Question about HP Pavilion dv4000 Notebook
I bought a good
I bought a good New Battery for HP M2000 Series DV1000 DV4000 laptop battery
  • Nicolas
    Nicolas May 11, 2010
    Good to hear M8! i hope you will enjoy your battery then:)
2 Suggested Answers
benwabnick
  • 2404 Answers
SOURCE: I bought a good
If the battery is bad then replace it with a known good one.
Posted on Jul 12, 2009
I installed a new battery in My HP DV4000 laptop but it won't charge. It's a 8800mah and says 11.1 volts. The old one says 10.8 volts. Any ideas?
this problem happens when the voltage of the battery is slightly less or equal or more than the output voltage of the charger u need a more powerful charger for charging that battery
Mar 31, 2010 | HP PAVILION DV4000 SERIES 30GB (4200 RPM)...
Cd/dvd drivers
i think i ur country's hp website(manufacturer) u can get all drivers just search there and download
Feb 26, 2010 | Battery Technology (HP-DV1000) for HP...
I have a problem with my cd/dvd drivers and my
just go to maufacturer website u get ur driver there
Is this hp pavilion dv1000 battery a cheap one?
From the link you gave its seen that its comparatively lower than the other series.. Brand: HP Laptop BatteryBattery Info:
Li-ion, 4400 mAh, 11.10V, Black, 310.00(g), 205.15 x 59.20 x 37.50 mm
Rating: rate4.gif
Capacity Voltage Price($) 4400 mAh 11.10V C $ 57.79
8800 mAh 11.10V C $ 79.69
Availability: In stock
Notes for charging Hp Pavilion dv1000 Series battery :
  1. You must fully drain the Hp Pavilion dv1000 Series battery until the laptop goes into hibernation for your first use it.
  2. Store it in a cool and dry area. Do not expose battery to water or other moist/ wet substances.
  3. Do not forget to take away your Hp pavilion dv1000 battery from the laptop if you will not use it for a long time.
  4. Know that after that plug in your charger and allow it charge for 12 hours or depending on what the technician has told you. 12 hours is the max and you can use it while charging .
  5. Charge new Hp Pavilion dv1000 Series battery for three times at first. After that it will take less than 2 hours to fully charge your Hp Pavilion dv1000 Series battery.
  6. It is normal for HP laptop battery to become warm during charging and discharging.
  7. Learn that this is recommended so that the Hp Pavilion dv1000 Series will heat up for the time allowing ions to reawaken.
Jan 20, 2010 | HP Pavilion ZV5000, ZV6000, ZX5000 Series...
Can this HP Pavilion DV9000 laptop adapter fit for Compaq Presario V3000 laptop? I doult that HP Pavilion DV9000 laptop adapter on website:http://www.laptopbatteryshop.ca/hp-pavilion-dv9000-ac-adapter.htm...
Have a look at the label on the bottom of the V3000 laptop and check the voltage and amps power rating of the laptop.
If the DV9000 adapter has the same voltage and current rating (amps) or higher amp rating then it is suitable for the V3000 laptop, provided the power plug fits the V3000 power socket.
Jan 15, 2010 | Dell Inspiron 1525 Laptop
How Do I Dismantle?
Just read this manual and do :
h10032.www1.hp.com/ctg/Manual/c00444840.pdf
May 16, 2009 | Battery Technology (HP-DV1000) for HP...
Thinking about purchasing a HP loading dock HP DV2000(ES631AA)
Compatibility document.write(neg_specification_newline('HP Pavilion dv2000, dv6000, dv9000; Presario V3000, V6000 series; compatible (reduced functionality) with Pavilion ze2000, dv1000, dv4000, dv5000, dv8000; Presario M2000, V2000, V4000, V5000; HP Special Edition L2000 series using included expansion base adapter
Note: When using a notebook that requires the included Expansion Accessory Adapter, the following functions will not be supported on the HP Notebook QuickDock: VGA port functionality, stereo microphone (only mono is supported) and power button (must use the notebook power button).')); HP Pavilion dv2000, dv6000, dv9000; Presario V3000, V6000 series; compatible (reduced functionality) with Pavilion ze2000, dv1000, dv4000, dv5000, dv8000; Presario M2000, V2000, V4000, V5000; HP Special Edition L2000 series using included expansion base adapter
Apr 18, 2009 | HP Computers & Internet
New battery and charger, but still not charging
Not at all. take battery and laptop to store for proper chack.
Good luck.
Rate this
Apr 13, 2009 | HP Pavilion dv1000 Notebook
HP Pavilion dv4000 battery question?
Compaq presario m2000 / v2000 / NX4800 / NX7100 /
DV1000 / DV5000 / ZE2000 / ZT2000 / ZT4000
they all using the same battery
Jul 17, 2008 | HP Pavilion dv4000 Notebook
HP Pavilion dv4000 Notebook Logo
52 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
