Question about Sansui VRDVD4005 DVD Player/VCR
I have a 2003 Sansui VRDVD4005 recorder. It currently playsback on channel 4 on my TV and I need to reset it so it plays back on channel 3. Do you know how I can make the change? All suggestions on the website do not seem to work for me.
  • kenya1122 Feb 25, 2009
    Thank you very much for the advise. It worked! You should know the 'paid' experts told me the unit wasn't designed to playback on any channel but 4 and even I knew that wasn't correct. So, thanks again!
  • Sansui Master
  • 520 Answers
Turn off the unit. press and hold the "3" button on the remote until you see "rf 3" in the display on the VRDVD4005. This will change the output channel to 3.
Posted on Feb 25, 2009
When I Insert A Cassette Into My Sansui, It Shows A Blue Screen With Nothing Else Written On The Screen. It Plays The Audio Perfectly Though. I Have Tried Many Head Cleaners But None Seem To Work.
is the yellow jack plugged into video out (DVD) to video in (TV).......is the TV on ch 3? if there is a switch on the back of player is it switched to 3 also?
Jan 17, 2011 | Sansui VRDVD4005 DVD Player/VCR
I have a Sansui model VRDVD4005. When I put a DVD
I think you need to take it to the service center, because there's nothing that you can do all by your self.The problems starts from the optical lens/ laser pick up, replacing the lens could be necessary.
Mar 07, 2010 | Sansui VRDVD5000 DVD Recorder/VCR
Can't see dvd on TV
how to hook up to watch dvds
May 25, 2009 | Sansui VRDVD4005 DVD Player/VCR
Only dvd plays properly but vhs will not show picture.
Most likely you have the dvd part connected through component or svideo cables. Despite the fact that this is one unit, like other vcr/dvd combo units it acts as two separate units in the same box. The vcr will probably not play through those cables. As you have audio coming through I'd imagine that the audio is connected using red and white composite cable. Connect the video on the vcr side with composite yellow cable or run direct to tv with a coaxial cable.
Feb 04, 2009 | Sansui VRDVD4005 DVD Player/VCR
Won't play DVDs or CDs at all. Reads error code C-104.
To solve this Code 10 error, follow these instructions: NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording applications.
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4)This folder is the DVD/CD-ROM Drive Class Description in the registry.Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the
Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives havereturned. You may also want to open Device Manager and verify that theyellow exclamation and error code on the CD or DVD drive is gone.
Dec 27, 2008 | Sansui VRDVD4005 DVD Player/VCR
SAN0901 Manual
again hope this helps!
i'll check back to see if you need more help
electech
Oct 22, 2008 | Sansui VRDVD4005 DVD Player/VCR
Sansui VRDVD4005 will record DVDs provided they are DVD-R NOT DVD+R. I have one of these for 3 going on 4 years and I took it apart and cleaned the dust off the magnetic hub and that worked for awhile but (2-3 months) now I'm having trouble finalizing again. Someone on this site said it needs 8x NOT 16x disks ... 'cause it's an older unit ... I'm checking it out in the users manuel.
magicbbs
Oct 19, 2008 | Sansui VRDVD4005 DVD Player/VCR
DVD Recording from Television on DVD and VHS
First off, be sure that you are on the channel that you want to record!!
Press the setup button, the SETUP menu screen appears.
Select "timer rec set".
Then another screen comes up... select "new"
Enter your times, dates, etc.
Dec 18, 2007 | Sansui VRDVD4005 DVD Player/VCR
Sansui vhs/dvd
there is a detection switch in the back of the unit it need to be cleaned or replaced.
Dec 13, 2007 | Sansui VRDVD4005 DVD Player/VCR
Transfering vhs to dvd
Is the vhs tape copy protected? I think you can only copy your own vhs tapes or what you record on tv. I could be wrong though.
Dec 03, 2007 | Sansui VRDVD4005 DVD Player/VCR
Sansui VRDVD4005 DVD Player/VCR Logo
139 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
