Question about Samsung X10 Notebook
The machine will not start up with what appears to be a fully charged battery and AC input
    Novelist:
  • 148 Answers
HI,
this can be either
no power/no post /no video situation
when you push in the power button do you see the power light on
if not follow the following
please follow these steps
1) take out the ac adapter
2) take out the battery and try to start the laptop with AC adapter in (on sate) see if it works
if upper solution works call the laptop manufacturer tech support either your motherboard or battery is faulty
if it doesn't start with solution above
1) take out both battery and ac adapter from your laptop
push and hold the power button down for 15 seconds and then put in the battery and try to start the laptop, (this step release any flee power in laptop)
if none of the above works you have to call your laptop company (this was for no power issue)
if you see upto the limit when windows logo appear then
restart the system again and then keep tapping the F8 key when the manufacturer logo appears
and you will be taken to a menu that says safe mode in one of the option, select safe mode and press enter
check if you are able to login into safe mode if so, that means you have a video driver issue
click start button > run > type in without quotes '%systemroot%\system32\restore\rstrui.exe'
> ok
you will be taken to a windows where you can restore your settings to a date when all was working fine, follow the instructions on the windows and select the date that was the one when system was working fine, > restore the system
(caution: when you restore a system back to a date any progarm installed after the that date will not work or appear in program menu as all the settings after that date is lost)
and when you will restart your issue will be hopefully resolved
if you are able to see the power LED its blinking or something
call your laptop manufacturer technical support
Further Queries are welcome
Posted on Feb 18, 2009
Charging my juke with a usb cord
Fully charge the battery to maximize playing time. However, it is not necessary to fully charge or completely discharge the battery each time. You can charge the battery by connecting the jukebox either to the AC power adapter (fastest) or to a USB port on the computer. The battery icon in the upper right corner of the screen indicates the remaining battery charge.
  1. Connect the USB combo cable to the AC power adapter, and then plug the power adapter into an AC power outlet. Or, you can connect the USB combo cable to a USB port on the computer.
  2. Plug the combo cable into the jukebox. Make sure that the top of the plug (the side with the arrows) is facing the same direction as the front of the jukebox.
    View Picture
  3. If you are charging your jukebox from the computer's USB cable, turn your jukebox off. If your jukebox is on, it cannot charge from the computer's USB cable. Note: If you are charging your jukebox from the AC power adapter, you can leave your jukebox on as it charges, but it will take longer to charge.
  4. If the jukebox is on, the power cord icon appears in the upper right corner of the display. The keypad's backlight turns on while the battery charges, and then turns off when the battery is fully charged.
  5. When your jukebox battery is finished charging, pinch the two side buttons on the plug, and then pull the plug out of the jukebox.
Feb 25, 2012 | Samsung SCH-U470 Juke Cellular Phone
My Mintek portable DVD player's battery will not charge. I have rarely used the battery so I can't believe the battery is dead. The AC cord works to power it when plugged in. Why won't it...
After a while even rechargeable batteries loose the ability to hold a charge. This process accelerates when the battery is allowed to lie completely discharged for long periods of time. NiCad batteries especially have this issue. If you left the battery sitting for long periods without occasionally charging it, it losses the ability to hold a charge. It appears you are going to have to either do without the battery or replace the pack. I would take out the old one, it will eventually start to corrode and leak and if its still in your machine it will cause damage. If you get a new battery pack make sure you charge it fully and then depleat it completely before recharging it. hope this helps.
Jul 26, 2011 | Mintek MDP-1880 8.5 in. Portable DVD...
My hp pavilion dv4 laptop's battery cannot sustain even for 1 hour.please give some ideas to maintain the battery and is there any remedy for this issue.Also which is better among, using laptop always...
If the battery appears to be charging, the drop in the time it sustains power is likely due to a faulty or old battery. Eventually it will appear 100% charged and drop to zero in 5 minutes or less. I would think you need to replace the battery.
If you want to maintain the battery properly, it is best to remove it once fully charged and use on ac power alone. If using the laptop on battery, remove the AC connection and allow the battery to fully discharge before recharging it ( there is some debate on this method, other may disagree)
Jul 14, 2011 | Computers & Internet
The initial battery of my Acer Travelmate 2480 packed up and I ordered and installed a new one. However, the laptop remains on "AC Only" power and the battery is not charged, giving a...
RTFM You can download the manual by googling "acer travelmate 2480 manual" (without the quotes). Or just click here
According to the Acer manual:
"Conditioning a new battery pack
Before you use a battery pack for the first time, there is a
"conditioning" process that you should follow:
1 Insert the new battery without turning the computer on.
2 Connect the AC adapter and fully charge the battery.
3 Disconnect the AC adapter.
4 Turn on the computer and operate using battery power.
5 Fully deplete the battery until the battery-low warning appears.
6 Reconnect the AC adapter and fully charge the battery again.
Follow these steps again until the battery has been charged and
discharged three times.
