Question about SanDisk Sansa e250 MP3 Player
Sandisk E 250 unable to turn it ON
Unable to turn it ON. also, it not displaying anything when connected to PC for charging.... do reply
  • 8,596 Answers
Make sure the hold/lock switch is not engaged.
Try switching between MSC and MTP Mode if that fails.
Otherwise:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Feb 20, 2009
Unable to see the music files in my sandisk sansa m240 mp3 player
click on start > my computer
it should be displayed now.
Oct 29, 2009 | SanDisk Sansa m240 MP3 Player
My Nokia 1112 displays 'Test mode' only and doesn't switch on!
charge your mobile and while charging try to turn on.make sure the charger is connected properly. else u need to check on the charging pin in the mobile.
Aug 20, 2009 | Nokia 1112 Cellular Phone
Cant edit the songs, unable to view
Check if the songs you transferred are mp3 or wma or try another XP service pack ( You could just try it on another pc)
Jun 22, 2009 | SanDisk Sansa m240 MP3 Player
Charging
sounds faulty to me, id return it for a new one if i were you. but before you do try updating it, might be a firmware problem. if your unsure how to do that. just go here and install the program.
Nov 05, 2008 | SanDisk Sansa e260 MP3 Player
Unable to connect my sansa e260 player in pc
To obtain the driver for your sandisk device go to http://www.sandisk.com/DriverDownload/index.asp and find the driver for your device..and then connecct the device on the back of your computer...it should work properly..if you are still having any problems..let me know..i would be more than happy to assist you..
Please rate accordingly
Thank you
Computerrep
Jul 27, 2008 | SanDisk Sansa e260 MP3 Player
I lost my installation cd for my Sansa c240 MP3 Player 1GB. Can I go somewhere to download the proper drivers to be able to connect to my pc again?
Yes - it is available from the Sandisk Website --> Support --> Mp3 players --> Sansa -- > Software & downloads
Jun 22, 2008 | Audio Players & Recorders
Frozen sansa e-250
Hold down the power button for fifteen seconds. Sometimes all the unit needs is a good soft reset.
If, for whatever reason, the unit is still unresponsive, you will need to force-format and downgrade the player. Instructions on how to do this can be found here:
http://www.anythingbutipod.com/forum/showthread.php?t=11233
May 22, 2008 | SanDisk Sansa e250 MP3 Player
Sandisk 512 MB MP3 player - Display not working
I don't know, but ur probably gonna have to send that one in.
Good luck
Dec 19, 2007 | SanDisk Sansa e250 MP3 Player
Problem in charging
try performing recovery mode on the player then after performing recovery mode update the firmware of your player. Recovery mode is > Enable Hold Switch + Press Record Button + Menu Button
Oct 06, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
SmartAviator
SmartAviator
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
