Question about Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304)
I have a belkin wireless router how do i set the password on it i am using vista
  • 728 Answers
Hi v_venom,
What you need to do is open your internet browser and in the address line type in 192.168.2.1. And I'm assuming you've got the router hooked up properly. Once you type that address a user name and password dialog box will appear. Leave the password blank and click "Login" On the right side menu options, click on System Settings, and it will allow you to enter a new password for the modem.
Good Luck,
Mark
P.S. Please don't forget to leave a rating.
Posted on Feb 18, 2009
I have an HP desktop that runs VIsta that will connect to my wireless router but not the internet.
    , click All Programs, and then click Accessories.
  2. Right-click Command Prompt, and then click Run as Administrator. securityshield.jpg
    If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. At the command prompt, type the following command, and then press ENTER: netsh interface tcp set global autotuninglevel=disabled
    This command disables the Receive Window Auto-Tuning feature.
  4. Close the Command Prompt window.
  5. Restart the computer.
  6. Also try here
How to Fix Local Only or Limited Connectivity in Vista
Jan 22, 2014 | Belkin Components Belkin N450 DB Wireless...
Wanna know how to secure my belkin wireless G router.
Setting the router's administrator password
All Belkin Router's ship without an admin password. If you require an admin password then follow the below instructions.
Setup steps:
  1. Connect the computer to one of the four LAN ports on the router.
  2. Open a web browser on the computer.
  3. In the address bar of the web browser, type http://192.168.2.1
  4. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
  5. Click on System Settings under Utilities on the left-hand side of the opened page.
  6. You will see a feature called, "Administrator Password". Type in your current password (default leave blank).
  7. Click "Apply Changes". Your new password is now active.
Note: Do not forget the new password and keep it somewhere safe. If you forget your password, you'll be unable to access your router's settings. If you forget or lose your password, you'll need to "Perform a hardware reset on the router". This will reset the password to its default, as well as erase any and all other settings you may have changed
Configure Wireless Security on Belkin Router - Enable WPA and WEP Why should we setup wireless Security on Belkin Wireless Router ?
After configuring your Belkin router you should secure your wireless network using proper wireless encryption. It can keep wireless hackers away from your wireless network and the unwanted sharing of your Internet connection. In order to know how to login and configure your Belkin wireless router click on the link below.
How to Setup Belkin Wireless Router
Setup Wireless Security in Belkin Wireless Router
Now I hope you just followed the steps mentioned in the above link and log in to your Belkin Wireless Router. In order to enable wireless security on your Belkin router click on Security Under wireless. ( Security tab present on the left side of Belkin configuration page).
You can select either WEP or WPA to secure your Belkin Wireless network. To know more about WPA and WEP click on the link below.
Which is better WEP or WPA on your Wireless network
Enable WEP in Belkin Wireless Router
To select WEP for your Belkin wireless network ,click on security mode drop menu and select WEP. WEP is of two kinds WEP 64 bit encryption and WEP 128 bit wireless encryption. You can type your PassPhrase and generate instant wireless key for your Belkin wireless network.
After generating the wireless key, you should save settings by click on Apply changes. Now onwards to login to your Belkin wireless network, you need this wireless key.
Enable WPA in Belkin Wireless Router
WPA is more secure than WEP. To enable WPA on your Belkin router, select WPA from security mode drop down menu.
You should enter a pre-shared key to enable WPA security on your Router. Don't forget to save this WPA settings.
Aug 28, 2011 | Computers & Internet
Laptop won't connect to the router
Let's start with the easy first. It's a ROUTER issue. If it came with a CD, DO NOT RUN IT!!! You will not like the result when Belkin tries to take over your wireless card, especially in Vista.
The best you can hope for is Plug in the Belkin to your Modem. If it's DSL, you probably have a PPPoE connection and there's a username and password TO THE INTERNET> If it's a Cable modem, you probably use DHCP. Hope for that, because out of the box the Belkin is looking for DHCP. Plug your computer into the router and see if it connects.
Set your computer for Obtain a DHCP and see if your computer gets 192.168.2.x (possibly 2). Now, open Internet Explorer (IE) and type in 192.168.2.1 in the address bar (no http, no www, just the numbers). If it logs you in, you're all set to make the changes to the router, no password is required on initial login. If for some strange reason the router does not give out DHCP addresses, manually set the network card to use 192.168.2.x (anything but 1)
the mask at 255.255.255.0 and the gateway at 192.168.2.1.
Set your wireless up with the wireless access tab and set your security for the wireless login. I use WEP with the 64 bit password of 1011121314.
All the above was for the easy. If you're using something ugly like an AT&T or Verizon DSL and you need PPPoE settings, you need to follow the instructions for your specific router to set it up. It may require the assistance of the Telco, as they can direct you into their modem to turn on bridged mode and the like. Since you can get into it by just plugging in the computer directly to the modem, I'm thinking that DHCP settings will work.
