Question about DeLonghi EC155 Espresso Machine
DeLonghi EC155 Expresso Maker
I filled the resevoir to the max line and let it preheat and then hit start and it overflowed out of my two cups and all over the place. What did I do wrong??
  • 3 Answers
THE PROBLEM IS THAT YOU HAVE TO STOP THE MACHINE ONCE YOU HAVE ENOUGH IN YOUR CUP . IS NOT A COMERCIAL MACHINE THAT WOULD GIVE THE RIGHT AMOUNT AND THEN STOP ....
Posted on Mar 17, 2009
For a single shot of espresso I hold for about 17 - 20 secs and then turn of the machine and this machine does not shutdown automatically.
Posted on Sep 18, 2009
I Descaled expresso maker and 4 reservoirs later, their is still an oily residue on top,of the water coming out. What do I do. I used DeLonghi expresso maker cleaner
white vinegar is a natural de-scaler (and cheaper than those specialist chemical cleaners) Lemon juice is a natural de-greaser, try a diluted solution then rinse it through with water. ;-)
Nov 23, 2017 | DeLonghi Coffee Makers & Espresso Machines
Water leaking from underneath my delonghi ec330s
There could be a loose hose, or a hole. Try to call the number the expresso came with.
Feb 08, 2014 | DeLonghi EC330-s Pump Espresso Maker
I have very little pressure when making an expreeso it can take 5 mins to fill a small cup any suggestions please
I had that problem once when I ground my coffee too fine? Perhaps your grounds are too fine or your packing too much in. Try a bit courser grind and maybe not so much and not stamp it too hard? Hope that works!
Jul 25, 2011 | DeLonghi EC155 Espresso Machine
We received a 14 Cup Delonghi coffee maker DC312T and the carafe leaks. We love the coffee maker, & do not wish to return the unit. It was ordered on-line... All we need is a replacement carafe. ...
Sorry to read about your problem, I hope this helps you out.
Contact Delonghi at Delonghi.com
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 04, 2011 | DeLonghi Microwave Ovens
Cannot find replacement carafe
https://www.delonghi-accessories.com/index.php
the carafe is technically a different serial number EH1254 and technically is a 12 cup (but fills to 14) but this is the correct one for the DC312T. However, the leaking seems a constant problem (we ordered a replacement via ebay and it did that too). Someone mentioned sticking puddy underneath so it does not spill
Nov 20, 2010 | DeLonghi DC312T 14-Cup Coffee Maker
Delonghi EC 155 does not make coffee even after I put new filter
DeLonghi EC155 Espresso Machine so what does it do?Possible nothing,and do you know your last time you ran vingar though it to CLean it out?Normally solution is Vingar depend on size put 1-cup Vingar,half cup water,run it though.then run only water then next step in full pot,do this twice.Should work fine.
Aug 08, 2010 | DeLonghi EC155 Espresso Machine
Steam knob won't turn on brand new DeLonghi EC155
Try turning it COUNTER-CLOCKWISE. This is was got it "unstuck" for me.
Feb 21, 2010 | DeLonghi EC155 Espresso Machine
Problems with handle alignment
I had to use some olive oil around the outside of the filter cup holder to get it to move all the way to the right. After the first couple of times I was able to get it on straight without any oil...
Mar 15, 2008 | DeLonghi EC155 Espresso Machine
Keurig Special Edition B60
I assume your coffe maker used to produce more coffee for each use. Roughly 6 ounces per large cup, and now is only making 3 oz. cups.
If your coffee maker is sputtering and not able to "suck" enough water to fill your cups of coffee it is most likely due to cavitation caused in the little pump due to a stoppage, which is most likely lime or scale buildup somewhere in the pump line.
To fix it, don't take your coffee maker apart. Get a bottle of distilled white vinegar, and pour it straight into the empty water resevoir. Press brew with no coffee pod so you are just running the vinegar through the system. Pour the vinegar out of the cup and back into the resevoir. Add some ice to cool it off. Repeat about 10 times. This should clear out the toughest lime scale clog.
After you notice the cups are filling full of water, Replace the vinegar with fresh water. Run about 5 or 6 cups of fresh water through the system to get rid of the vinegar.
Make coffee/tea/whatever.
Jade
Oct 06, 2007 | Keurig Special Edition B60 Coffee Maker
DeLonghi EC155 Espresso Machine Logo
958 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
