Question about LG DU-62SY20D 62" Rear Projection HDTV
Mitsubishi Projection TV: Menu is in perfect color, Video is gray
I just got a Mitsubishi projection tv from my friend's dad. I don't know all that much about it's history, but when I play video on it, all I get is grayscale. The strange thing about it though is that the tv's menu screen
is in perfect color. Also, when I set the crosshairs I can see red, green, blue, and any color in between by moving the crosshairs to and fro.
I'm very confused! How would it work for the menu, but not for the video?
Help is much appreciated! Thank you in advance.
  • 1 more comment
  • rtldan Feb 18, 2009
    Hello Dan!
    Thanks for your reply. I am connecting with the standard yellow video cable and red + white audio cables. Thanks for the tip! I'm not able to check the tv's settings at the moment but I will do so tonight and get back.
    Thanks again!
    -Daniel
  • rtldan Feb 19, 2009
    Hello Dan!
    My video source was a yellow RCA cable into a yellow RCA port. But as a test I connected a source through the S-video port. Wa-la! This worked! Everything looked normal.
    Okay, here is where I win the "bad amateur decision" award. I mistakenly thought that the RCA problem might be a setting that was incorrect, so I got to the service menu and reset the eeprom (E2RESET). Oh ****. Now everything looks horrible. After a night spent scouring the web, I was able to get everything pretty decent EXCEPT for the horizontal convergence. After a few hours of twiddling I got the vertical convergence lines to match up. But with the horizontal lines I'm having a heck of a time lining up the middle lines. Do you happen to have any tips for getting this set right, or a link to something that might help? Or will I simply need to tweak, tweak, and tweak some more until it I get it right?
    Thanks!!
    -Daniel
  • rtldan Feb 20, 2009
    Hey Dan!
    Thanks again for all your help!
    I will have to break down and get a copy of that manual :)
  • 4,234 Answers
The gray color indicates that all of the colors are working properly. For some reason, you are telling the set that there is no color. How are you connecting to the set? If the set is expecting component video (RGB) and you are sending composite (yel connector), it will appear this way for example. Please update this with your connections and we'll figure it out.
Thanks,
Dan
Posted on Feb 18, 2009
  • ABRsvcs Feb 18, 2009
    Make sure that the source end is sending composite video and that the cable is connected to the correct spot. If that is not the problem, let me know and we'll look elsewhere.
    Dan
  • ABRsvcs Feb 19, 2009
    Unfortunately, with the complete reset, all of the parameters must be set. Your best bet is to purchase the service manual and perform the complete convergence procedure. There is a specific order to the adjustments that if not followed can have oyu trying to adjust things almost forever. I believe that the service manual is available from a number of places on the net. You should be able to locate one for less than $20.
    Good luck.
    Dan
What is the best color setting for Mitsubishi WS-48515 48 in?
The menu will have some choices---if someone hit the reset it returns all of them to default levels.
You do need the Mitsubishi remote to do that--go into menu and look for custom-which is the one you can preset all to your taste---the only critical one is PICTURE which is contrast---it should never be set above 70 percent or fixed images (like games) can burn the images into the tubes this set uses.
If you do not have the owner manual let me know--I know a site that has them for free.
May 16, 2012 | Mitsubishi WS-48515 48" Rear Projection...
Cc color distortion bows at too and bottom
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 05, 2011 | Mitsubishi WS-55809 55" Rear Projection...
I have mitsubishi vs-50800 i was watching a movie and the screen just all of a sudden went blury and the color is all mixed up i went to the convergence menu and it wont allow me to move the colors left or...
  • Screen looks 3D
69189a5.pngSOLUTION
May 03, 2011 | Mitsubishi VS-50800 50" Rear Projection...
Where can i find a color wheel for a 73732 mit
The way that you change the color on this TV is thru the audio/video menu, under Perfect Color. It show you how in your owners manual on page 74. If you no longer have the owners manual you can downloaded it here http://www.mitsubishi-tv.com/pdf/ownersguides/WD-73732.pdf
Mar 02, 2011 | Mitsubishi WD-73732 73" Television
We need to figure out how to get it off of the 3d setting we just recieved this tv from a friend of ours and we are trying to figure out how to view it without the 3d our tv is a mitsubishi big screen...
  • Screen looks 3D, wavy, or has a shadow or shadows
69189a5.pngSOLUTION
69189a5.pngSOLUTION
Jan 29, 2011 | Mitsubishi WS-65907 65" Rear Projection...
My Mitsubishi projection tv WS-A55 video isssue
Colored ghosts (red,green,blue) is convergence bad. If can't adjust from menu, then bad circuits. Call someone for approximate estimate.
Apr 20, 2010 | Televison & Video
Picture is bowed at top and bottom picture perfect in middle of screen; colors seperating in corners convergrence is perfect
Projection sets have two very common problems outlined below.
The first common problem is convergence
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. The TV can also shut down when the convergence starts to fail.
Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith, RCA and others.
You can more info and a DIY convergenece repair kit with instructions from TV Repair Kits using the link at the end of this article.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped or bowed
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Nov 01, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Turning on Internal TV Speakers
either your model tv ,doesnt have that option,,or its on the back,,check the rear of the tv,,good luck
Oct 01, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Color
replace the converge ic's
Jun 01, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Colors are offset
You will need to install new convergence ICs if you need more info on this please let me know. Its a fairly easy repair.
Apr 10, 2008 | Mitsubishi WS-48613 48" Rear Projection...
LG DU-62SY20D 62" Rear Projection HDTV Logo
473 people viewed this question
Computer Repairing
Computer Repairing
