Question about Lexmark E232 Laser Printer
Printer not printing
E232 explanation mark light has come up with toner light, i changed the toner and the two lights are still showing and i cannot print anything.
    Problem Solver:
  • 5 Answers
If "ready" and "toner low" lights are both on, your problem is probably photoconductor. You must reset your printer. Turn on the printer, open front door and press "cancel" button until all lights cycle on the operator panel, than release it and close front door.
Posted on Feb 27, 2009
When putting it on all lights are flashing one way ,at the same time as a results the printer doesnot want to print because one light should be on to show that it can print.
All service errors are indicated by all lights flashing as the primary notification or code. Please press the continue button to display the secondary error message or code. The secondary code indicates an area or function which has the error.
For further assistance, please contact Lexmark Technical Support.
Jan 30, 2012 | Lexmark E232 Laser Printer
The exclamation and the toner lights are steady on yellow and i can't print
needs pcon or toner replacing exausted hence toner light and ! mark and will not print por before changing or it will stay the same
Nov 17, 2011 | Lexmark E260dn Laser Printer
One of the lights are on and don't know what it means, but printer wont print
LED lights do not know where but I think it could be empty toner cartridge (replaces toner) or a piece of paper remaining inside if you had problems
Apr 11, 2011 | Lexmark E232 Laser Printer
Toner is changed but toner led flashingr
The flashing toner light indicates that the photoconductor kit needs to be replaced.
Use this Lexmark Part# : 12A8302 to order. After replacing the drum cartridge counter will have to be reset, Use the following steps.
1. Open the front door (press button on left side).
2. Press and hold the cancel button (x button) until all the lights flash in order.
3. Then close the front cover.
This will reset the drum counter to enable continued printing.
Jul 21, 2010 | Lexmark E232 Laser Printer
TONER LIGHT STAYS ON WITH NEW TONER CARTRIDGE
If the main problem is just the toner light on then what you could do after installing the new toner is resetting the printer. You could do that by powering the printer off, open the front cover (as if you were to replace the toner) with the front cover open and the printer off push and hold the two buttons on the printer and turn the printer on while holding down the buttons then once the bottom light stays on solid, release the two buttons and that should reset the printer.
Now if the toner light is blinking that means that you have reached the 30,000 page mark and the Photoconductor needs to be replaced. If that is not the case you can follow this link to a procedure where it will explain how to reset the Photoconductor. http://bit.ly/91SWS3
Mar 04, 2010 | Lexmark E232 Laser Printer
Two lights are lit up on the operator panel of my Lexmark E232 printer: a steady blue ready light and a steady yellow toner cartridge light.
Jul 10, 2009 | Lexmark E232 Laser Printer
My lexmark 232 shows the light "toner low/replace pc kit". how do i do that?
The Photoconductor Kit designed for use with Lexmark E230, E232, E232T, E238, E330, E332, E332N/TN, E240, E340 and E342. Yields 30,000 pages.
Have you printed 30,000 pages on this unit? If not perform the following reset:
Procedure for E-232 is:
1. press and hold Start
2. turn on the printer
- this is service mode -
- by pressing the Start you can print Printer Settings Configuration sheet -
3. press and release Cancel 4 time
4. Press and hold Start while all lights start cycle
5. press and hold Cancel untill all the light cycle
6. turn the printer off to exit the menus
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 20, 2008 | Lexmark E232 Laser Printer
Blinking lights
I believe that you are talking about the photoconductor kit this needs replacing when it has reached end of like if you don't replace it you will get poor print quality and risk damaging the printer as well. Below find the lexmark web site with their quick reference guide.
Luck
http://www.lexmark.com/publications/pdfs/e230/eng/qref.pdf
Jan 21, 2008 | Lexmark E232 Laser Printer
Lexmark E232 photoconductor
Make sure to install the new photoconductor 1st.
1) Power off the printer using the switch in the back.
2) Open the front cover.
3) Press and hold the Continue button (Big silver button with Diamond shape symbol) and power the printer On (turn the switch back to ON).
4) When you see the last light i.e. error light on solid, release the Continue button and close the front cover.
5) When you close the cover you will see all the top 3 lights on solid.
6) Press the cancel button with X symbol for 4 times very slowly till you see toner low light (i.e. second light from top) on solid.
7) Press the continue button and wait until you see the light sequence.
8) Press the cancel button and wait until you see the light sequence.
9) Finally power off the printer using the switch in the back (IMPORTANT= wait 1 minute) and power it back on to exit the configuration mode.
Nov 07, 2006 | Lexmark E232 Laser Printer
Lexmark E232 Laser Printer Logo
490 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
