Question about Minolta DiALTA DI2510F All-In-One Laser Printer
Getting error C0f32
I have almost everthing but no help still getting error C0f32 please help
  • Anonymous Apr 14, 2009
    GET EROR CODE C0F32 ON Bizhub 162 minolta
HOLA BUENO YO TENGO 2 MAQUINA MINOLTA 2510,3010 ME GUSTARIA SABER LOS CODIGOS DE AVERIA POR FAVOR LES AGRADECERIA MUCHISIMO .
Posted on Nov 18, 2009
Konica minolta buzz 211 printer error c0f32 ?
Off-on and press the stop bottom :) its trouble reset
Aug 23, 2015 | Konica Minolta Office Equipment & Supplies
Error code cof32
C0F32
Faulty ATDC Sensor
- The measurement taken by the ATDC Sensor (UN1) at a time 2.0 sec. after the Main Motor (M1) has started turning is less than 5% (greater than 4.63 V).
- The measurement taken by the ATDC Sensor (UN1) at a time 2.0 sec. after the Main Motor (M1) has started turning is 19% or more (1.41 V or less).
Jan 31, 2014 | Minolta DI-2010F Copier
C0F32 Minolta bizhub 210 and 211
C0f32 that means ATDC error, when toner amount in developer is uneven then this code will display, so you have to replace the developer and do the atdc auto adjust the code will remove.
please always mention the copy counter and life of consumables every time when ask the qustion.
Sep 15, 2012 | Konica Minolta DiALTA Di183F Copier
How to clear error code C0F32
How to clear error code c0f32 problems
by khan
Jan 16, 2011 | Minolta Di3510 Fax
How to fix error c0f32 in konica minolta bizhub 180
C0F32 is relatd to Developer, enter in to programming............. utility, stop, 0, 0, stop, 0, 1
Adjust...... ATDC Gain if for example 142 ,make it 152 then see, if problem remain same then change Developer, as i had experience Konica 7115/7118/7120/ minolta di152 Drum , Developer are same,
Hope it wil help
Mar 24, 2010 | Konica Minolta bizhub 180 All-In-One...
Minolta di20 c0f32 error?
C0F32 Faulty ATDC Sensor E1
The value of data read by E1 is faulty. [E1 reading is 7% or
less (3.92V or more) or 19% or more (1.41V or less).]
C0F32, C0F33
Are PJ40, CN50, CN17, and PWBA
PJ15A connected properly? Connect them properly.
Is the CN50 connection dirty? Clean
Is “C0F32” or “C0F33” displayed
even when an I/C with the same T/
C as that of a new one has been
installed? Change the I/C with a new one
installed and an F8 operation run?
(Be sure to record the ATDC control
voltage setting value if an F8 operation
is to be run.)
YES Change PWB-A, install the old I/C,
and return the ATDC control voltage
setting to the value recorded. If
“C0F32” or “C0F33” redisplayed,
change the I/C with a new one.
is to be run.)
NO Change the I/C with a new one.
Jan 25, 2010 | Minolta Office Equipment & Supplies
Code error fo32
My think your error C0F32:
PJ15A connected properly? (NO) Connect them properly.
Is the CN50 connection dirty?(YES)YES Clean.
installed?(NO)Change the I/C with a new one.
is to be run.) (YES) Change PWB-A, install the old I/C,
change the I/C with a new one. (NO) Change the I/C with a new one.
if you are not tech pleas call your tech service.
Nov 26, 2009 | Konica Minolta DiALTA Di200 Copier
C0F32 error displayed in new machine just in 25000 copies
Is the copier is brand new out of the box? If so you have to call a dealer or a good friend that works on them to help you by pass the set-up error code. They put that little curve in to stop none dealer from installing there copiers.. Good Luck......
Jul 29, 2009 | Konica Minolta DiALTA Di200 Copier
Please Help Kyocera KM-1510 Grayscale Copier & Minolta D251 C0F32
check the exp.lamp . it mzay be blinking at the time of scanning the original.
Feb 17, 2009 | Kyocera KM-1510 Copier
Minolta DiALTA DI2510F All-In-One Laser Printer Logo
1,507 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