Please post back and mention your country and the exact number of the Belkin router. I don't know what version software you have, but if it's new, I'm guessing Axxxx. Here's a link
http://cache-www.belkin.com/support/dl/p74559-h_f5d7230-4vaxxx_manual.pdf
Starting on pdf page 29 (25 real) are the step-by-step manual configuration instructions. If you follow along, it will tell you how to set up PPPoE and the like.
Good luck and please post back if you run into any problems.
Carl
Mar 22, 2009 | Belkin (F5D7230-4) Router (587009)
Lost password into router need reset
Use the reset button near where the AC adapter plugs in. Hold it in for at least ten seconds. This should set it back to factory, allowing you to set another password.
Jan 25, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Secutiry for BelkinF5D7230-4 router using Vista
Hi, here's a quick guide for you:
1. Connect to the router via Ethernet cable
2. Login to the router via a web browser, by typing 192.168.2.1 in the address bar
3. Click to login, leaving password blank (unless you have set a password)
4. Go to Wireless > Security. Select Security Mode WPA-PSK.
Enter your network key (password) under ‘Pre-shared key’ – make a note of it – click ‘Apply Changes’. That’s it, your wireless is encrypted.
For better security/more details:
1. Pick up a manual from Belkin UK
2. When you’re in your user interface, change the SSID and router password for a better level of security (see this tip for more details).
Hope this helps, but please come back to Fixya if anything doesn't work, or if you need more info. Good luck
Jan 20, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Belkin wireless security
plug a laptop straight into the router with a cable. then open an internet browser and type in 192.168.0.1
type in the username and password. the default will be admin for username and password for password. then close the browser and unplug the cable. it might detect wireless internet after a few seconds. if it doesn't, it is possible that you have a PC set up as the internet gateway for the laptops or something, so when you introduce encryption the laptops can't get access. in which case you should go to your wireless icon on the laptop and click that and open the connection list. double click on the wap secured connection and try to connect. it should ask for a username and password, which you have secured the wireless encryption with. enter that and it should connect to the gateway.
dunno if this helps, good luck
chris
ziraffa@hotmail.com
Dec 10, 2008 | Belkin (F5D9230-4) Wireless Router...
Belkin router problem
VISTA and wireless don't go well together. First, I would disable your firewall, you can turn it on later when everything works and play with the settings, second use the hex value instead of the password key when logging into the wireless device, third try it both with windows managing the connection and with the vendor software. Some wireless prefer one or the other depending on their compatibility with the Vista virus.
Dec 09, 2008 | Belkin (F5D9230-4) Wireless Router...
We have purchased a new notebook{higrade brand vista OS} to replace a packard bell using XP the XP laptop connected no problem the newone finds the belkin router but won't connect to the internet are...
Do you have a wireless security protocol enabled, and if so, what? Install a wired connection to the router (use an ehternet cable to connect your laptop's RJ-45--looks like a wide phone plug--into one of the Belkin router's network jacks). Go to the router's management page using your web browser (probably http://192.168.2.1). If you have not previously set the password in your router, simply leave the password field blank and CLICK "Submit". If you have previously password protected your Belkin router, use the known password. If you have forgotten your password... you'll need to reset your router.
Reest Router: there is usually a small hole into whiuch a pin or paper clip can be inserted for this purpose or a small button to press. Most Belkins--IIRC--have the button.
Once you are on the Belkin router's management page, look for the wireless link and set your security protocol to match what your wireless card is capable of, set the password, save and exit. Use the sasme password in configuring wireless networking in Windows.
Jul 17, 2008 | Belkin Computers & Internet
Help! new users for Belkin wireless router
there are several reasons why this happens. dont use belkins utility use windows utility it will ask you if you right click the icon in the tray.
Jan 07, 2008 | Belkin (F5D5231-4) Router
Wireless network security
alright... it does depend on the model of belkin itself but here goes... assuming you have windows since most people with mac are QUITE familiar with PCs Open an Internet Explorer window on your computer and type in http://192.168.2.1 in the address bar. This will take you to the Belkin router's web based configuration page.You will get a login page. Leave the password blank. Click Submit .On the left side of the page, click Channel and SSID below Wireless . . set it to have a wireless password... (again the exacts depend on your model) by doing this a computer must have that password you made to access the connection.. now depending on you computers operating system(ie: windows 95,98,200,ME,NT,XP vista or a mac) will depend on how you put this "password" into your computer... windows- START-CONTROL PANEL-(network and internet options)NETWORK CONNECTIONS-VIEW AVAILABLE WIRELESS NETWORKS and when you try to reconnect to your internet connection you will be prompted for the password... IF however your wireless adapters have their own wireless clients then you will have to contact their tech support instead of that last paragraph heres the number to belkin tech support in case your router will not allow you into the interface 1 800 2BELKIN x2263
Jun 07, 2007 | Belkin F5D7630uk4A Wireless Router
Belkin Wireless Pre-N (F5D8230-4) Router (F5D82304) Logo
37 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
steve morris
steve morris
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