Use this conditioning process for all new batteries, or if a battery hasn't
been used for a long time. If the computer is to be stored for more
than two weeks, you are advised to remove the battery pack from the
unit.
Warning: Do not expose battery packs to temperatures below 0°C
(32°F) or above 60°C (140°F). Extreme temperatures may adversely
affect the battery pack.
By following the battery conditioning process you condition your
battery to accept the maximum possible charge. Failure to follow this
procedure will prevent you from obtaining the maximum battery
charge, and will also shorten the effective lifespan of the battery.
In addition, the useful lifespan of the battery is adversely affected by
the following usage patterns:
• Using the computer on constant AC power with the battery
inserted. If you want to use constant AC power, you are advised to
remove the battery pack after it is fully charged.
• Not discharging and recharging the battery to its extremes, as
described above.
• Frequent use; the more you use the battery, the faster it will reach
the end of its effective life. A standard computer battery has a life
span of about 500 charges."
Jun 16, 2011 | Acer TravelMate 2480 PC Notebook
Battery has been charging to 100%. Suddenly would only charge to 76 percent. Now, after two weeks, will max at 62 percent. Computer is 1 year old. Can battery meter be recalibrated?
Pulled from Gateway's website:
Do not interrupt the battery recalibration process. If recalibration is interrupted, you must start the process over again.
  1. Close all open files and programs.
  2. Connect your notebook to AC power and allow the battery to completely charge.
  3. Disconnect the AC power and restart your notebook.Note: If the power cord plug.gif or battery baticon.gif icon does not appear on the taskbar, click the show hidden icons showhidden.gif button. If the icon still does not appear, verify thatAlways show icon on the taskbar is checked on the Power Options Properties Advanced tab.
  4. Completely discharge the battery by doing the following:
    1. From the desktop, right-click on the power icon, then select Adjust Power Properties.
    2. Click the Power Schemes tab.
    3. Click the arrow button to open the Power Schemes list, then click Always On.
    4. Click the Alarms tab.
    5. Click to remove the check mark from the Low battery alarm and Critical battery alarm checkboxes. Let the battery drain until your notebook automatically turns off.
  5. After the battery is completely drained, reconnect your notebook to AC power.
  6. Charge the battery completely until the yellow battery status indicator goes out.
  7. When you are ready to use your notebook again, do the following:
    5. Click to select the Low battery alarm and Critical battery alarm check boxes.
Mar 11, 2011 | Gateway Netbook N450
New battery in eMachine M6811 won't fully charge.
1) Control Panel / Security & Maintenance / Recovery
Feb 22, 2018 | E-Machines M6811 Notebook
?how do I charge the battery
You use one of two methods
Method 1
1. Install the battery in its compartment.
2. Plug the AC adapter
The battery will start charging, and the status light for the battery will appear amber. The light will remain amber as long as the battery is not fully charged. When the cahrge is completed, the light will turn green.
Of course, if your are using your computer while battery is being charged, it will take three to four times longer to complete the charge.
Method 2
Toshiba sells battery chargers which you can use to charge a battery outside of the computer.
Hope it helps.
Aug 26, 2009 | Toshiba Tablets & eReaders
Bettary problem or adaptor problem?
ac/dc convertor board inside laptop faulty.
May 31, 2009 | Dell Inspiron 1300 Notebook
Zen Vision M battery not charging
The problem was partially solved in that I put my old battery back in and at least it charged properly. I did receive a new battery from BatteryMill and I fitted it and left it charging for 5 hours. However, when I unplugged it to see if it had charged at all it did the low battery thing and then when I tried to recharge it the battery fully charged symbol ame up. I suspect that had I left the new battery charging for say 24 hours it might have charged fully. However, I have decided to send my batteries back and get a refund. The problem must be something to do with a battery memory problem.
Jul 31, 2008 | Creative Labs ZEN Vision:M Digital Media...
Power problem with dell latitude.
This is a failed power management system on the motherboard. The power management system regulates the power input, usage, allows the machine to switch from AC t battery, and controls the charging. When this fails it can cause problems ranging from battery not charging, power on battery only, power on AC or battery but not both, no power at all, and more. You will most likely have to replace the motherboard, however, there are a few places that do circuitry and component repairs on motherboards. Google motherboard repair facilities, get an estimate, and compare the price to a new board.
Jul 29, 2008 | Dell Latitude D600 Notebook
Samsung X10 Notebook Logo
201 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
