Question about Dell Dimension 3000 PC Desktop
CAN'T CHANGE MY VOLUME SETTINGS ? COMPUTOR DOESN'T HAS SPEAKER HOOK UPS !
  • pat ozane Feb 22, 2009
    THANKS VERY MUCH !! I WILL PURCHASE ME ONE ! THANKS AGAIN !!!
  • 51 Answers
If there isn't a little green 1/8 inch audio jack for speakers anywhere on your system then you do in fact need a sound card which can be cheap and easy to install. if you do have a sound card already and you just arent seeing volume control then your sound card drivers are probably not installed and to find out drivers you need you need to figure out what sound card you have by physically looking at the card. or you can try running microsoft update in custom mode and you might get lucky and under hardware drivers you might get what you need.
Posted on Feb 20, 2009
  • Dell Master
  • 19,396 Answers
If the computer is the dell in title, then the speakers socket is the green jack , you find one at the back of computer, and one behind the front sliding panel.
If the computer is different from the one in title, then you may need to install an audio card into the computer.
In this case a simple solution may be installing an external audio card, klike the ones below.
SoundWave 7.1 Audio Adapter
USB Audio Adapter 3D Sound 5.1 CH Controller
If instead your computer has the audio jack , but has no sount it may need driver setup.
In that case follow instructions on link below to download and install drivers.
Dell Drivers and Downloads
Posted on Feb 18, 2009
My logitech speakers mo.ls11 sound is blurred when volume is increased
Adjust the volume level of the TV to low while the Logitech Speaker volume is at the middle... try changing volume of both TV and speaker to achieve satisfying results.
Apr 26, 2012 | Logitech Audio Players & Recorders
I just pick up a used LW 10 Powered sub and 2 channel sherwood receiver.What is the preffered method of hook up up the sub with out a pre sub out?
"Sherwood Receiver" doesn't really tell us much about that end of the scenario.
Look at this picture of the sub amp.
http://cgi.ebay.com.sg/CERWIN-VEGA-LW-10-SUBWOOFER-AMPLIFIER-Speaker-Blade-Amp-/350444290153
You COULD run the Main speaker output to the large Red/Black speaker inputs, then some more wires Out from the other Red/Black connectors to your Main Speakers. That way your amp volume control will affect both equally.
Tweak the sub volume, crossover and phase to match it up to your mains.
May 15, 2011 | Cerwin Vega LW10 Subwoofer
I have a 1997 aiwa stereo with surround sound, i dont have all the speakers hooked up, but when i am listening to music the radio volume will get louder then softer. if you look at the display on the...
Regardingt he display differing from the actual speaker complement, THAT is up to the user to set up. The unit probably doesn't falsely 'sense' the phantom speakers.
Have you looked at the manual?
The specific product you're inquiring about is not showing in your post. Name the make and model first, then we'll look for the manual. Then (maybe) find a solution. You might find it at the manufacturer's support site or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usermanualguide.com
vinylengine.com
Google search: "(product) manual"
May 04, 2011 | Audio Players & Recorders
No sound
When my sound output set to off and I use the remote to change volume; it tells me speakers off.
Try a different output method: hook up headphones, other speaker type... these answers should help you find a solution.
Feb 27, 2010 | Televison & Video
Speakers in pc mode
i have the same exact problem with mine i tried
(Start -> Control Panel -> Sounds and Audio-> Then in the speaker settings box click advanced -> then click the drop down bar and click monitor speakers.) it didn't help for me but you might find it help full..
Jun 17, 2008 | Philips Magnavox 27MS343S 27" TV
Sharp aquos LC 37D43U
If you have satellite, I am assuming you at least have a converter box hooked up. If so, make sure the converter box volume is set at its max. There may even be a volume setting in the converter menu that forces the volume output of the box to always be at full so that you don't get variations in audio when changing channels. Warning...before attempting this, please turn down the volume on your tv to at least the middle setting so you don't blow your tv speakers if this works.
Jan 20, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Subwoofer volume and sound
i had the same problem when i tried to adjust speaker output levels, distance and equalizer manually without using audessy setup..so i reset everything to factory setting (0s)..and then ran
audessy setup..reduce volume on your subwoofer to slightly above minimum(behind the subwoofer) before running the setup..once audessy setup is completed successfully..i started changing setup
manually..changed speaker config for front speaker to small (it is set as large by audessy setup), this should automatically adjust center and other speaker configuration (if not make sure to set them to small as well), then set the cross over frequency to 120..increase the volume on your subwoofer and now you should hear it fire..if this does not help..try playing some rock music with all channel streo mode..if your subwoofer does not fire even for this..then take the system back for exchange..
Dec 28, 2007 | Onkyo HT-SR800 System
Wsp150
Turn up your computor volume all the way up and adjust the volume at the speaker,..Ted
Dec 13, 2007 | RCA WSP150 Main / Stereo Speaker
Wsp150 transmitter failure
The following alternative may solve your problem:
Check to make sure the volume on the audio source is set to a normal volume. If the volume is too low, the transmitter will not turn on.
Apr 01, 2007 | RCA WSP150 Main / Stereo Speaker
Dell Dimension 3000 PC Desktop Logo
1,222 people viewed this question
Alun Cox
