Question about Car Audio & Video
Jvc kdhdr1 stereo radio will not come on
Has power . att. light is on but the unit will not come on . no blown fuses or bare wiring .
  • 77 Answers
If it has a removable face, remove it and look for the reset button. generally very small and needs to be depressed for about 5-10 seconds with a pen or other small tipped item. if not look throught the manual for where the reset is located if this is not an option remove the positive or negative battery cable from the battery terminal under your hood for a few minutes and then try again
Posted on Feb 18, 2009
How to adjust bass and treble on JVC KDHDR1
This should be the link to the instruction book for your unit, Its in a pdf file https://www.google.com/#q=JVC+KDHDR1
Jul 03, 2016 | JVC Car Audio & Video
I put a new stereo in my 1990 Suburban and it blew the fuse for the dome lights, dash lights. It says on the box that it is putting out 3 times the wattage as my old stereo. What can I do to fix that?
Aftermarket stereos are designed to work within the power specifications for most vehicles, if you are experiencing blown fuses I would suggest re-checking the stereo wiring for a crossed, exposed, or improper connection. If you have ruled out all of these then you can install a capacitor to power your system more efficiently. Most car audio stores sell these and are installed between the connection to the head unit and battery. I hope this helps =)
Sep 29, 2013 | JVC AM FM CD DET FACE CAR STEREO
My vw passat 1999 jvc cd player canot hold memory. have to start my music from track 1 any time the key is out. do i need rewiring? thanks
THERE ARE 2 POWER INPUT WIRES ONE RED THE OTHER YELLOW THEY BOTH HAVE INLINE FUSES THE YELLOW IS FOR THE MEMORY AND SHOULD HAVE +12 AT ALL TIMES RED ONLY WHEN KEY IS ON OR ACC. SOME JVC UNITS HAVE A FUSE PLUGED INTO THE BACK OF THE UNIT ITSELF THEN YOU HAVE TO PULL IT OUTLOOK AT YOUR FUSE PANEL AND YOU MAY SEE RIGHT OFF A BLOWN FUSE BUT IF THE STEREO WAS INSTALLED PROFESSINALY THEY USUALLY HAVE A HARNESS THAT PLUGS DIRECTLY INTO THE FACTORY HARNESS ELIMINATING THE INLINE FUSE THUSLY THE FUSE ON THE BACK IF IT WAS PUT IN WITHOUT A HARNESS ADAPTER YOU SHOULD SEE THE RED AND YELLOW WIRES. IF SO MAKE SURE THEY ARE PLUGGED INTO THE FUSE BOX OR HARDWIRED TO THE OLD HARNESS THE YELLOW ONE IS THE PROBLEM IF THE RADIO PLAYS BUT NO MEMORY THE FASTEST WAY TO CHECK IT IS TO PULL THE PLUG FROM THE BACK OF THE STEREO IF YOU CAN GET TO IT AND HOOK A TEST LIGHT TO GROUND AND TEST THE YELLOW FOR POWER IF NO LIGHT THEN LOOK FOR THE INLINE FUSE OR CHECK ON THE BACK. IF THE RED AND YELLOW WIRES WERE CROSSED ON INSTALLATION IT WOULD DO A SIMULAR THING ASWELL, IF YOU TELL ME THE MODEL# OF THE JVC I CAN BE MORE HELP. MAKE SURE YOU KNOW YOUR SECURITY RESET CODE BEFORE YOU REMOVE ANY FUSES OR PLUGS OR YOU'LL HAVE A HARD TIME RESETING IT GOOD LUCK!
Sep 28, 2011 | 1999 Volkswagen Passat
I have a jvc kds-16 receiver. It has been working for about 5 months with no issues. Now there is power to the head unit but I have no sound. I have checked all of the connections, nothing is loose, the...
buy a digital volt meter and start checking fuses for the radio at fuse panel . if blow replace it . if not blown remove radio from dash check to see if radio is still grounded . if still grounded take the volt meter turn on to dc volts and take black test lead touch to your radios ground the touch the red test lead to the red with to see if you get 12 volt with car on if not need to find out why .. take to professsinal ..
you can also check the yellow wire on radio it should have 12 volts allways doesnt matter if car in off or running this saves memory for clock and station presets.
if every thing is test out right then you need to buy new radio ..
if you dont feel good about doing this yourself find a mecp car audio installer and have them troubleshoot your problem maybe expensive but a good tech could find out problem with in the first 30 to 45 minutes it get 35.00 per hour to troubleshoot car audio system ...
http://www.tintingbyfredjohnson.com
Dec 31, 2010 | JVC AM FM CD DET FACE CAR STEREO
The memory on my new jvc car stereo model kd-s17 does noty work whenever i turn the key off then on i have to reset the clock and presets all of my wires are connected
need to check the yellow constant power wire on wire harness to see
1. connected to battery with constant 12 volts
2. if wire has power 12 volts
if no power check fuses to see if blown
with out this wire working right you will never have pre set station on radio or clock
with correct time
Dec 22, 2010 | JVC KD-G801 CD Player
Glitch???
sounds like you don't have power going to the red wire. should be a switched power source so it turns off with the key.
Apr 29, 2010 | JVC AM FM CD DET FACE CAR STEREO
Stereo wont turn on
the fuse might of blown take it off and check the fuse
Nov 10, 2009 | Cars & Trucks
JVC KD-G140 Chevy s10 problem
Your headunit is getting constant power (yellow wire). You most likely have no switched power (acc red wire). You can be certain by testing the red wire w/ a 12 volt test light when your ignition is on. If there is no power to this wire then you probably have a blown fuse. The radio fuse should be a 10amp fuse located in the drivers kick panel.
May 28, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Wont keep memory
Most stereo manufacturers agreed on a color-coding scheme for their wiring to keep things consistent. In that scheme, red wires are run to power (ie, the battery) and serve as the ignition-switched power leads (so when the engine is shut off, the head unit also shuts off), black wires are grounds, and purple, gray, green, and white are used for the main four speakers. Blue is an antenna and/or amplifier turn-on wire. Orange is a dimmer wire (for cars with dimmers on the dash lights, this can be tapped in to also dim the head unit's lighting). Yellow wires are typically the memory wires. These feed power to the head unit constantly, regardless of whether the car is on or not, so that memory presets and tone settings are maintained. Your JVC unit should have a yellow wire coming off the back as part of the harness - this would be the one to supply power. You can run this directly to the battery - that way if you blow the fuse in the fuse box that you're considering using, you won't lose your stereo settings as well as whatever feature the fuse was utilized to protect.
Jul 20, 2008 | JVC KD-G320 CD Player
Car Stereo will not turn on
Most headunits (cd players) have fuses of their own. If those are are not blown, connect a simple test light to ground and with the ignition on, test your constant (yellow wire) and accessory (red wire) for power. If all fuses are good and you still have no power you can connect your red and yellow wires (whichever shows no power on the test light) directly to your vehicles fuse panel.
Jan 08, 2008 | Sony CDX-F7710 Car Audio Stereo CD MP3...
Car Audio & Video Logo
101 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
