Question about La Pavoni PC-16 Espresso Machine
Water leaking from the group
I have a 16cup mchn - using it for 16 years now. For some time now there is steam/water leaking from the group when you heat the machine. This probably is some sort of seal or gasket problem but i dont know how to fix it. Steam/water also leaks from the frothing attachment.
    Scholar:
  • 36 Answers
You can buy a service kit for your machine at www.theespressoshop.co.uk and that contains all replacable gaskets and washers and gives you an exploded diagram and sachet of grease and descaler to get your machine back in as new working order. The service kit you require is the "old group service kit" and is about £20. If you go to the website above and click on the la pavoni machine on the right hand side of the home page it will give you the full parts list.
All the best
LaPavoniBoy
Posted on May 28, 2009
Ascaso Dream steam wand leak
Hi Emily,
You have 2 issues.
Steam wand leaking while making coffee - This indicates that the seals on the steam tap o rings need replacing.
Coffee pouring over the handle when making coffee - this indicates that the group gasket needs replacing.
Replacing the group gasket is easy takes 10 min
Replacing the o rings on the steam tap may take a little longer..
All you need is a group service kit Ascaso gasket kit Dream Arc Basic
Feb 28, 2012 | Ascaso Dream Espresso Machine
My pasquini livia machine is leaking from the base of the steam wand. Perhaps it is a gasket how do you replace these?
You have to take apart the system for changing the gaskets.If you are not a technical savvy don't try for it.Here is the parts diagram for your machine.Many of my fixya customers took apart the system to change the valve and they suffered a lot to fix it again back.All the best.
1 Boiler end gasket 11 Expanse Valve 21 Group gasket 2 Heating element 12 Drain 22 Refill solenoid 3 Gasket for above 13 Pressurestat 23 Group touch pad 4 Steam + water valve 14 Main switch 24 Drip tray grill 5 Pop off valve 15 Group 25 Water flow meter 6 Bleed valve 16 Group solenoid 26 Drip tray 7 Water level Probe 17 Group handle 27 Basket 8 Auto refill relay effect 18 Filter basket single 28 Steam-water valve knob 9 Heater exchanger injector 19 Plastic gasket 29 Manual refill valve 10 Heat wand 20 Site glass 30 Shower screen
the gasket look like this.I will cost around 12$.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Dec 29, 2010 | Pasquini Livietta Espresso Machine
Gaggia Syncrony logic rapid steam machine leaks water from bottom
Check the chamber under the white plastic valve behind the brew unit, it might be blocked with coffee.
Apr 13, 2010 | Coffee Makers & Espresso Machines
My Pavoni Pro started leaking water from its base. It doesn't let steam escape, and it still makes espresso, but water leaks out slowly I guess from the base (like 1 cup per hour or so). Is it a gasket or...
You most likely need a boiler gasket
European Gift & Houseware
514 So. 5TH Ave. Mt. Vernon N. Y. 10550 Phone: (914) 664-3448 ext. 102, 106, 107 Toll-Free: (800) 927-0277 Fax: (914) 664-3257 E-mail: sales@europeangift.com
Feb 13, 2010 | La Pavoni "PROFESSIONAL Chrome" 16Cup
Water Leaks from the head gasket while heating up to use steam
This is a result of the water temperature in the boiler increasing, thereby expelling water that may remain in the lines out of their respective exit points. A solution may be to place a container under the group head to catch the water, or opening the steam valve partially to allow the water to exit through the steam wand (again placing a vessel/cup/pitcher there to catch the water). This is a problem that even higher end (dual-boiler) models have, due to the necessary purging of water that accumulates in the steam wand during down-time.
Don't look at it as a problem, but simply as a quirk that single-boiler machines have. If you are still irked by the issue, consider buying an inexpensive manual frother (Bodum makes these) to froth and heat your milk (in the microwave after frothing) separately. An added plus is that you can do this while you make your espresso, so if you make primarily milk-based drinks (latte, capps etc.) you'll save on time.
Dec 21, 2009 | Saeco Starbucks Sirena Espresso Machine
No water coming out
Sounds like the gaskets need replacing.
A faulty steam solenoid can cause no water from the group head too
Oct 18, 2009 | Gaggia Classic Espresso Machine
Steam Wand Leaking on La Pavoni Espresso Si
I HAD the same problem. I fixed it for 50 cents. It takes the removal of 4 screws (2 phillips on top, 2 long standard on bottom by the group) to remove the top to access the steam wand valve. Once the the top (and the chrome bezel) is removed, then screw out the valve counterclockwise buy ALL THE WAY until it comes out. There are 2 O-rings on the stem of the valve that wear out, Cut these off with a sharp knife, go to your local hardware store, buy 2 new ones for 50 cents, install new O-rings, and reverse the disassembly procedure. Voila, no more leaky steam valve!
Jun 20, 2009 | La Pavoni Espresso Si PAB-16 Espresso...
Water is leaking, while the machine heats water for steaming
The steam valve tap rod needs to be replaced, or check machine if it has a plastic steam valve, Gaggia designed a new Stainless steel steam valve for the compact machine.
May 23, 2009 | Gaggia Syncrony Compact Coffee...
Leaking water from the group and steam spout
You will need to take the machine apart completely as there are more gaskets inside the group head. You can buy an old group service kit at www.theespressoshop.co.uk for about £20 and it comes with an exploded diagram so you can see what goes where. Don't worry there is no technical mechanical solenoid like the last comment stated. I repair these machines for a living and all it needs is a good service.
All the best
LaPavoniBoy
Nov 13, 2008 | La Pavoni "PROFESSIONAL Chrome" 16Cup
Steam escapes while machine tries to heat up
That big nut is the pressure relief valve. It should normally be closed, unless the machine overheats, in which case it will vent the steam, thereby preventing an explosion.
The valve design means that it's somewhat normal for some steam to vent as the machine heats up, but once it gets close to working temperature, it should seal.
Pavoni does now have a replacement valve that avoids this problem. When your machine needs a major service, hopefully more than 5 years from now, you may decide to get the upgraded valve fitted.
Fergus.
Aug 22, 2008 | La Pavoni "PROFESSIONAL Chrome" 16Cup
La Pavoni PC-16 Espresso Machine Logo
268 people viewed this question
Top La Pavoni Coffee Makers & Espresso Machines Experts
billconfused
Pieter Vleeshouwers
Pieter Vleeshouwers
NOEL
NOEL
Are you a La Pavoni Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
