478 pin CPU socket
Mecer 757IAO P4 CPU (478 pin) damaged. Can I replace with Celeron D CPU?
  • bhaw157 Feb 18, 2009
    Thanks. Much appreciated.
    President:
  • 778 Answers
Yes you can.
Posted on Feb 18, 2009
  • Frank  Fernandez
    Frank Fernandez Feb 18, 2009
    That's the short answer anyway.
  • Frank  Fernandez
    Your Welcome, and thanks for the rating!
CPU upgrade for Compaq SR1220NX Desktop
Here are the CPU specs that will help you find a new CPU for your desktop:
Socket 478 for Intel P4 Williamette and Northwood processors
  • Supports Intel Pentium 4 processor up to 2.8 GHz
  • Supports Intel Celeron processor up to 3.06 GHz (Prescott based Celeron with 533MHz FSB)
Oct 14, 2014 | Computers & Internet
CPU upgrade for Compaq SR1220NX Desktop Computer
Hi
The specs for this machine state that it is a motherboard with
"Socket 478 for Intel P4 Williamette and Northwood processors
Supports Intel Celeron processor up to 3.06 GHz (Prescott based Celeron with 533MHz FSB)"
In other words, any CPU that is not socket 478 ( a fairly old socket now) will not even fit on the board. You do not mention your current CPU so you need to compare it with the spec above to see if you can improve it. It is an old machine/motherboard, so your money might be better going towards a motherboard or system box upgrade.
Cheers
Whats the processor support of this board
Pentium® 4 processors & Intel® Celeron® processors in 478-pin package.
it will support the following in the 478 pin package
P4 1.4ghz 400fsb speed to
P4 3.06ghz 533fsb speed
Celeron 1.7ghz 400fsb speed to
Celeron 2.8ghz 400fsb speed
Nov 23, 2010 | Intel 845GEBV2 Motherboard
I have this moterboard 845gvm-v ms-7057 ver : 1.0 i would like to know wat cpu i can upgrade to my pc speed is 2.40 ghz and i have a socket 478
Supports Socket 478 for Intel P4 Northwood/Celeron/Prescott/Prescott Celeron processor
?Supports up to 3.06GHz and P4 Prescott up to 2.8GHz.
Oct 24, 2010 | MSI 845GVM-V (MS-7057-010) Motherboard
I have an Intel Celeron D 2.26GHz Socket 478 256 k /FSB 533. Is it possible to replace the Pentium 4 1.6GHz in the Vectra with the Celeron. If so what steps would I take and will I have any XP COA...
You need to check with the motherboard maker. A manual would tell you and you might be able to get the info online if you search for the above model number, find the manufacturer and look up the specs. It needs to have the same socket(form factor) and support the bus speed of the new one.
Replacing a CPU is straightforward but non trivial.
Oct 12, 2009 | Intel CELERON 2.66Ghz CPU AND MOTHER BOARD...
Motherboard ID Motherboard Name Compaq Evo
as long as it is a socket 478 processor which narrows it down to P4 or celeron ( P4 being better and faster ) it should be fine.
Obviously it will state what processors it can handle in the computer manual so if you find the manual it should state in there.
I dont think it will handle more then a 3ghz P4
Apr 18, 2009 | HP Compaq dc7100 PC Desktop
Upgrade cpu
According to the product website your board supports all intel socket 478 cpu's. Maybe you bought a faulty cpu ?
M266A
  1. Socket 478 for Intel® P4 processor
  2. VIA® P4M266A chipset
  • FSB 533MHz
  • Supports Hyper-Threading Technology
  • Hybrid Booster - a safe overclocking feature
  • 2xDDR 266/200
  • Integrated ProSavage8 3D Graphic
Socket 478, Intel® Pentium 4 / Celeron
- FSB 533/400MHz
Jun 22, 2008 | Asrock M266A Motherboard
Cpu upgrade
To upgrade the cpu, you will still need to use the same type of cpu. A socket 478 motherboard will not work with a socket 775 processor. The pin configuration is different.
Dec 21, 2007 | Toshiba Satellite A105-S4004 Notebook
CPU Upgrade-Which Sockel?
Here is some information may be useful to you. Intel processors Socket 1 169 pins 486 SX/DX Socket 2 238 pins 486 SX/DX/DX2 Socket 3 237 pins 486 SX/DX/DX2/DX4 Socket 6 235 pins 486 DX4 Socket 4 273 pins Pentium 60 en 66MHz Socket 5 320 pins Pentium 75 t/m 200MHz Socket 7 321 pins Pentium, AMD K6/K6-2/K6-3, Cyrix M1/M2 Socket 8 387 pins Pentium Pro 150 - 200MHz Slot 1 242 pins PII, PIII en Celeron Slot 2 330 pins PII Xeon en P III Xeon Socket 370 370 pins PIII, Celeron, Cyrix III Socket 423/478 423/478 pins Pentium4 Socket 603 603 pins Pentium4 Xeon PAC418 418 pins Intel Itanium PAC611 611 pins Intel Itanium 2 AMD processors Slot A 242 pins Athlon Socket A 453 pins Athlon, Athlon XP, Athlon MP and Duron Socket 754 754 pins AMD Athlon 64 Socket 940 940 pins AMD Opteron Conclusion: You can not upgrade beacuse Armada M700 has a pentium III processor with 370 pins. So the Socket 478 pinned pentium is not suitable. Advise: Try to exchange it with a new laptop or buy a used laptop for suitabl configuration
Oct 01, 2007 | Compaq Armada M700 Notebook
Are all P4 478pin cpu's compatible with the P4mm2 motherboard?
Just in case your pins are only bent you can straighten them out as long as you are careful. Take a mechanical pencil without lead (.5 works ok but .7 may be easier to use) and ground it by touching it to your power supply. Then work the CPU pin slowly into the pencil and slowly bend the pin up. If you?re patient and careful you can usually straighten out any pins that have been bent. You didn?t stat which version motherboard you had. On the P4VMM2 (V1.3) motherboard the manual states that the motherboard will automatically determine the CPU clock and system buss frequency and makes the appropriate changes. The manuals only references a front-side buss limitation of 400 MHz, however, a FAQ from the manufactures support site says the V1.x motherboard?s CPU is limited as follows: - Pentium 4 400Mhz FSB (256K/512K L2 cache) CPU ? 2.6GHz - Celeron 400Mhz FSB (128K L2 cache) CPU ? 2.6GHz I would stick with the FAQ recommendations if you have to purchase a new processor, that or contact the support line to verify. Make sure you point out the FAQ on their site since they will probably just refer you to the manuals specs. P4VMM@v1.x CPU FAQ: http://www.ecs.com.tw/ECSWebSite/Support/FAQ_Answer.aspx?FAQID=3010023&MenuID=65&LanID=9 Let us know if you have any other questions and please don?t forget to rate the posting.
Jan 14, 2007 | EliteGroup P4VMM2 Motherboard
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
