Question about IBM Thinkpad (05K5179) CPU Fan
Fan is not running while the system is working, is it normal ?
  • 27 Answers
Its absolutely not normal...turn the pc off or it might get fried..
if you are a novice at hardware you can change the fan otherwise you'll have to get the fan changed from a tech..
Posted on Feb 18, 2009
My 2004 3400 closed system ,runs hot in town unless heater is on. driving up a mountain pass it gets very hot.on a flat highway runs normal. new t state,resivior cap, both fans work no leaks or smell
Radiator fan motor or radiator fan thermostat defective/
Also there is a relay that operates the fan motor
In town not enough air passing through radiator allowing it to over temp.. With heater fan running acts like cooling fan keeping engine cool
Highway driving ample air passing through radiator without fan.
Hill climbing requires cooling fan/
Hope this helps?
Nov 17, 2016 | Cars & Trucks
2007 chrysler pt cruiser cooling fan does not work with ac
If refrigerant is low , high side pressure may not be high enough to engage the pressure switch to kick on the fans. Have the a/c system evac'd and recharged to capacity then recheck fan operation. Also, extreme cold weather can reduce high side pressure on a fully charged system preventing fans from coming on.
Feb 14, 2014 | Cars & Trucks
Cooling fans run at cold start
That may be normal depending upon what you are doing in the vehicle. If you have the climate control system set to defroster, most vehicles run the AC system to avoid fogging. Anytime the AC system is engaged the cooling fans must run. Make sure you don't have the AC or defroster on and try again. If the fans still run it could be a faulty fan switch.
Nov 02, 2013 | 2004 Ford Freestar
Want to know why one fan turns on all the time but the other two don't. Is this normal. The heating is working fine besides this. Tax
That's a condenser fan motors they work when you a/c system is running. On hot weather temperature they should work all the motors to keep the system cool.On the winter time they never works cause the weather outside is too cold.
Feb 03, 2013 | Heating & Cooling
COOLING FANS NOT WORKING WHAT COULD BE THE PROBLEM
I would check the fan first, run a hot wire to one side of the plug, if you unplug the fan you must ground one side. if fan works, then next check the fan relay. only other thing it could be is the temperature censer on the engine block, should be close to the upper radiator hose
(Thermostat) side, this works on a ground bases. Hope this helps you!!!
May 17, 2011 | 1994 Toyota Camry
The car is running hot..we went to change the thermostat, but discovered it didn't have one in the line. What could be causing it to run hot??
check electric fans to see if they are coming on. and also make sure there is enough anti freeze in system. if fans do not work proper, check the fan relay if relay is ok. then the problem is either a bad wire or the fans itself are bad. to check fans-- take wire connector off of fans, then run a wire from positive on battery to positive on fan, ground other wire if need be. if fans do not run then thats your problem.
Aug 20, 2010 | 1996 Nissan Sentra
The one fan willl not come on but both will when motor is hot
I'm not familiar with your particular car, but this info may be of some help to you...
Dual fan cars work in a few ways:
1) Some only use one fan during normal cooling, and turn on the second either when the temperature reaches a certain level, and/or when the air conditioning is running.
2) Some use both fans for normal cooling, but at least one of the fans have a dual-speed motor. Generally only one has dual-speed motor, which operates at low speed during normal cooling cycles, and operates at high speed at a predetermined temperature, and/or when the air conditioning is running.
Based on this, it's possible that your system is working correctly, or you have the chance that your low speed portion of the cooling system is not functioning. Check the wires going to the fans. If there are only two wires, then it's a single speed fan. If there are three wires, it's a dual speed fan.
Based on that information, you should be able to determine if your system is working correctly or not.
Dec 13, 2009 | 1989 Honda Accord 4 Door
Fan won't stop running
The fan should be running all of the time in order to keep the system cool.
If it seems to be working a lot harder than normal the computer may be over heating. Make sure there is plenty of ventilation around the pc.
Mar 17, 2009 | Dell Dimension 4600 PC Desktop
Fan Error on IBM T41
This is normally the CPU fan - is it working?
Is it connected to CPU fan socket on mainboard or a different socket - it must be connected to correct socket or fan will not be detected?
Aug 09, 2008 | Computers & Internet
IBM Thinkpad (05K5179) CPU Fan Logo
337 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
