Have checked with multimeter the elec current to the pigtail and it is good, the heating element is fine, just replaced a couple months ago. The sensors on the back, like the internal bias operating thermostat, the non-resettable thermostat, and the high limit thermostat. I still need to check the thermal cut off fuse.Don't know what else to check, or what else could be wrong.
SOURCE: Dryer won't heat?
Make sure your electrical connections are correct.
Check the voltage to the dryer element and make sure you are getting 220 volts.
Otherwise I am at a loss also...good luck
I hope this helps
Hello, Before you replaced all those parts did you check each with a multimeter by performing an ohms test or measuring for continuity? By doing this it would tell if any of the parts that you had replaced were at fault. You can also conduct the same test on the heater as well. when performing any ohms or continuity test make sure the unit is unplugged and that you also unplug the part as well from the wires that are connected to it. I await your reply if you have any other questions. Thank you
Rick
