Question about SanDisk Sansa e250 MP3 Player
Sandisk E 250 not starting
I am unable to turn it on.. wat to do...its not showing disply when i connect it to PC for charging ...
plz do reply...
  • 8,596 Answers
Make sure the hold/lock is not engaged. If it is not:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out:
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Feb 20, 2009
My cpu is front light on but not go to disply powr fan is ok runing but not show the disply plz help me any on
check the display monitor cord to CPU if attached perfectly/check on off switch of display screen
Feb 23, 2015 | Computers & Internet
Gigaset a495 showing Register HS, and i cant making call.. plz give me a solution
gigaser A495 Handset ,
Actualy one problem may Handset Disply not work,Pls reply how to work in incoming and disply screen number.
Aug 18, 2012 | Siemens Gigaset A495 Cordless Phone
My lap s nt working.i cant switch on/off this again .still it in one position,it didnt disply the screen also.wat i do? plz help me my laptop s lenovo.
Firslty u chck  ac adapter and the battery is working properly or not or charged,and follw fiven steps,
Turns out, it has something with ur lp Ram. if two ram inyour lp like (512*2)some reason one is malfunction which caused the other one function improperly as well. than u switch the memory card to different slot, and than ur laptop boot fine afterward.
Dec 10, 2009 | Computers & Internet
My Nokia 1112 displays 'Test mode' only and doesn't switch on!
charge your mobile and while charging try to turn on.make sure the charger is connected properly. else u need to check on the charging pin in the mobile.
Aug 20, 2009 | Nokia 1112 Cellular Phone
What to do when my iphone is hang? plz reply it
Connect your i phone to pc through folder option show hidden files alongwith system files and known file types you will get folder option in tools menu of any open folder. Check for any exe file delete it. If your phone hangs and unable to restart then simply take out the battery of your i phone.
Jun 19, 2009 | Apple iPhone Smartphone
you have lost your system files, if there is chance can you remove the RAM and fit again and then start if it doest not work then plz mail me
May 28, 2009 | Lenovo ThinkPad R51
Frozen sansa e-250
Hold down the power button for fifteen seconds. Sometimes all the unit needs is a good soft reset.
If, for whatever reason, the unit is still unresponsive, you will need to force-format and downgrade the player. Instructions on how to do this can be found here:
May 22, 2008 | SanDisk Sansa e250 MP3 Player
Problem in charging
try performing recovery mode on the player then after performing recovery mode update the firmware of your player. Recovery mode is > Enable Hold Switch + Press Record Button + Menu Button
Oct 06, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
