Car turns off after a few minutes of turning on car. As Iam driving the car will just turn off, will restart car will be on a second or two and will die. I disconnect the power cable the car has no issues. Have changed batteries same symtom. I am suspecting the aternator?
  • 544 Answers
Thank you for using Fixya.com
please go to this site it will help you to solved your problem..
thank you.
http://www.expertvillage.com/video/13359_alternator-diagnosis.htm
Posted on Feb 18, 2009
  • 716 Answers
Yeah Id Replace The Alternator Asap. If I Am Getting Your Statement Right You Disconnect The Battery And The Car Dies Thats The Alternator If The Car Doesn't Die It's The Battery.
  • Michael Fisher
    Michael Fisher Feb 18, 2009
    Also The Alternator Can Be Checked At Most Local Auto Parts Stores For Free.
  • 19,396 Answers
The best thing to do is a code reading scan on the ecu to troubleshoot the problem.
  • Ginko
    Ginko Feb 18, 2009
    If the problem is the battery or the alternator , the car will not start using the ignition, as it wont have enough battery charge to spin the starter motor.
    If the alternator is not working , the battery will drain while you are driving and the car won't crank.
    If the car stops shortly after starting, and whils idling, then the problem can be related to the air intake or air filter, or to an incorrect idle settings.
    The best thing to do is connecting the car computer ECU to an ODBII code reader and having a scan done .
    This will return error codes that can tell you where the problem is.
    This is a code reader:
    OBD-II - On-Board Diagnostic System
Bravia klv 32ex300. Runs for a few minutes, then turns off. Restarts twice then turns off and won't restart. What's wrong?
most common problem is main filter cap aster which is in power board if find defective please change but if its ok then replace main board because system ic internally leaking
Aug 29, 2015 | Sony Televison & Video
Hi I have Panasonic camcorder hoc-hs700 when turn on camra after few second later message on screen hdd error occurred please turn off unit and on again I have done that several time .but not luck pl
Hello there .
Well according to a manual,
Sounds like the Hard Drive is faulty.
"ERROR OCCURRED. PLEASE TURN UNIT OFF, THEN TURN ON AGAIN." is displayed.
The unit has automatically detected an error. Restart
the unit by turning the power off and on.
The power will be turned off in about 1 minute if the
power is not turned off and on.
Repair is needed if it is repeatedly displayed even if it is restarted. Detach the power connected, contact consumer support. ( Do not attempt to repair the unit by yourself
So......why not try a FORMAT of the Hard disk drive which seems to be at fault....nothing to lose friend Worth a try !!!!
Page 142 of this manual http://service.us.panasonic.com/OPERMANPDF/HDCHS700-MUL.PDF
Sep 16, 2014 | Lands Phones
1993 Oldsmobile cutlass ciera is stalling and won't restart after engine is turned off
Two thing, maintenance will be first[tune up,fuel filter,air filter].Second could be crankshaft sensor.
Mar 14, 2013 | 1989 Oldsmobile Cutlass Ciera
My 1993 nissan sentra 1.6 wont run and check engine light wont turn on,bulb is ok
Could be any of several things. If the crank sensor is marginal and not sending pulses, the fuel pump is shut off. This is for safety. The pump is energized for a few seconds as key is turned in preparation for starting then engine must rotate normally to keep the pump on. If it stops, in a few seconds the fuel is cut off.
Aug 17, 2012 | 1993 Nissan Sentra 4 Door
My car will start but after about 15-20 minutes of driving, the car will completly turn off...i have to wait for the car to cool down for about 30 minutes before i can restart again and drive it.. If i...
if light on dash is on, then it sounds like a bad crank sensor. shuts off while driving down road, then will not start for about 15 minutes. heres more causes:: car shuts off when tempurature gets to normal-- low coolant, failing coolant tempurature sensor, air in water pump, failed radiator fan, it takes 10 to 15 minutes for a car to warm up. check or replace coolant temp. sensor if above is ok. have a good day !
May 04, 2011 | 1995 Geo Prizm
My Samsung hcn4226w won't stay on.
There are many protective circuits inside the set that will shut it down if a problem is detected. It sounds like there are intermittant detections of problems and the "restart" temporarily clears the problem. If the unit is no longer under warranty, open up the back with the set unplugged and try reseating all of the boards and connectors. The trip may have jared a few things loose. Update this with the results.
Thanks,
Dan
Aug 20, 2009 | Samsung HCN4226W 42" Rear Projection...
Car dies while driving
It could be something as simple as a bad or loose ground wire but the hard part is finding it.
Good luck
Sam
May 13, 2009 | 1993 Pontiac Grand Prix
Starting problems
Clean & inspect battery connections & have battery load tested.
Dec 19, 2008 | 1996 Dodge Caravan
Fisher/Paykel Smart-drive 5.5 auto washing machine was on final spin cycle and starte making unbalanced load noises. I stopped it,redistributed load and tried to restart. It restarted in spasms so I took...
sound like the controller opr micro board is sick. unplug leave off for a few minutes then power up again and try empty wash cycle if its the same call the engineers.
Apr 22, 2008 | Washing Machines
15 people viewed this question
 Grubhead
Grubhead
