Question about NorStar M7310 Corded Phone
Cid on display
Need to see the number of the incoming call on Norstar display
  • 1 more comment
  • sotelobc Mar 06, 2009
    i've just installed a "CID TRK CARD" on a Norstar system. All incomming calls display only 1 line of "calling party info" on 7310 set. Why don't both lines appear on display?
  • terry gormley May 11, 2010
    Does your phone provider supply you with cid for all lines
  • 192 Answers
Depending on the software, you can either have all the phones that are ringing to display caller id... or just one.
If the phones are set to ring and appear, but they are not displaying CLID infomation, you can hit the FEATURE 811 to toggle between name and number.
This should give you calling line ID, so long as it's enabled.
Posted on Mar 20, 2009
Why doesn't one phone in my norstar meridian m7310 phones is not displaying caller id
Either COPY the config settings from a set where it works to those that don't, or on the sets that do not:
F**CONFIG, Terminals&Sets, (enter ext #), ... Telco Features, 1st Display Name: change between Name, Number, or Line.
And remember that some callers (esp Cellphones) do not provide Name info, so if the incoming calls at that extension are mostly from the same #s, it might be normal.
Aug 11, 2014 | NorStar Meridian M7310 Phone
Uniden cordless phone caller id quit working
Using the Caller ID and Redial Lists
Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls. Contact your telephone provider for more information.
Caller ID list
Redial list
When a call comes in, the phone displays the number and name (if available) of the caller.
The phone saves the information for the last 30 received calls to the
CID list.
When it's in standby, the handset shows how many calls came in since the last time you checked the CID list.
Each handset remembers the last 5 numbers you dialed on it. The redial list is separate for each handset.
Dec 02, 2012 | Uniden Cordless Phone
M7310 + Caller ID
You need CID service from teoco, Caller ID capable circuit packs in your Norstar system and 2 parameters turned on in programming under "terminals a & sets" for each extension. Also the CID will only auto display on sets that have the ringing turned on for that line. (you can also program a display button..feature-811). I doubt it is the software version but to display it go into programming and step down through the menu from 'Terminals&Sets' 10 items to 'Maintenance' and press 'show' then show again at 'System Version' this will give you a display like "SP: 30DHC04 NAT". Hope this helps. Bill C. www.dyns-tech.us We also do remote programming on Nortel CICS and MICS so equipped
Mar 15, 2010 | NorStar M7310 Corded Phone
Norstar Meridian M7100 incoming calls - no ringing tone
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear & ring
press the Chng key till it says appear only press next key (lower right arrow)
The display should say line 002: appear & ring
repeat the procedure the same as line 001 for the remaining ringing lines
press the release key when finished
Jan 12, 2010 | NorStar M7100 Corded Phone
How do you activate call display on the Norstar M7310 phone system. email me a elainedrew47@hotmail.com Thanks you
CID call display requires 3 items, CID service from the telco,CID trunk cards, and maybe a software upgrade. If you program it and it doesn't work, then you need a CID trunk. If your software is in the neighborhood of 4, then you may need to upgrade to get a display on all phones when the phone rings.
Carl
Nov 18, 2009 | NorStar M7310 Corded Phone
NorStar ICS Caller ID Upgrade
Yes, this is correct. install the co card with cid and you should be fine.
Dan
Jun 07, 2009 | NorStar Compact Ics WithClid Trunk Mod...
Remove message of the middle line of display
Pick a spare button and label it CALL LOG. Now press PROG that button and dial 54 STORE. Ooh, it should light up. Now press it and your display will show 3 of the 4 lines of CID info from the calls to your set. The navigator button will show the rest, just keep pressing the UP, DOWN, LEFT, RIGHT buttons. When you run out of items to display, the light and INCOMING CALL display will go out.
If you press 54 and the 3 digit number of your incoming call group (maybe 601 by default) it will follow the incoming calls to the entire call group.
Carl
Apr 24, 2009 | Panasonic KX-T7630 Corded Phone
Display showing "Incoming Call :001"
Don't worry, if you ignore it will grow :-)
It's a count of the unanswered calls with CID. If you take a spare button and program it for Call Log, it will light up and you press it to start the call log display.
Try this press PROG 54 STORE
When you press it, your display will now reveal the numbers under incoming.
If you put a number after the 54, it will log calls for a particular group. I get my calls on incoming group 100, so I store 54 100 under a button and I can see all system calls. I have a second button for just my extension calls.
Carl
Jan 15, 2009 | Panasonic KX-T7630 Corded Phone
Nortel Meridian Norstar-Plus Compact ICS with #7310 phones.
I'm pretty sure CID is automatic on a CICS....IF you have a CID trunk card. You might want to post the part number on the face of the trunk and we'll see if it's the proper one.
Carl
Jan 08, 2009 | NorStar M7310 Corded Phone
Cid issues
Are you getting caller ID?
Under phones/sets, you have to tell the system to log the calls.
Jan 09, 2008 | NorStar T7316E Corded Phone
NorStar M7310 Corded Phone Logo
165 people viewed this question
Top NorStar Lands Phones Experts
Oloyede Monsuru
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
