Question about AOpen AX4SG Max Motherboard
I have a AX4SgMax motherboard and I am unable to boot it up. I noticed that the board has a resettable fuse, could this be the problem and how do you go about resetting it?
  • Mike Feb 19, 2009
    Thanks for replying yanickv, when I hit the power on button, I get the green light come on and a red light onthe motherboard. I get nothing in the way of fan etc..., on the screen it starts to boot up a screen with very little white writting flashes up really quickly and goes to the safe mode selection window.
    no matter what you choose, it just boots up the same way to that window.
    Could it be the power supply, can get 1 cheap.
    Our is it the motherboard?
    I have had 2 harddrives and 1 external harddrive lock up on me and cannot access them.
    At the end of my teather.
    Hope you can help,
    Mike
  • Yannick Verhoog May 11, 2010
    Unable to boot it up?
    You mean that the whole pc just doesnt start, or do the lights go on but yo don't get anything on screen?
  • 285 Answers
No fans could indeed indicate a problem with your power supply...
Or your motherboard is broken.
Have you recently added extra hardware to your pc, like a new graphics card, or one of the harddisks you mentioned.
I suggest you try removing them from your system, if possible, and then try to boot again. If the pc then works, it's probably your power supply.
If not, your mainboard is probably broken. I suggest you try replacing it with one from another pc first, before you go buy a new one. If replacing it doesnt work, buying a new one will be of no use.
But then you've got the problem of removing a mainboard, which isnt exactly easy. So I guess it's up to you to find someone who can do that.
I hope this helps,
Yannick
Posted on Feb 19, 2009
Supermicro x8sax memory bank issues
The X8SAX motherboard has 6 memory slots. Try booting with one memory stick in each slot to identify which memory bank (dimm slot) is giving you issues. If you are able to boot off of a good slot, check the BIOS version to make sure you have the latest installed (R 2.0b). It can be downloaded here: Super Micro Computer Inc Products Motherboards Xeon Boards X8SAX
If you are unable to get into the BIOS at all, check the warranty status and submit an RMA request to Supermicro:
http://www.supermicro.com/support/rma/
Mar 01, 2012 | SuperMicro Desktop Board - X8SAX...
CANNOT FORMET THE C PARTITION IT WILL SHOW THAT WINDOWS UNABLE TO FORMET ? WHAT IS THE PROBLOM & HOW TO RESLOVE CAN BE BOOT FOR MOTHER BOARD KOBP4266 NDFSMX -P4M266ISU IF SO MOTHER BOARD CD/SW?...
You cannot format the C drive or System drive with opened OS. But you will be able to format the drive on Boot, through A bootable CD/DVD or Any Other device!
Sep 01, 2011 | Mercury KVM266PM-U (KVM266PMUD1600)...
Installed a new msi 88ogm - e43 motherboard with a amd phenom 2 processer and get no boot/post message of any kid
Go ahead and remove everything but the processor, heat sink, PSU, and the power connectors to the board and attempt to boot up like that. If you still are unable to boot up check to see if you have any yellow lights on your board, if so either your board or power supply are damaged.
Mar 30, 2011 | MSI 880GME41 AM3 AMD 880G HDMI Micro ATX...
I am using mercury 845gvml motherboard but having a problem in vga drivers
To set up vga you have to set the bios setting to the vga platform which you are using like intgated to on board ,pci to pci card and pci-E to pci express card .
Then boot pc and right click on my computer - manage-device manager-display adapter -and see any yellow mark in it .
if their is any mark then update the driver by keeping mother board cd in cd/dvd rom .
delete any non completable driver in it or you can use control panel to do this work .
if you are unable to boot in system then on boot screen press f8 to boot in vga mode or safe mode .and do all work recommended
Dec 07, 2009 | MSI 845GVM-L (MS-6714-040) Motherboard
Computer does not boot
If you computer over heated, this could have caused the board or power supply to short. I would first start by trying a new power supply unit (since this is cheapest of the options). If that does not work then try replacing the motherboard and/or processor. Since you not getting any power, my guess is motherboard or power supply unit.
Apr 20, 2009 | Intel Desktop Board D845PEBT2 Motherboard
L440Gx server board do not boot
1: Check wether the on/off button on your power supply is turned to on.
2: Check your cables. Try switching with those from other pc's.
3: Check wether all the connections from power supply to the mainboard/ram/video/harddisk are OK.
Hope this helps,
Yannick
Feb 18, 2009 | Intel Server Board L440GX (KMS440GXTPAK10)...
Unable to boot up
The problem is of the display side so if possible connect the pci
display card or can repaire the mother board, If not then only solution is to change the mother board.
Thanks
Sep 08, 2008 | ASUS P5B-E Motherboard
Unable to boot
i have intel D101 motherboard and 2.8GHz processor, 512MB Ram but boot settings are disabled in bios
and unable to enter into bios.
Aug 09, 2008 | Intel D101GGC Motherboard
Presario SR1030NX - with a ASUS A7V8X-LA motherboard, won't boot.
those are notoriously bad boards. i have worked on 2 or 3 of those boards and founds its adefect on some voltage regulator on motherboard..
best thing u can do is upgrade motherboard and cpu and ram in a combo.. don't forget power supply unit, new stuff needs at least 350watts
Nov 06, 2007 | ASUS A7V8X Motherboard
AOpen AX4SG Max Motherboard Logo
71 people viewed this question
Top AOpen Computers & Internet Experts
Michael Galve
Michael Galve
David
David
Alun Cox
Are you an AOpen Computer and Internet Expert? Answer questions, earn points and help others
