Question about AMD Athlon 64 X2 3800+ Dual Core Processor - Socket 939 (AMDX23800)
I want to know about different cpu processor.how they are working and evolution of cpu processor
  • googli10 Feb 19, 2009
    i wan more informtion on processor. treat me as 0 about processor.tell me the proper answer
  • Roberta Smith
    Roberta Smith May 11, 2010
    doing your homework are you ?
  • 37 Answers
PROCESSOR IS BASICALLY KNOWN FOR ITS BEST PERFORMANCE AND SPEED. CURRENTLY AMD PROCESSORS ARE KNOWN FOR ITS BEST PERFORANCE AT LOWEST RATES. BUT IF YOU NEED A BETTER PERFORMANCE YOU SHOULD GO TO INTEL PROCESSORS. COZ TODAY INTEL PROCESSORS ARE THE WORLDS FASTEST PROCESSORS. THE ONLY LIMITATONS FOR THIS PROCESSORS IS ITS PRICE.
BUT IF YOU NEED TO PLAY GAMES AND WANT TO WORK IN MULTI TASKING YOU I ADVICE U TO SHIFT INTO INTEL PROCESSOR.
YOU CAN COMPARE THE BOTH PROCESSORS. JUST GO TO GOOGLE.COM AND TYPE COMPARE PROCESSORS IN SEARCH. THE RESULTS WILL SHOWS YOU THE SAME THING AS I SAID.
BYE
NICE DAY.
PLS. RATE MY SOLUTION.
KETAN
Posted on Feb 18, 2009
I have an el1333g desktop it has a amd 64x2 2.4 prosscer in how much bigger can i go
Select the "Start Menu." Click to select "Control Panel." This will open a new window with several clickable options. Choose "System and Maintenance," typically located near the top left-hand corner of the Control Panel Click to select "System" from the new list of options Look for the CPU's stock speed as indicated under the "Processor" heading. This is a ballpark, relatively close estimate of your computer's CPU speed, as provided by the manufacturer. Checking the Stock CPU Speed in Windows XP Click the "Start Menu. Right-click on "My Computer." Select "Properties." By default the Properties window will usually be set to the "General" tab, but if the window is set to a different tab you'll need to click on the "General" tab located near the top of the window. Check the CPU rating as listed underneath the "Computer" heading. b> Determining Real-Time CPU Speed Go to CPU Speed Professional's website (see Below) and download "CPU Speed Professional." While other free CPU clocks exist, many are beta programs with glitches and unwanted bugs. CPU Speed Professional is well-known and reputable, receiving the "Vista 5 Star Software Award" according to its website. Install the recently downloaded " http://download.cnet.com/cpu-speed-professional/3000-2086_4-10833139.html " file by double-clicking on it and following on-screen prompts to complete the automated install procedure. Open CPU Speed Professional. Click "Test Your Speed" on the main program interface. A real-time, active measurement of your CPU speed will appear numerically, and CPU Speed Professional will also display your CPU speed on a stylish meter for easy visual comprehension. Get a Faster Processor b> Start by visiting Intel.com (see the Below ) to research and figure out which processor you want. http://www.intel.com/products/processor/index.htm Read the page and click on the links to the different processor families. Once inside the processor families you can look at the specifications and speeds of the processors. There are three main ways of determining the speed of a processor. First is the speed, measured in GHz. The higher the speed (example: 2.4 GHz) the faster the processor. Second is the L2 cache, measured in MB (example: 2 MB L2 Cache). The L2 cache is kind of like the CPU's own RAM; the larger the cache, the faster your computer operation will be. Finally, there is the Front Side Bus (FSB) speed. The FSB speed is the speed that bits of data are fed through the processor. FSB is measured in MHz (example: 1066 MHz FSB). Once you have an idea of the processor you want, continue to step two. Ensure that your processor of choice will be compatible with your current system. You can do this by checking the documentation for your motherboard. Look through the manual to find out what its CPU socket type is (example: LGA775). There can and will be different socket types on CPUs so ensure your processor choices match up with your motherboard before continuing. The socket (or package) type will be listed in the specifications of any processor you look at. Worth noting is that some motherboards also impose a limit for how high the FSB of a processor can be. While a higher FSB processor will still work with a lower FSB motherboard, processors have to go by the speed limit imposed by the motherboard. Keeping this in mind, as long as the socket type is the same on both parts, they will be compatible. Visit Newegg.com (see Below) or a similar computer or electronics store of your choice and nose around the processor section of the site. http://www.newegg.com/Store/Category.aspx?Category=34&name=CPUs-Processors You should be able to find the processor model you are after. Decide on a processor. If you've already done the research suggested in steps one and two, you should have a decent idea of the kind you want. Choose among the models you selected and add it to your cart, ensuring that the socket type of your new processor will match your motherboard. Once purchased, you should receive it within a few days.
