Question about Nokia N72 Cellular Phone
My n72 does not play .mp3 files
I accidentaly got my n72 wet and now it does not play .mp3 files any more . ighav installed wma plusto play .mp3 files
  • udaykumar_ko Feb 22, 2009
    i cant able to play MP3 files in my mobile (N72).
    Please give a Solution as fast as possible
Cella thuki kubbaila podu
Posted on Feb 18, 2009
HOW TO CONVERT WMA FILES TO MP3 FILES?
This issue is very easy to dispose of. A free online converter could assist you. Whatever the OS ur running on your computer, this Free WMA to MP3 Converter is available. Ive used it for many times. It is very helpful.
Jun 17, 2014 | Eclipse 180g2 4gb mp3 music/vid
My mp3 says file format error when I try to listen to the music.
It's possible that the file type of the music file(s) you are trying to listen to are not a supported format of your mp3 player. Your player only supports MP3 and WMA audio formats. You should check the music files you are tying to play to confirm they are of a compatible format.
http://www.cobyusa.com/files/manuals/MP300_MN.pdf
Mar 02, 2011 | Coby MP300 MP3 Player
SwiMP3 (128 MB) MP3 Player: I have the original first version of the Swimp3 pl...
This could actually be an easy fix. If you have any files on the player that are not WMA or MP3 files, or that you've stored your music in folders - either way it could simply stop the drive from playing.
Incompatible Music Files: If you have loaded a music file that is not compatible, it simply won't play. The SwiMP3 player works with mp3 or wma files, but not aac (like from iTunes).
Solution: Remove the incompatible files. Convert your other music files to mp3 or wma, and if you are importing your songs direct from itunes, you'll need to convert them to mp3s first.
Incompatible NON-Music Files: An MP3 player is similar to a Thumb Drive or Flash Drive because it can hold any kind of file that will fit in the drive's capacity. However, if you have loaded an incompatible file - including JPEGs, Cover Art, Word Docs, anything that is not an MP3 or WMA file, the player simply can't translate it into music.
Solution: Remove the incompatible files, leaving only your mp3 or wma files in your root directory.
Folders: The mp3 player is not able to open folders and play music files stored inside, to the Swimp3 player the folder is simply an un-playable file.
Solution: Open the folders, move or copy the music files into the root directory (remember, mp3 or wma - not aac), then delete the folders.
I hope you find this helpful.
Michelle
Swimp3 Troubleshooting Video
May 18, 2010 | Finis Swi MP3 Player
Can't play mp3 songs from my sd card files named .AAC how to change to .WMA files?
AAC files are for itunes you need to reformat them to wma using some software.....try downloading and installing from this link
http://download.cnet.com/Free-Mp3-Wma-Converter/3000-2140_4-10442362.html
please let me know if this helps
jonniecullen@ireland.com
Nov 16, 2009 | Nintendo Video Game Consoles & Games
Can't play wma files
Dear! You should install total video converter on your PC and then you should convert your files in correct format. Then you can past in mp3 it will work 100% guaranteed.
Thank You
Jul 30, 2009 | Toymax Ativa ATMP410 MP3 Player
Plays wma books, will not play mp3 books
convert the mp3 files to wma on a computer and then try
May 31, 2009 | SanDisk Sansa Clip MP3 Player
I can't get my MP3 to download and play WMA Format
Here is the asterisk behind WMA compatibility - there are two types of WMA files - protected and unprotected. 90% of WMA files are DRM-protected, hence they are either not usable in mp3 players that say they can play WMA's, or the song has a DRM restriction on it that prevents it from being played on an mp3 player without purchasing additional rights.
To avoid the problem completely, only download songs that are in mp3 format. It may be more expensive initially, but they are better in the long-term - even if you found a WMA file that eventually works with your mp3 player, the protected WMA files have an expiration date, so they would stop working after 30 days, 90 days, 1 year, or 2 years depending on the specific license for each song. Mp3 files never expire, never give you error messages, and work with nearly (if not all) 100% of mp3 players.
