Windows Vista or 7 using your old XP software. The Futura patch works for most people, though, so you will hopefully not have to go that route.
Happy embroidery!
Feb 15, 2011 | Singer CE-100 Futura Computerized Sewing...
I have recently bought a new computer and i installed the software, but the machine will not recognise the computer, can it be installed on computer with the new windows 7 or do i need an update??
Yes, it can be installed on Windows 7. Check the Futura support sight at www.Futura-support.com and look on the right hand side under downloads. There's a download listed for CE150/250/350, etc, that applies to XP 32 & 64 bit, Vista and Windows 7 32 & 64 bit. Follow the directions CAREFULLY! If this doesn't work for you, I've posted a set of instructions under CE100 solutions for running the CE100 software on Windows Vista/7 by installing a Virtual Machine software on Windows 7 that works regardless of the situation.
The update should work for you perfectly, however. Just make sure you uninstall the Futura software and reboot your machine BEFORE you do anything else and follow the instructions from the website carefully! Good luck!
Jul 29, 2010 | Singer CE350
Future CE-250 software compatible with Windows 7?
I just bought a new Futura CE250 & had the same problem.
I fixed my "can not run an x86 build of this utility on x64 platform" by visiting the futura support website & downloading a service update. I have a computer with Windows 7 installed.
The website is www.futura-support.com
When you are there, click on the link on the left for "Service Updates."
The actual link to where I downloaded my udate is: http://www.futura-support.com/downloads/ce150.html
Happy Embroidering!!!
Jan 19, 2010 | Singer CE-200 Quantum Futura Computerized...
Vista unable to install Futura software
Vista is notorious for being flaky regarding embroidery software etc.....have you had advice from the Singer Dealer where you bought the machine ? Find your local dealer HERE
Singer USA Customer Support should have solutions for these things by now too and I recommend you hound them if they cannot easily suggest what to do. Vista is some years old now, not the first few weeks of release !
Apr 27, 2009 | Singer CE-200 Quantum Futura Computerized...
Futura software on winds vista
well i fixed the problem. if anyone wants to know how, just send me $9.99 (fiya price) and i will be glad to share.
Jan 11, 2009 | Singer CE-200 Quantum Futura Computerized...
Singer futura 350 and 150
Crafty123.
After reading through your problem, I began doing some research. You are correct with your initial assumption. Singer at this time, does not support Vista 64bit Operating System. They will support it on Vista 32bit, but even then you would have to install it in what is called, "Compatability Mode." Unfortunately, it is not uncommon to have many vendors not have their software work on 64bit systems. Many programs/applications were only written to work on 32bit systems. Ocassionally, you will have a system work on 64bit, by almost pure accident. Here's the link for the system requirements on the Singer Quantum Futura. http://www.singerco.com/futural/qfutura.html
For the plain futura system, you can go to: http://www.singerco.com/futura
click on the Futura System Requirements.
If you would like to attempt to install to Vista x64. Try following the compatability mode for 32bit Vista. http://www.futura-support.com/downloads/patch.htm#/ read the "Click here" to read the detailed installation instructions for installing on a Vista system
Best of Luck.
Jun 01, 2008 | Singer CE-200 Quantum Futura Computerized...
I just purchased a new lap top and how do i run my singer embordery programs
The singer website has a patch and instructions to use the software with Vista. It works great.
Feb 14, 2008 | Singer CE-200 Quantum Futura Computerized...
Help!!!!!!
IF YOU ARE RUNNING WINDOWS VISTA YOU HAVE TO DOWNLOAD FROM FUTURA SITE. HAD TO TAKE MY MACHINE AND COMPUTER TO COMPUTER SHOP TO GET SOFTWARE DOWNLOADED BECAUSE SOFTWARE IS FOR WINDOWS 98,2000 AND XP
Aug 25, 2007 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
46 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
