Question about LG LSC26905TT Side by Side Refrigerator
Freezer not freezing/compressor not running
After a power outage of just a few minutes a couple of days ago,the freezer is not freezing,and the refrigerator side is starting to get warm also...compressor not running - - -can it be restarted?rebooted?please help...husband is out of town!
  • Anonymous May 05, 2009
    my LG side by side, freezer doesnt work. i dont know what to do. please help
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
Relay on compressor
Posted on Apr 06, 2009
Freezer stopped after power outage
If the sides are hot, look at the defrost timer. Sounds like it has stopped running with the defrost elements on. The compressor has a safety switch on it that opens either if the compressor gets too hot or if it pulls too much current when starting. If your power flickered a lot before coming back on, that triggered the safety switch. Now that it's running normally, I wouldn't worry. The defrost timer is your problem now.
Jul 10, 2016 | Frigidaire 14.1 cu. ft. Upright Freezer...
Why doesn't my Kenmore Refrigerator/Freezer freeze food?
The compressor could be failing, especially if it was running when the power outage occurred.
Jul 15, 2014 | Kenmore Refrigerators
Maytag PTB1753GRW Both top and bottom not cold. Compessor starts for a few seconds. Then kicks off. Just lost power a few days ago. Power went on and off several times before power went off for hours. Any...
Hi Nick,
I would plug in a new start relay. The start relay is on the side of the compressor.
If the new relay still will not start the compressor then the compressor has been damage from the power outage.
Aug 03, 2011 | Maytag PTB1753G Top Freezer Refrigerator
Chest freezer not freezing on bottom
Sounds like a circulation problem. Does it have a fan inside the freezer. Should be bdhind the floor or one of the wall panels. There should be a vent for the air to circulat through. If so check to make sure it's running when the compressor runs.
Aug 19, 2009 | Whirlpool 10 cu. ft. Chest Freezer...
CTB1722GRW compressor clicking on for 20 to 30 seconds then off.
it depends on how severe the power spike on the outage was,if your lucky it may just be the contactor,if not comp time,you can open the contactor case and manually start the compressor,use an insulated non-metallic device to do so
Jul 20, 2009 | Magic Chef CTB1722 Top Freezer...
I have a 8 year old amana fridge model #SQD23VE we had a power outage about 1 week ago and the fridge has not been cooling properly since i hear the fans running but no ice is being made and things are not...
hi thanks forr the question so you cleand the coils inside the freezer and at the back by the compressor and was the compressor running . if it was and still not cooling you have a compressor problem
Sep 26, 2008 | Refrigerators
Amana AFD2535DEW freezer/refrigerator with intermittent tempurature swings
I had the same issue. It was the relay overload which essentially provides the extra boost to get the compressor going. The switch tries for about 10 seconds before giving up and then retries 3 - 4 minutes later. In the early stages of failure, eventually it will work and the compressor will kick on. But eventually the switch will fail and will just cycle through the 10 second attempt every 3 to 4 minutes. The part is about $35 - part number 67005560.
Jun 26, 2008 | Amana AFD2535DES French Door Refrigerator
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Freezer Problem
If it started to cool again the compressor was running. Check the condenser and make sure it is clean. Provide as much air movement through the garage as possible . 100 degrees is a high temperature to be operating a refrigerator in.
Jun 10, 2008 | Frigidaire Freezer 16.7 cu. ft. Upright...
LG LSC26905TT Side by Side Refrigerator Logo
738 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
