Question about Nokia N70 Cellular Phone
Nokia N70 Menu not opening
When I try to open a menu it is not coming up. All other keys like navigation keys and left and right button open all applications like Gallery, Messages, Contacts etc. What should I do now ?
Waiting for quick and positive reply.
Thanks.
Jignesh.
Ok i think sure you phone need soft waer again but in this case can not you do it alone because it need tornado or jafa box
Posted on Feb 18, 2009
How to deactivate offlinemode of my nokia e52
To switch OFFLINE mode on/off:
  1. Press Menu (left soft key)
  2. Highlight Ctrl. panel and Open (Navigation key)
  3. Highlight Profiles and Open (Navigation key)
  4. Select a Profile of your choice and then press in Navigation key
Alternatively,
  1. Press the on/off button quickly and the list of Profiles will be shown
  2. Select a Profile of your choice (Navigation key)
Hope this helps. If so, kindly vote.
-regards,
Mrigs
Mar 04, 2011 | Nokia E52 Smartphone
Tip
Broken Screen Delete Messages Nokia 3109 3109c 2323 2323c
This works for the Nokia 3109/c and also the 2323/c which have a Nokia menu like in the picture. If you have the same menu then it should work. The handsets have a central navigation button which allows you to move up, down, left and right through the menus.
Delete Inbox Messages Blind Nokia Broken Screen
Press Central Navigation Button to get Menu
Press left once
Press up once - Message Menu
Press Central Nav Button
Press up twice - Delete Messages
Press down once - By Folder
Press Central Nav Button - Inbox
Press Central Nav Button - Confirm Delete
Press Button above call end several times to exit from the menu
Note on the 2323 (not sure about the other models) you have an option to keep unread messages. If you still want everything deleted then swap confirm delete step above for
Press Left hand button set above green call button - confirm delete all messages
Delete Sent Messages Blind Nokia Broken Screen
Press left once
press down three times - Sent Items
Press Central Nav Button - Confirm delete
on Aug 06, 2010 | Cell Phones
Tip
Saving contacts to SIM with Broken Screen Nokia 3109 3109c 2323 2323/c and...
Save Contacts to SIM blind. Nokia Broken Screen
Press Up once - Contact Menu
Press Up once - Copy Contacts Menu
Press Central Nav Button - From phone to SIM card
Press Central Nav Button - Confirm copy
Leave for a few minutes depending on how many contacts you have to copy
My friend sent me mms on my N70 I tried to removed the message but I can't do it. Maybe you could help me erase the messages. Thanks
Hello - I use a Nokia 70 so hopefully I can help.
Scroll the centre button down to messages - press once to open. Move down one more setting to UNREAD messages and press again.
This will open ALL messages in you inbox - TXT/SMS + email + MMS.
Find your MMS by scrolling up/down then click the C (cancel) button bottom left on your phone. This should then ask - Do You Want to Erase this message - click YES.
The second option after you have found the MMS in the inbox is to open it, then press option which is the 'select' key on the left part of the screen. Press this once and you will have a menu of choices like -- move to / save picture / forward message to / save message on phone card // AND DELETE.
One of these should work if the phone is in good working order on all the other features. - Ray
Jan 15, 2011 | Nokia N70 Cellular Phone
Hello sir/madam , in my nokia n70 device the left navigation key and the buttons 1 and 3 does not work . up and down navigation keys are also not working . kindly tell me the right solution
Hi Friend!
The best advice I can give is that you bring your phone to a technician for check up. You might not want to tinker with your device on your own and end up with a dead unit altogether but if you wanna give it a try, the problem somestimes is a dirty or corroded keypad. Remove the membrane attached to the keypad and use a cleaning solution such as a paint thinner to clean the keypad surface. Use a piece of cotton with the solution. Another thing you should also check is the keypad connector. Check if it is properly aligned.
Dec 19, 2010 | Nokia N70 Cellular Phone
My mozilla firefox window no longer shows menu or navigation bars. How restore?
Hi pbqsf
The Menu bar and the navigation toolbar have been disabled. You can enable it by following the steps below:
1) Open firefox
2) Press the 'Alt' key on keyboard (Pressing this button temporarily brings back the Menu bar)
3) When the Menu bar shows up, right click on an empty area right next to Help as shown in the picture
4) Now select the Menu bar option and the Navigation toolbar.
Now, your Menu bar and Navigation toolbar will be up.
Thank you for using Fixya.
Nov 20, 2010 | Computers & Internet
How to install flash player n70 phone?
Download the Flashlite software. You can get it easily by searching in google.
Connect you phone with pc via bluetooth or a USB cable.
Trasnfer the Flashlite software to the root directory (c:\) of your phone or to the memory card (e:\).
From tools menu of your phone open file manager.
Open by default it will look in your phone memory. If you saved the software to your memory card move the right navigation key to select your memory card.
Look for the software file.
Open it and install it.
If you need any detail discription please feel free to write back.
Thank you for choosing Fixya
Jun 23, 2010 | Nokia N70 Cellular Phone
I have a nokia 6021 and my screen is broken how do i transfare my numbers from phone to sim
This also maybe useful
Press left once
Press left once
http://www.fixya.com/uploads/images/eb5cca9.jpg
May 21, 2010 | Cell Phones
License Key for Smart movie 3.41
Please enter 00000 or 123456 or few amount of key to register or download the following link
Click this link and download
Thanks & Regards
Nandu.
Mar 16, 2009 | Nokia N70 Cellular Phone
Nokia N70 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