-Tha Mp3 Doctor
Mar 30, 2009 | Audio Players & Recorders
Wont play wma files
Different players will accomodate different formats. You might have to reformat the WMA files on your PC and then transfer to your unit.
Nov 01, 2008 | Philips GOGEAR SA6045 MP3 Player
Rca junk
When RCA first came out with the Lyra series the only way to get music onto the device was by using musicmatch jukebox that would convert your mp3 file to mpy before downloading it to the device. But now RCA has come out with a new firm ware update for these mp3 players that improved the players playback quality plus enabled it to use .WMA files. so first go to RCA support http://support.rcaaudiovideo.com/select.aspx?u=downloads and find your player and download the firmware upgrade and install to your player its very easy and instructions are at the same site. You can now convert your music to .wma or use the free Real player that will convert mp3 to wma at the kbps that you request before loading it on. If your music is all ready in wma format you can use windows media player to send the files to your player. One last thing the .wma files that you put on your Lyra player need to be at least 128kbps or higher enhanced playback quality of wma files (160 kbps to 256 kbps).
Jan 15, 2008 | RCA Lyra RD1080 MP3 Player
225 mr will not play burn MP3's
I have the manual and copied it verbatim for you. Please let me know if you need me to scan the manual for you. Acceptable medium formats: The following formats are available for the media used in this unit. The maximum number of characters used for file name including the delimiter (".") and three-character extension are indicated in parentheses. ? ISO 9660 Level 1 (12 characters) ? ISO 9660 Level 2 (31 characters) ? Joliet (64 character; Up to 32 characters are displayed) ? Romeo (128 character; Up to 64 characters are displayed) ? Long file name (200 characters; Up to 64 characters are displayed) ? Maximum number of characters for folder name: 64 (Joliet; Up to 32 characters are displayed) For a list of available characters, see the instruction manual of the writing software and the section Entering file and folder names below. The media reproducible on this unit has the following limitations: ? Maximum number of directory levels: 8 ? Maximum number of files per folder: 255 ? Maximum number of folders: 50 MP3/WMA written in the formats other than the above may not be successfully played and their file names or folder names are not properly displayed. Settings for your MP3/WMA encoder and CD writer Do the following setting when compressing audio data in MP3/WMA data with the MP3/WMA encoder. ? Transfer bit rate MP3: 8 ?320 kbps WMA: 48 ?192 kbps ? Sampling frequency MP3: 8, 11.025, 12, 16, 22.05, 24, 32, 44.1, 48 kHz WMA: 32, 44.1, 48 kHz When you use your CD writer to record MP3/WMA up to the maximum disc capacity, disable additional writing. For recording on an empty disc up to the maximum capacity at once, check Disc at Once. Play mode may not be possible when portions of the functions of Windows Media Player 9 or higher are used. Entering ID3 tag: The Displayable ID3 tag is ID3 version 1.x. For the character code, refer to the List of Codes. Entering file and folder names: The code list characters are the only file names and folder names that can be entered and displayed. If you use any other character for entry, the file and folder names are not displayed correctly. They may neither be displayed correctly depending on the CD writer used. The unit recognizes and plays only those MP3/WMA which have the MP3/WMA extension (.MP3/.WMA). A file with a name entered with characters not on the code list may not play correctly. Writing files into a medium: When a medium containing MP3/WMA data is loaded, the unit checks all the data on the medium. If the medium contains a lot of folders or non-MP3/WMA files, therefore, it takes a long time until the unit starts playing MP3/WMA. In addition, it may take time for the unit to move to the next MP3/WMA file or a File Search or Folder Search may not be performed smoothly. Loading such a medium may produce loud noise to damage the speakers. ? Do no attempt to play a medium containing a non-MP3/WMA file with the MP3/WMA extension. The unit mistakes non-MP3/WMA files for MP3/WMA data as long as they have the MP3/WMA extension. ? Do not attempt to play a medium containing non MP3/WMA.
Jul 31, 2007 | Kenwood KDC-225MR 200W Car/Marine SIRIUS...
Nokia N72 Cellular Phone Logo
Top Nokia Cell Phones Experts
IT Solution
IT Solution
Shehu Pro
Shehu Pro