Hope this helps.
Jan 21, 2013 | eMachines EL1333G03w (884483010820) PC...
Need to upgrade cpu for using multiple progams at on time, can cpu be upgraded on this older model compaq presario S0000 / 8000 series computer
As you have stated it's a Compaq Presario S0000/S8000 SERIES desktop computer.
One of the S0000/S8000 series.
Without knowing the exact model number I have no idea of what hardware is installed on the motherboard.
On the back of the computer tower, or up on the side, is a white Service Tag.
P/N = Product Number. This is the exact model number I need.
Also; Going to HP Support with the exact model number may not reveal the info I need, either.
They may not list the specifications, and therefore the installed hardware, for your computer.
There is an easy way around this, however.
Use CPU-Z from CPUID.com
What info is needed in order to know if the Processor can be upgraded:
A) Processor Socket: What processor socket is installed on the motherboard. This is what the Processor sits in.
Just two examples for Intel processors; Socket 478, and LGA 775 processor socket.
1) http://en.wikipedia.org/wiki/Socket_478
With this style of processor socket, the processor socket has the socket holes, and the processor has the contact pins. (478 holes/478 pins)
2) http://en.wikipedia.org/wiki/LGA_775
With this style of processor socket, the socket has the pins, while the processor has contact pads.
There are other styles of Intel processor sockets. There are also AMD processors which can be used, and have many different processor sockets also.
B) What motherboard chipset is used.
Specifically, what Northbridge chip is used.
3) Chip and Chipset are slang terms for I.C.
Integrated Circuit,
http://en.wikipedia.org/wiki/Integrated_circuit
For your motherboard the motherboard chipset is a Northbridge chip, and a Southbridge chip.
{So aptly named Northbridge, and Southbridge, for the relation of how they sit on the motherboard.
Looking at a motherboard as if it were a map, the Processor sits to the North.
The Northbridge chip sits close to the Processor.
The Southbridge chip sits to the 'South' on the motherboard }
The Northbridge chip handles the faster capabilities of a computer.
It handles the Processor, Ram Memory, and High-speed graphics.
The Southbridge chip handles the slower capabilities of a computer.
4) Motherboard Diagram,
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
Knowing what processor socket is used, and what Northbridge chip, we can accurately determine what processors are supported.
CPU-Z is a tiny, free program that without opening your computer, tells you what hardware is installed on your motherboard.
Tells you what processor socket, and Northbridge chip are used, for one.
5) This is information on CPU-Z. Shows you a screenshot of the user interface of CPU-Z,
http://en.wikipedia.org/wiki/CPU-Z
Left-click on the CPU-Z user interface to the upper right of the page, to enlarge it.
(Under the bold CPU-Z heading)
When CPU-Z opens it automatically opens to the CPU tab.
(Central Processing Unit. Another term used is Microprocessor, or simply Processor for short)
To the right of - Package - tells you what processor socket is used.
Clicking on the Mainboard tab tells you what motherboard chipset is used.
6) CPU-Z download page,
http://www.cpuid.com/downloads/cpu-z/1.56-setup-en.exe
Left-click on Download now! in the purple rectangular box.
A small window will come up on the right side -
Opening cpu-z_1.56-setup-en.exe
Left-click right on Save File
Another small window will come up on the left.
In the header at the top of this small window, tells you where the file will download to.
In the wording may be Desktop, or My Documents, or Downloads.
Desktop: The file will be on your desktop screen.
My Documents: Left-click on Start, then on My Documents
Downloads: Left-click on Start, then on My Documents. DOUBLE-click on Downloads.
When you see the file name DOUBLE-click right on it.
Follow the easy installation instructions.
Go back to your desktop screen. Double-click on the CPU-Z icon.
