Question about Hotpoint BWM12 Front Load Washer
I have the hotpoint BWM129 super silent 1200 spin, recently the machine has stopped draining water even after spin cycle has finished , I also have constantly flashing lights which are super wash and delay start and i can not turn off the machine
  • Anonymous Feb 25, 2009
    I can't get the drain off to clear it out. What ever is in there is now preventing it being fully closed and so now drips!
  • gelrevo May 11, 2010
    I have had exactly the same problem with flashing lights 2 and 4 super wash and rinse hold. I also couldnt get the filter cap off as the item in the cap was preventing it from being turned. I turned the washing washing slightly on its side and removed the black pipe from the filter to the drum. I put my finger in the hole and removed the items from the filter i could then undo the cap. That may not have been the cause of the flashing lights as I then found an item trapped (a dead sock) At the top of the black pipe from the drum to the filter there is a ball in the black pipe which is meant to be there and that is where i found the offending item after removing this all is well. regards Keith
  • Hotpoint Master
  • 19,396 Answers
The flashing lights means that an error had been detected.
The machine must be unplugged from main to check the drain hose and the drain pump.
The most common is that the drain pump is clogged with debris and must be unlocked.
Posted on Feb 18, 2009
I have just had exactly the same problem and it was because something was blocking the pump fan just behind the filter at the bottom of the machine. i had to dislodge the offending article with some needle nose pliers and once i had done that the machine worked fine again. when you take the filter cap out at the front of the machine just shine a torch into the cavity
Posted on Aug 06, 2009
  • John Jordan Nov 24, 2011
    I had exactly the same problem and solution as spate801. I would just add that if, as is probably the case, your machine has stopped with water in the drum, isolate from the mains, pull machine out from under worktop and drain the water a little at a time via the drain hose into a bowl. Keep draining until the water stops flowing when the hose is held very low to the ground. You will still have some water behind the front plug so take care when emptying this last drop.
    I found the corner of one of my wifes face cleansing cloths inside that front plug hole.
My hotpoint lumina super silent is starting a cycle but only loads the water and then doesn't spin it just stays still and counts down the time until theoad finishes and then empties the water. What's...
it's not named after that other car, is it? It's a hotpoint ultima super silent. Most likely suspect is the drive belt for the tub. Remove back cover and find the tech sheet stuffed in the unit for lots of secrets, shortcuts, and commonly replaced parts with the correct mfr part numbers. Check to see if the belt has come loose and why.
Mar 05, 2015 | Hotpoint Washing Machines
I have a hotpoint bwm129 1200 spin and I can't drain the water out of the washing machine. I have taken out the filter as it was clogged, cleaned up but the rest of the water has not come out of the d
You should be able to drain the water out by laying the drain hose down into a bowl. Does the pump function properly on final spin, that usually clears the water to allow the door to open. Parts are obtainable from Hotpoint Spares.co.uk.
Jan 29, 2015 | Hotpoint BWM12 Front Load Washer
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
May 25, 2014 | Hotpoint Washing Machines
My Hotpoint BWM129 drains at end of a cycle but doesn't proceed to spin, fault lights flashing are rapid Door locked and intermittent Delay Start. Does this fault code indicate a faulty drain pump or
Engine fault or main board fault. Most likely main board.
Check cable harness from main board to engine. Check the carbon brushes on the engine. If its all okay, replace main board
May 21, 2014 | Hotpoint Washing Machines
Why does the machine not empty the water, machine is a hotpoint super silent load wt90 1600 spin
When giving model and make information, you should take it off the id tag because that is how all our repair systems are set up.
Since I can not call up you model, I will have to give you a generic answer.
You first need to check and see if the machine will drain in any of the other cycles (permanent press, regular, delicate). If it doesn't then either your drain pump has stopped working and needs replaced or something like hose or a sock has clogged the drain pump intake. You should also check to make sure that nothing has block the drain hose.
Jul 20, 2011 | Hotpoint Washing Machines
Hotpoint bwm129 wont finish a cycle. super wash and rinse hold lights are flashing.have checked pump for obstructions and waste pipe. any suggestions?
Have you checked the filter? even if the pump is o/k, if the filter is blocked, it will not empty..
If filter clear, then you have a more serious problem.
Hope this helps.
Dec 02, 2009 | Hotpoint BWM12 Front Load Washer
WD640 aquarius super silent won't spin or drain
hi there......most likley cause is a blocked or defective drain pump....if the water cannot get out of your machine due to the faults above it wont rinse drain or spin
regards Sir Galahad
Aug 16, 2009 | Hotpoint Aquarius WD640 Front Load...
Lights flashing & door wont open
Dear RedBikeGirl
I've got a BWM129 which is causing me problems too (the washing is smelly at th eend of the cycle!) - How did you get the filter unit out of its housing, I turns around but doesn't seem to want to come out!
Any help gratefully received
Jun 01, 2008 | Hotpoint BWM12 Front Load Washer
Hotpoint BWM12 Front Load Washer Logo
3,292 people viewed this question
Top Hotpoint Washing Machines Experts
hungoverrr
Level 1 Expert
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
