Question about OKI MICROLINE 3320 Matrix Printer
Losing connectivity on my OKI MICROLINE 3320 printer
About 15 days ago we installed a new server in work...after that every now and then when i want to print something i lose the connection with the server and have to log of my computer so i can finally print.Both servers are still online old one and new but even if i close the new one the problem still remains...if someone could help i would really appreciate it.Thanks...
  • chris_tzo Feb 24, 2009
    that unfortunatelly didn't work,so i guess is an IP problem...if i sent u the configurations u think u could help me out?my email is chris_tzo@hotmail.com thank you again for replaying.
  • 728 Answers
Hi chris_tzo;
Without knowing your configuration on your servers, it sounds like a sharing issue on the printer. If one of the servers is set to be a print server, then you need to duplicate that on the other. If you don't have a print server, then you are sharing the printer from a workstation. In that case, what I would suggest, from the computer that you are having problems with. Drill down into the network to the computer/server that is sharing the printer and when you get to the printer, right click the printer and click connect. This will load a direct connection to your computer, and you shouldn't have any disconnect issues again. If you do, I'd say it's a network IP problem that is causing the disconnect, which is a whole other can of worms.
Good Luck
Mark
Please don't forget to leave a rating
Thanks
Posted on Feb 18, 2009
  • Mark Taylor
    Mark Taylor Apr 04, 2009
    Hi chris_tzo
    I'll certainly be glad to try.
    Mark
Oki MICROLINE 3320 All numbers are printed on the invoice where they need to be, but each print yields a line or two of squashed, barely visible numbers (usually at the bottom). Please assist?
Remove the main cover of the printer. There are a few white plastic gears on the right side of the printers engine. You will probably find one tooth missing from one of those gears and a new gear will be needed from OKI. You should be able to get it thru any OKI dealer.
Mar 13, 2017 | The Office Equipment & Supplies
Can we print Courier New font with print quality UTL: Utility in OKI3320 printer
the printer normally prints the font set in the computer as it replicates the document
Mar 30, 2015 | OKI MICROLINE 3320 Matrix Printer
How to get oki microline 391 turbo to work with windows 2003 server?
use the HP laserjet 4 or 4000 print driver. this is the most basic print driver and has played nicely with the older printers
Jun 02, 2014 | OKI MICROLINE Office Equipment & Supplies
How do i install the printer without a disk
Go to http://www.okidata.com/mkt/html/nf/Drivers.html and download the drivers, which work with your OS, for your printer.
Sep 13, 2011 | OKI MICROLINE 3320 Matrix Printer
Good day, we have a oki microline 3320 printer with a usb port. It is a new cable and we are trying to install it on our pc but it keeps on failing. Can you please assist us with this matter. many...
find out that any other device is working on that USB port? if yes then try with other cd, ask the dealer to provide u other cd. may be any file corrupted on that cd. if any device not working on that port may be the port is defective or may be it is disable from bios setting. go to bios setting while u turn on the pc see the message appears press DEL or press F12 to go to bios seeting. go to bios setting & find USB port is enable or disable. enable it.
Oki microline 3320 doesnt stop in the right place for next invoic
Look on preferences, check if A4 is used for paper layout...
Jun 09, 2009 | OKI MICROLINE 3320 Matrix Printer
Lost installation disk for microline 520 printer
Did you check on-line with OKI? If they do not have it, check used computer stores on-lne and ask if they have it. Perhaps they can burn you a disk for a small fee.
Does you new computer have it in their database?
Go to Printer install, and check the OKI database in MS windows. Might be there. Just install and go to work.
Cheers.
Mar 27, 2009 | OKI MICROLINE 520 Matrix Printer
Oki 3320
There is no easy way. You need to adjust starting position for every form. There is fine feed function and Top Of Form setting procedure, so you can adjust the minimum space between top of porm and first printed string (user's guide explains in details how to do it). But after that you need to decide whether you manually set the start position by rotating the knob or play with your application to adjust margins etc.
Dec 24, 2008 | OKI MICROLINE 3320 Matrix Printer
OKI MICROLINE 3320 Matrix Printer Logo
354 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
mukhtar21 shaikh
mukhtar21 shaikh
SiNnA
SiNnA
Level 1 Expert
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