When CPU-Z has loaded, come back here in a Comment, and tell me;
1) In the CPU tab, what is stated to the right of - Package
2) Left-click on the Mainboard tab.
What is stated to right of;
A) Manufacturer
B) Model
C) Chipset
D) Southbridge
Regards,
joecoolvette
Sep 11, 2011 | Computers & Internet
Hi i need more help in knowing just what type of processor chip to buy i know i need to put the same type back in my problem is i dont know what type it is my pc is acer aspire t135 1.8ghz it says on my...
Hi Paul,
Correct, you have to use the same type, but you can upgrade to a faster CPU.
According to the specs for your computer it can take the following:
AMD Sempron processor 2600+ to 3300+, 333MHz FSB
AMD Athlon processor 2800+ to 3200+, 400MHz FSB
See:
http://support.acer.com/acerpanam/desktop/0000/Acer/AspireT135/AspireT135sp2.shtml
The Athlon's are better...faster Bus. The Sempron is cheaper.
The 2 processors you describe are very similar. The difference between the 2 is that the first one is capable of running 64-bit operating systems and applications. The second one is strictly for 32-bit systems.
The next question will probably be, "What do I have?" Probably a 32-bit system. You can go with the 64-bit CPU and be safe as it can run both. You can see what your old one is by the revision number on the top of the CPU. You can use the following comparison chart to see the differences:
Sempron 3100+ Comparison
I hope this has been some help. Maybe it has just caused more questions. Just ask.
Thanks for using Fixya.
Mar 24, 2010 | Computers & Internet
I just bought a new motherboard; basically new everything, well on my old motherboard there was a CPU and on this newer better motherboard there is not a CPU. Do I need to got one? What is a CPU exactly?
first, make sure that the new mother board support the old Processors, ask the M.Board supplier about it (or google it) , and make sure you know the old processors type.If you wasn't really sure, just remove the old Processor from old M.Board, then check for the ID (such as Pentium 4, Pentium D, etc ) on top of the processor.
If the new M.Board support the Processors, then you can re use the old processors, if don't, then you don't have a choice, buy the new one that match with the new M.Board specifications.
Hope you understand.
Feb 22, 2010 | Office Equipment & Supplies
I am wanting to upgrade the cpu to a faster
You dont need to know your southbridge info or anything like that, you just need to know the socket type for the processor. If they make a processor for the socket type, then you can assume it is compatible.
Jul 17, 2009 | Toshiba Satellite M45-S331 Notebook
Difference b/w Core to duo and daul core
Core 2 Duo is a Brand name by intel to identify his class of Dual core CPU
a Dual core CPU is basically two CPU in one package, which dramatically improves performance over previous architectures.
Pentium Dual Core is another brand name by Intel to identify his new entry level CPU offer.Basically Pentium dual-core are similar to Core 2 Duos except they(pentiums) are slower and cheaper.
they both are dual core CPUs.
I would prefer a core 2 Duo having to choose a laptop because of better performance, but the prize is different for the two solutions.
Jun 28, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Processor upgrade
Here is a link to the manual for the motherboard.
http://dlcdnet.asus.com/pub/ASUS/mb/sock423/850/
p4t-m/p4tm-100.pdf
The manual doesn't really say what cpu speeds the board supports.
1.4 ghz was about the fastest processor speed when the board came out. My guess is that a 2.0 ghz cpu may not work.
It would be a slight improvement over the 1.4 ghz cpu, but not a huge difference.
Jun 25, 2008 | ASUS P4T-M Motherboard
CPU Upgrade for Compaq (283983-001) Motherboard
download and run everesthome
click on the + by motherboard
click on cpu then click on motherboard
the cpu will id the the processor
motherboard will id the FSB speed.
CPU-Z
click on the download latest version, left column
when you unzip and run this it will tell you if the processor is 478 or 479 pin both have 478 pins but location is different.
Mar 29, 2008 | Compaq (283983-001) Motherboard
Wont post and buzzing noise
Don't mean to butt in here but I'll bet the 4 pin_ATX 12v connector is not connected to the board. That 4 pin_ATX 12v connector give's the CPU it's power. Without is the system will not boot. Some boards will give off that weird sound you are hearing.
Feb 29, 2008 | Computers & Internet
AMD Athlon 64 X2 3800+ Dual Core Processor - Socket 939 (AMDX23800) Logo
197 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
