Question about Samsung BD-P1500 Blu-Ray Player
Locked dvd tray
How do i unlock the tray on my samsung bluray bd-p1500
  • 2 more comments
  • flan_d Apr 23, 2009
    I have the same problem but there is no small hole by the relase button. Can you explain where this is located?
  • Anonymous May 04, 2009
    Help. The dvd tray is locked on our unit and there isn't any small hole as suggested to release the tray. Can someone offer any other solutions? There is a disc locked in the tray.
  • flan_d May 11, 2010
    I do not see the small hole. Can you elaborate on the location?
  • Anonymous Mar 31, 2014
    HOW TO UNLOCK
This player doesn't have the old style release. I called Samsung and there were two fixes: They are both procedures to reset the player. The second one worked for me.
1) Player should be on. Hold down fast forward on the player for 10-15 seconds. See if the player resets. If this doesn't work, try the next solution.
2) Disconnect player from power source. Re-connect, turn on player and hold the "on" button down on the player for 10-15 seconds then open the tray using the button on the player.
The second solution worked for me.
Posted on Apr 02, 2010
  • 10,865 Answers
Get a paperclip and unfold it so you have a straight piece of wire. Now look at your tray release button and next to it you will see a tiny hole. put your paperclip wire in the hole and push gently. the tray will open as this is the manual release.
please rate my answer as a fixya. thankis
Posted on Feb 18, 2009
Mannuel for dvd player
Here is a link to the manual for Samsung BD-P1500
SAMSUNG BD P1500 User Manual
Best of luck!
Feb 14, 2016 | Samsung BD-P1500 Blu-Ray Player
Samsung BD-P1500 Blu-Ray Player won't play salt blue ray dvd
Connect the ethernet cable to the backside of the samsung bluray 1500 player ethernet connection with the bluray player power on with no disk & it will automatically update your bluray. It should be work fine after update your bluray. Good Luck!
Jan 05, 2011 | Samsung BD-P1500 Blu-Ray Player
Why does my samsung Blue Ray DVD player load to the menu but wont play the movie
Just need to verify if your trying to play a Bluray Disc or regular DVD?
If Bluray Disc:
All you need to do is to check on the FW version of you BD player. Go to Set-up > System > System Information. SW will be the FW version info. Please be informed that the latest FW version is v2.12. If it will not resolved the concern, try to verify if its happening to all of your Bluray Disc.
Sincerely yours,
Genius 101
Oct 22, 2010 | Samsung BD-P1500 Blu-Ray Player
After updating the firmware on by Samsung BluRay
The firmware you used may have been corrupt which would cause that kind of problem.Try downloading again and reflash the player or download from a different site
Good luck
Rich
Jun 06, 2010 | Samsung BD-P1500 Blu-Ray Player
Samsung bd-p1500 bluray player won't connect to wireless even though access point is recognized
The most common problem here is that the access point is using some encryption like WEP etc. and the player is not configured for the secure link. So it will see the AP, but can't connect to it.
You either need to setup the WEP keys on the player in the settings, or remove the security on the access point (Not recommended) Also check the preamble, the key type, open / shared etc.
Feb 28, 2010 | Samsung BD-P1500 Blu-Ray Player
My Samsung BD-P1500 keeps saying "No Disk." It won't play Blu-Ray or DVDs? Why?
Is it new? Then send it for warranty claim. Is it old? Warranty expired? Then send it for repair. U have an internal problem. Either with circuitry or with the pick up lens. Most cases if the power is there, then the issue is with the lens. In optical disc drives, lens is the main culprit which fails most of the time. Just in case if u don't know, pick up lens is what reads the cd/dvd/bluray through a laser.
Jan 18, 2010 | Samsung BD-P1500 Blu-Ray Player
My bluray player is a samsung bd-p1500 and terminator salvation the bluray wont play it never even gets to the menu?
All disc players have a thing called stacked tolerance. What it boils down to is some transports in players will not play certain discs; plain and simple.
All you can do it test it out on another BD player to make sure the disc is fine and test another disc in your BD player and make sure it hasn't gone defective.
Sorry I don't have an easy fix, this is not an uncommon problem.
Jan 06, 2010 | Samsung BD-P1500 Blu-Ray Player
Samsung BD-P1500 will not play blu-ray discs
it seems that samsung is posting it's firm updates online @ samsung.com i had same problem with my BD-UP5000 its connected to the internet when i go to the menue to update on the bluray player it said i had the latest update went online and found a new firmware on there web site, check samsung web site
Jul 16, 2009 | Samsung BD-P1500 Blu-Ray Player
Samsumg BD-P1500 Blu-Ray Multizone
possibly because the regions are different to dvd than blu ray, there are 8-9 for Dvd and 3 for blu ray.
Jun 05, 2009 | Samsung BD-P1500 Blu-Ray Player
Unlocking of Samsung BD-P1500
I have a new BD-P1500, and after 5 Times
The trick seemed to be not holding the repeat key too long.
I have a Region B/4, running
090417_01_BDP1500_XAX.RUF
I used the R4 code from below.
1) Turn on the player with no disc in the tray
Wait till the unit is at the Samsung logo screen.
2) Open then close the tray, wait to see the No-Disc Message in the top Left Corner
3) Now press the REPEAT button on the remote, followed by a five digit code.
In this case Repeat 76884
Now it to me about 5 tries to get this to work, It needed to be done without delay.
So if you don’t get it to work straight away don’t loose heart.
4) When it works a 4 will appear in the top left corner
5) Press 9 to make it regionless.
6) Press Eject to OPEN to open the disc tray.
7) Press Eject to CLOSE to close the disc tray.
8) Power the unit off
9) Now power the unit on again, it should now read all regions of DVD Disc.
From other threads I got the follow list of region codes.
R1 - 29334
R2 - 57538
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Report this hack (requests/questions/spam/wrong/****).-->
Region code hack posted by wasgo, September 17 2008:
I have tried the hack mentioned above on my new BD-1500 and couldn't make it work. But the software in it isicon_minipost.gif about a month newer.
Does anybody have any new ideas how to solve the problem?
I have the region 2 version (Sweden)
Jan 18, 2009 | Samsung BD-P1500 Blu-Ray Player
Samsung BD-P1500 Blu-Ray Player Logo
714 people viewed this question
Henry  Thomas
Henry Thomas
