RTO Idec Rte-p1ad24 24vac/dv Electronic Timer Logo
Posted on Feb 25, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
E4 means what in idec - RTO Idec Rte-p1ad24 24vac/dv Electronic Timer
Gene Haynes
Level 3:
  • RTO Master 5,391 Answers
  • Posted on Feb 26, 2013
Gene Haynes
RTO Master
Level 3:
Answers
5391
Questions
0
Helped
2605976
Points
14124
Voltage error?
http://waterheatertimer.org/How-to-wire-pin-timers.html
Add comment and give more information about timer, including which timer, voltage, and what you are wiring, and where E4 appears.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
IDEC AIR CONDITIONING UNIT 1.5HP. What does Error D2 mean in my IDEC INVERTER AC
Question edited for clarity and typos.
This is a unit I have never heard of. I am in Canada, so this link might work better for you than it does for me.
https://www.google.com/search?q=IDEC+AIR+CONDITIONING+UNIT+1.5HP.+Error+D2
The correct search query would be IDEC (if that is the maker) MODEL number Error codes
1helpful
I have a LOFRA dishwasher LOD6001/LOD60002W showing an E4 error. It started OVERFLOWING so I opened the door to turn it off. Now it will not restart.
"E4" means Error and from 1 to 5 means malfunction in water valve / sensor. E4 means defective water level sensor.
Sep 27, 2018 • Dishwashers
2answers
I get an E4 message. what does it mean?
I have a model yf-008 110 v 3000w tankless water heater it shows e4 what dose that mean
E4 error code beautyrest electric blanket
beauty rest electric blanket error code - akaQA
www.akaqa.com > Uncategorized
beauty rest electric blanket error code. What does error code E4 mean? Answer this. 0 Views: 2487 Answers: 1 Posted: 3 years ago. Comment this question.
E4 error code beautyrest electric blanket - Fixya
www.fixya.com/support/t22178587-e4_error_code_beautyrest_electric
Dec 13, 2013 - E4 error code beautyrest electric blanket One side works the other returns an "E4" error code - Simmons Beautyrest Microfleece question.
E6 error on idec
E6 error code comes for room sensor in this. It means there is any damage in sensor. Pls replace it
E4 PROB LEM IN HAEIR DISHWASHER
(E4) means a problem with your Temperature sensor
God bless you
Oct 02, 2012 • Dishwashers
1helpful
I have e4 showing
E4 error indicate an abnormal water level which means too much inlet water (E5 also is refer at this fault).
I quote other comments/solution about this same error:
I had the e4 error code and i took the outer panel off and inside behind the power button is a grey reservoir tank which measures the water that goes inside the dishwasher which actually got bunged up with **** and grease causing the floaty thing to get jammed and cause the e4 code to come on which means abnormal water level the top to the reservoir just unclips on both sides then just clean all the gooey stuff out and put it back together it worked for me.
Good luck.
We got this panasonic fp-7718 for free and have tried to get it to copie but the e4 code keeps and i have no idea how to reset this code or any of the other codes.
There will be more to it than just E4..........it will say E4-01, E4-10,11, OR 12.
If its e4-01...that means the machine is not warming up and may have a problem with the Fuser unit.
If its E4-10,11 or 12 it relates to a problem with a Fan motor.
Thats the best I can do given the information you have provided.
Cant get the timer to power up, I know incoming power is on 2 and 7 .do i need to jump to other terminals?
RTE-p1ad is 24-volt AC 8-pin on-delay timer.
Manual for RTE-P1 & RTE-P2
http://www.idec.com/language/english/catalog/U908/G_Timers_RTE.pdf
I have not wired the P1 timer.
Manual shows for ON-delay, 24VAC input power goes to terminals 2 and 7
Using multimeter set to read ohms, check continuity between pins 7 and 8 to see if these pins are connected internally, or if you need jumper.
Also check continuity between pins 1 and 2 for same.
When power is applied to 2 and 7, the ON delay countdown begins.
When countdown ends, the switches are activated.
geno_3245_268.jpgSwitches are represented by angled line that connects to terminals 1 and 8. When countdown ends, the switch moves left and and completes circuit to other wire.
Using multimeter set to 24VAC, you can check each of the pins by putting power to 2 and 7 and checking which pins have power after countdown ends.
The NC normally closed terminals are 1 and 4, and 5 and 8, so it appears that these terminals are ON all the time until countdown ends and 'contacts transfer power.' Test the pins to be certain.
There are contact numbers for product:
USA: (800) 262-IDEC or (408) 747-0550, Canada: (888) 317-IDEC
3helpful
3answers
E4 Error
york hvac unit e4 error code Troubleshooting
Top RTO Hardware & Accessories Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a RTO Hardware and Accessory Expert? Answer questions, earn points and help others
