HP Compaq 6720s Notebook Logo
Posted on Feb 18, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DVD/Cd-rom error message code 39
When I look under the driver device, this is the error message it gives me (DVD/CD-rom Error message code 39). I deleted the driver, so that Vista would automatically reinstall it. But it failed to download completely. How do I get my DVD/CD-ROM back up and working again?
Thank you!!!
Anonymous
Level 2:
President:
  • Expert 1,257 Answers
  • Posted on May 26, 2009
Anonymous
Expert
Level 2:
President:
Answers
1257
Questions
Helped
1179465
Points
168
My LiteOn iHAP422-98 9 IDE drive will read but not burn CD/RW discs. No problem with DVDs or CD/R. One of two error messages, depending on the CD/RW disc: 1) Doesn't recognise a disk is in the...
Click start control panel administrive tools computer management device manager scroll to cd/dvd rom drives right click properties then properties again then tick enable cd digital cd audio for this cd rom device or scroll to dvd regions select the no _ for your specific area
If this does not fix the problem you might try
Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. or
you might have to physically unplug the leads for this cd/dvd then plug them back this should activate the found new hardware wizard or
you might have to uninstall then restart your computer then reinstall your DVD/CD then reinstall the driver for this device
if your computer came with a motherboard disk the drivers could be on it
click start control panel administrive tools computer management device manager scroll down cd dvdrom drives if you see a yellow question or exclamation mark?! or a red x right click you will need to update the driver or
hope this helps
1helpful
Could not load the driver for this device. Perhaps the driver is corrupted or missing. (Code 39)
hi code 39 is a error code for a missing driver usually cd/dvd rom. go to my computer and right click /click properties /check for yellow exclamation marks against your cd/dvd rom /click/click update drivers.close program see if problem is fixed if not/
Read more: How to Fix Code 39 Driver Error | eHow.com http://www.ehow.com/how_5344400_fix-code-driver-error.html#ixzz0xzIAh2xi
follow this link .hope this helps.
1helpful
3answers
My DVD rom drive is not working I cannot "see" it on the system I have this error message "windowns cannot load the device driver for this hardware. the driver can be corrupted or m missing error code 29...
Check in device manager. To do this. 1st right click my computer, 2nd Click properties, 3rd click hardware, 4th click Device manager, 5th check that the computer is seeing the DVD/CD-ROM drives by double clicking the DVD/CD-ROM drives words or click the + symbol next to DVD/CD-ROM drives, the drop down menu will list your device if it’s there. If a device is listed double click the device. If it says it’s working properly click driver in the top bar and uninstall, then re-boot, the system will re-load the driver on re-booting. If the driver was corrupt it will re-install it correctly.
If the system cannot find the driver on re-booting it's missing from the systems file, go to the Support Fujitsu site and download and install the driver. Its free all you have to do is put the laptop details in the appropriate boxes and all the drivers for that laptop will be listed.
From your description of the error message it’s no doubt a corrupt or missing driver.
Hope this helps.
2answers
Drive not showing in WinXP (error code 39)Liteon Combo SOHC-5236v
After loading the Windows, the DVD/CD-ROM drives work properly, but we can not see the drives in “My Computer” (System can not recognize the drives.). When try to run the drives, it shows up a notice “Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code39).” Before solving this error, check the drives connection correctly, then follow the steps below:
Delete Device Manager. Most people will firstly think of Windows “Find New Hardware” when drives missed, but it does not always work out. To fix the problem: open “My Computer”’ “Control Panel” ’“System”’“Device Manager”’ “HDC(Hard Disk Controller) ”, then click “Delete”. Follow the note to reboot computer. After rebooting, the computer will find the Primary IDE Controller and Secondary IDE Controller again and install the drivers. Restart the computer again while the installation is completed. In this, we can get back our CD/DVD-ROM Drives.
The other way is by editing the registry to return the missed CD/DVD-ROM drives (Code 39 error.). Obviously, it is too risky to edit the registry if you are not familiar with it. To fix the error from the registry, carry out the following steps:
Exit and close all applications currently running on your PC.
Step1. Click Start > Run and type in Regedit, press Enter.
Step2. Look for the following registry key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\ {4D36E965-E325-11CE-BFC1-08002BE10318}
Delete any of the following registry entries under this key directory:
LowerFilters
LowerFilters.bak
UpperFilters
UpperFilters.bak
Step3. Reboot your PC and open My Computer to check that the CD-ROM drive is visible.
Also, have a look at the Device Manager to see if the yellow exclamation mark and the error code 39 are gone.
System errors are not welcome guests that bring up unhappy computing experience. Registry Easy (www.registryeasy.com) is a professional troubleshooting system maintenance tool that can help you to solve this error and many more.
Article Source: How to fix DVD/CD-ROM drives (Code 39 error) in Windows XP or Vista
Posted on 2 January '09 by , under TECH NEWS.
This worked for me.
! on my LG GCC4522B CD-RW/DVD-ROM
To solve this Code 39 error, follow these instructions:
NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
2helpful
Dvd rw
Please go through the below provide steps.
Fixing Code 39 Error
If your CD-ROM drive is not visible in My Computer, you may see the following error message displayed with the CD or DVD drive item in your Device Manager. (Steps to open Device Manager are discussed later in the article.)
"Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)"
Using Device Manager
To fix this error, first try to update the driver from the Device Manager. To open Device Manager, right-click My Computer on your Desktop, and then on the Hardware tab, select the Device Manager button.
In the Device Manager window, identify the CD or DVD drive item (with Yellow exclamation mark), right-click on it and select Update Driver. Follow the screen instructions to update the device driver and restart your PC.
Using Registry Editor
If updating the driver does not resolve the problem, it indicates that there is a problem in the registry. To fix this problem, you may have to remove a few keys from the registry.
Note: Be careful while working with the registry editor because changes done to the registry using the Registry Editor are irreversible and mistakes can leave you with more problems than when you started. Therefore, it is recommended that you make a backup of the registry before proceeding with the changes.
After you have removed the registry keys listed below, you will have to reinstall all applications that you use for CD or DVD recording to make them work properly.
To fix the error by editing the registry, perform the following steps:
  1. Exit and close all applications currently running on your PC.
  2. On Start > Run type Regedit and press the Enter key.
  3. Next, navigate to the following registry key:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\ Control\Class\ {4D36E965-E325-11CE-BFC1-08002BE10318}
  4. Delete any of the following registry entries if they exist under this key:
    • LowerFilters
    • LowerFilters.bak
    • UpperFilters
    • UpperFilters.bak
  5. Restart your PC and open My Computer to ensure that the CD-ROM drive is visible.
  6. Also, open the Device Manager again to ensure that the yellow exclamation mark and the error code is now gone.
  7. Restart your PC and open My Computer to ensure that the CD-ROM drive is visible.
  8. Also, open the Device Manager again to ensure that the yellow exclamation mark and the error code is now gone.
Thank you........
1helpful
4answers
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
