Question about Samsung HL-P5063W 50" Rear Projection HDTV
Hlp5063w 50'' DLP samsung Experiancing The Word LAMP green letters flashing for 20 second followed by clicking noise then shut off.. then repeats that same process twice then TIMER / STANDBY/TEMP/LAMP flashing all at once ? I replaced the bulb but there is no power to the bulb .... I am thinking it might be the ballast .... Also when i took the color wheel out , i spun the wheel .... has a grinding sound but silent when moving fast . . Any feedback would help
    Scholar:
  • 73 Answers
Sounds like you've already gotten into the repairs. The three major things that fail on DLP are the bulb, the ballast and the color wheel. If your bulb is new and you aren't getting anywhere, replace the ballast, if that is still a no go, then move on to the color wheel. If replacing those three doesn't fix the problem, you will have to whip out the multimeter and start looking for problems on the PSB. You can get a ballast on ebay for about $100. Start there. The color wheel should be very freely moving. If something is grinding and hindering the movement at all, you need to replace it. That grinding may not seem like much but it is likely enough to keep the wheel from spinning at proper speeds. The sensor then kicks in and tells the brain that there is a problem and the brain keeps the ballast from firing the lamp.
Good luck.
Posted on Mar 11, 2009
DLP 65 in. wont turn on. Lights flash . Red light first followed by 9 green lights flashing-then shuts off.Repeats this pattern.My lamp is foggy but not blown. Is it the lamp? Lamp is 1 yr old.
While i don't recall that particular pro lemme alot of Toshiba sets had an issue with the ballast boars. Basically over time the solder connection s get hot and cool so much that the joints Crack and breal. The ballast board may need to be resoldered. If you choose to try this yourself...be advised there are very high voltages inside a tv that can seriously hurt or kill you.
Jul 07, 2016 | Toshiba Televison & Video
I have a 50 inch DLP samsung and it wont power on after making a lot of noise (I replaced the lamp) worked fine for a few days now the red light and the right side green light is blinking. any sugge
The answers above are correct. It's either the lamp or the color wheel. Testing the lamp is pretty straight forward. Use an Ohm meter to see if the it's filament has continuity. It's unlikely that a good color wheel would fail immediately after changing the lamp. Look to see if some wiring is out of place and rubbing the wheel causing the noise you described. A jammed but otherwise good color wheel would cause the TV to shut down and display an error code.
Sep 12, 2014 | Samsung HL-S5087W DLP TV
Tv keeps shutting itself off. the power button will then begin flashing in green lighting the words"timer and lamp' and in red letters the word "standby". i can press the power button to turn the tv back...
The first thing to try is a new lamp. There should be an orange or red tag on the left side of your set that has the lamp number on it. The number will look something likr BP96-01434A. It probably won't be this exact number but will have that sort of format. Google "DLP lamp" and you'll find numerous sites that sell lamps. Shop around for the best price.
Sep 01, 2010 | Samsung 61" Slim-Depth DLP HDTV
Samsung dlp hls6186w, picture has darkened, could it be the lamp or is it the colour wheel??... tv is making sounds...I thought it was the fan, the fan looks okay??? It also shuts down once and a while...
The lamp is the only thing that will cause the picture to go darker. According to the model you have the lamp part number is BP96-01472A. The noise you hear could possibly be the color wheel itself. The way to tell is when you turn off the TV the lamp stays on for about 10 seconds longer. Once the lamp shuts off if that noise goes away then it is a bad color wheel. Any noises past that would be a fan. Please take a moment to rate my answer. Thanks...
Dec 02, 2009 | Samsung HLS6186W 61 in. Plasma HDTV
Samsung DLP HL-P5063W. . .no lamp!
Remove the rear cover and check the lamp cover switch. Earlier versions used a black plastic switch holder that may break due to improper assembly. The part number for the holder is BP61-01240A. Newer versions use a metal tab attached to the engine. In this case, improper assembly may cause the lamp cover switch to be extended past its range, either breaking the switch or causing it to have an open contact. Replace the switch with BP91-01231A.
Note that in these models, when reinstalling the rear cover, it is best to remove the lamp cover first, install the rear cover, then install the lamp cover. This will make sure that the lamp switch is properly engaged.
May 02, 2009 | Samsung HL-S5087W DLP TV
Green flashes then tv turns off
or a new lamp. you could first replace the lamp.
the screen might work fine for a couple of seconds, but then it fades away or deteriorates. This means the lamp is going bad.
Aug 23, 2008 | Sony KP-51HW40 51" Rear Projection...
Tv went pop
All you can do is get it repaired or replace. Take the receipt (if you still have it) to the retailer you bought it from and ask about it. Alternative, phone Samsung (number is probably in the instruction manual that came with the TV, or look on their website) and ask if they can do anything about it.
Jun 10, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Very noisy when turned on, then shuts down, Samsung 61 inch
Color wheel defective. Replace it with the new designed color wheel. The lamp is ok.
Dec 10, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
You will need to have it diagnosed if you do not have the service manual, or the knowledge of how these circuits work. I can tell you to replace this or that but it would be a guess! You need to start measuring the voltages on the ballast circuit, as I have seen door switches, fan sensors, heat sensors cause all of your symptoms as well. Good Luck
Jul 24, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
Samsung HL-P5063W 50" Rear Projection HDTV Logo
773 people viewed this question
Jerry Greenberg
Jerry Greenberg
