Question about KitchenAid KSCS25FKSS Side by Side Refrigerator
Icemaker not getting water. I came home to find water all over the floor from my refrigerator. I turned the water supply off in back of the unit and a couple days later started investigating. Changed the filter (tube filter) under the fridge and the leaking stopped. Water comes out of the dispenser fine, however water is not getting to the icemaker. the icemaker works (motor turns etc) will even make ice if I poor water into the cube tray (manually). I now this is similar to other postings Does the icemaker use the same tubing as the water outlet? so I can avoid chasing the tubing any other ideas? thanks
  • winy68 Jun 15, 2009
    thanks
    new to this site and already fixed my problem when you replied
  • KitchenAid Master
  • 19,396 Answers
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 22, 2009
How do I turn off the water to my icemaker on Kenmore Model 253.7818480 Refrigerator?
If your fridg is plumbed like most, there's a valve under your kitchen sink that controls the water going to the fridg.
Jun 12, 2015 | Kenmore Refrigerators
Tip
How to repair an ice-maker of a refrigerator
An icemaker receives water through a small, 1/4-inch water supply line that runs from the refrigerator to a water pipe, where it is connected by a tap valve. The water supply line enters a valve in the refrigerator that is controlled by an electric solenoid that sends water through a fill tube into a mechanized icemaker assembly. There, the water freezes and is dumped into an ice bin. When the bin is full, the ice lifts a bail wire that turns off the icemaker. If the water’s route is blocked or the solenoid doesn’t work—or if the bail wire is lifted—the icemaker won’t make ice. (Also note that your home’s water pressure must be strong enough to serve an icemaker.)
Here are a few steps you can take to get your icemaker working (be sure the bail wire above the ice tray is in the down position):
1) If the icemaker doesn’t make ice but you can see the arm swing into motion and you hear a buzz for about 10 seconds after it is finished, the water valve is asking for water that isn’t arriving. This means the valve and the solenoid are probably okay, but the water supply is not. Be sure the water supply line isn’t kinked behind or beneath the refrigerator (1/4-inch copper tubing is much better than plastic fill line).
2) Check to see if something has caused ice to back up around the mechanism—this can cause the fill tube to freeze, blocking the mechanism. When ice cubes are small and seem to be getting smaller, it generally indicates a frozen fill tube.
3) Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, unscrew the copper line from the back of the refrigerator, put the copper line in a bucket, turn on the valve, and see if pressurized water pours out.
4) Check the tap valve; a bad tap valve may cause the problem where the icemaker’s supply tube connects to the water pipe. If necessary, replace the inlet valve and the tap valve. For the tap valve, use the type that requires you to drill a 1/4-inch hole (as opposed to the “self-piercing” type). You can do this yourself, or call a repairperson or plumber to install an inline water filter when replacing the valve.
5) The water line attaches to a solenoid at the back of the refrigerator and then travels to the icemaker. The solenoid may be defective or may not be receiving power. You can try removing the sediment screen inside the solenoid and flushing it with water to clean it, and at the same time you can inspect any seals or diaphragms to ensure that they are sound. Unplug the refrigerator first. Unless you’re skilled at home repairs, this job is better left in the hands of an appliance repairperson.
on Sep 02, 2010 | Refrigerators
I need to stop water from getting on the floor of the freezer?
If your refrigerator is frost-free, water may not be draining into the evaporator pan underneath. The drain tube may be clogged.
Dec 18, 2014 | Refrigerators
I have a 15 year old GE fridge with an icemaker that has started
You can buy a new icemaker from Home Depot your is probably rotted. Unplug the appliance and unplug the icemaker then remove the screws.
Sep 24, 2009 | Refrigerators
Water on floor under unit & ice bottom of freezer
By going online, saw several posts re this problem. In short, the water drain was clogged and there was also a problem with the defrost timer. Service man blew out the drain line with compressed air and installed a new timer. Voila! Problem fixed. Interestingly, the serviceman found a wad of what looked like putty, but was sticky like gum in the drain area. He said he had never encountered anything similar.
Aug 04, 2009 | Jenn-Air JCD2295HES Side by Side...
Water leaking from icemaker on outside
If this is your water dispenser leaking
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
Jul 08, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
We have a maytag refrigerator mtb2656ge with icemaker. We have filtered water to the icemaker. The filter shut off to be replaced. NO ICE. We have water to the solenoid where supply water comes in but...
Emptyed out freezer unit & shut it off. Took a hair dryer and blew hot air for about 3 minutes on ice maker unit just in case it had an ice block. Left door open and let is stand for about 10 minutes. Turned everything back on and it started making ice.
Carol
Jun 29, 2008 | Maytag Refrigerators
Ice Maker floods floor and freezer compartment
You may not have got the supply tube all the way into position so I would check this first. If the water is running down the back wall of the freezer compartment at a higher level than the icemaker the problem is not with the icemaker but with some break in the supply chain. If the water is overflowing from the icemaker then it could be the timer cycle on the icemaker or the water inlet solenoid valve at the back of the cabinet (compressor side). Water leaks need to be traced back to the highest point ( I know how obvious that sounds but sometimes we all miss the obvious). Hope this is of some help.
Aug 16, 2007 | Jenn-Air JCD2389G Side by Side...
KitchenAid KSCS25FKSS Side by Side Refrigerator Logo
210 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
