Question about HP ProLiant ML150 G3 Server
Instalation of windows server edition
Want install raid drivers
You have to make a floppy disk with the raid drivers on it. Start the Setup process and just as it's beginning it will ask you to hit F6 to install raid drivers. Hit F6, insert the floppy, install the drivers.
Posted on Feb 19, 2009
I tried installing windows server 2008 on my Ibm x236. after the installation completes when the system reboots I'm getting error msg. file: \windows\system 32\drivers\wdf01000.sys
that is a Western Digital driver file......for your hard drives likely.
If you are using RAID, then make sure that the RAID is the correct one, and if not, then make sure in the BIOS, you have NOT selected a RAID option.
If those do not seem to be at issue, then attempt to boot in Safe Mode with Networking. That error has been known to have other driver(s) unrelated to the WD driver.
Nov 04, 2014 | IBM X236 Server
How to installed xp2 in server hp proliant ml 350 my hard drive ok
You may need raid controller driver for HP proliant ml 350. Copy raid controller driver in flopy disc, insert it in flopy drive, insert cd in cd driver, boot server from cd and start installation process, as soon as you see Press F6 if you need to install third party scsi drivers or raid controller, press F6 and follow the instruction. It will then ask you to select RAID driver file and then will continue to windows xp installation.
Regards,
Kaushik Patel
Aug 24, 2013 | Computers & Internet
While i am tring to repair 2003 standard server on IBM 3400 Tower server i am facing a issue that hdd not found
Windows not see the disk because they are connected through a raid controller.
When you start the recovery windows you have to offer the installer the driver for raid. Installer wait new driver only 5 seconds.
During this time you must press "F3" and point driver on floppy.
Jun 16, 2011 | IBM x3400 Server
I cannot install windows 7,no disk seen are there drivers for raid smart array 5I for windows 7? DL 740 G1 , 8 x 2700Mhz+40GB ram , 4 x 73gb Raid 5
Not quite sure what your problem is but I would recommend getting Windows Server for a server like this. The HP site recommends the following OSes: Microsoft Windows 2000,
Microsoft Windows Server 2003 (Standard, Enterprise, and Datacenter) ,
LINUX (Red Hat, SuSE) or Microsoft Windows 2000 Datacenter Edition. It is unlikely Windows 7 will install on this 5 year old server.
Jun 06, 2011 | HP Compaq ProLiant DL740 Server
I am unable to instal windows server 2003 on HP Proliant ML150 G5 because it gives me message no hard drive found
Option 1 (HIGLY Recommended): HP servers should come with an install disk that prepares the windows installer for you. Boot from that disk,tell it your OS, and pop in the disk for the OS when prompted. It will come up fine and have all the HP monitoring agents installed.
Option 2: Load the driver the old fashioned way. Unless you have a floppy drive the standard "Press F6 to load drivers" trick won't work. If you do, then you'll need to put the RAID driver on the disk.
Option 3: Use an installation customizer like nLite to pre-add the RAID driver to the Windows 2003 installer.
Good luck.
Feb 26, 2011 | HP ProLiant ML150 G5 Server
When i install MS windows server 2003 in IBM x3400 server it gives me message that setup could not find any hard desk installed in your computer. guys please help me temor
Ensure drives are seated correctly and set up the RAID config.
Then on the Blue screen of Windows installation it will say "press f3 for 3rd party drivers", hit F3 (I think its F3), then insert a floppy disk with the drivers for you RAID controller, setup will then say it has found the followign drivers "your device xxx" then it should* pick up the hard drives later on in setup.
:) - RAID controller drivers can be got from the manufacturer websites.... normally.
Sep 05, 2010 | IBM x3400 Server
Hard drive not detected. When i trying to install Win 2003 Server Std edition. It does not detect the hard drive.
you will need to download the RAID drivers from the Dell website
http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R74082&SystemID=PWE_PNT_P3C_2450&os=WNT5&osl=en&deviceid=1374&devlib=0&typecnt=5&vercnt=7&formatcnt=2&fileid=126163 and load them onto a floppy drive.
Then when installing the server press F6 to install other drivers this will load the PEC drivers and W2k3 will then see your drives
Do not try to load the drivers from a USB as W2k3 is "preset" to only accept drivers from a floppy drive unlike WIndows server 2008
Hope this helps
Jul 22, 2010 | Dell PowerEdge 2650 Server
Gateway e-9425r was setup to boot via PXE. I want to boot off a raid. Have 2 250gb sata drives in system. Loading raid driver from gateway site on floppy. Windows install and bios don't detect raid or...
Copy RAID driver to mini diskette.
Boot server using Windows Server 2003 CD
The moment you see the blue setup screen press F6
After the setup runs for a little while it will ask you if you have any additional drivers you need to install
Then insert your mini diskette with the RAID driver and respond to prompts to load it.
Windows should no recognize the RAID controller and let you complete the installation.
Aug 10, 2009 | Gateway Computers & Internet
Ibm x series 226 attempt to install os and says no harddrive
Make sure that the motherboard and/or disk controller recognize the drives during POST.
Then check and see if IBM has a server installation CD-ROM that you can use boot the server and automatically load the correct drivers to prep for the OS install. I have downloaded installation CD ISO files from HP and Dell that walked me right through the OS install.
Another important consideration is that servers frequently use disk controllers that are not included in the operating system's driver files.
For example, when installing Windows OS on a RAID controller you must press F6 immediately after the installation CD-ROM starts up.
Later in the installation you will be prompted to insert a 1.44 diskette with the driver for your RAID controller.
The only challenge is to find the correct version of the driver and get it on a diskette.
I hope this helps.
Jul 16, 2009 | IBM xSeries 226 Server
HP ProLiant ML150 G3 Server Logo
354 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
